Page 1 of 4 1 2 3 4
A choice to make ... #96001
01/13/07 06:43 AM
01/13/07 06:43 AM
Wouter Offline OP
Wouter  Offline OP
Guys,
We have a choice to make I'm afraid.
I won't go into details right now but because of the short hull length this F12 will have a more narrow crew weight range then larger catamarans. We need to decide where to place this range.
I worked out the underlaying scalings law and as such can give you all a feeling of what we are talking about.
As the reference I put forward an F18 sailed from 115 kg to 180 kg, with 155 kg being optimal. Lets assume that all F18 crews in this range are more or less competitive and experience enjoyable sailing, meaning, neither heavily overpowered nor sluggish and underpowered.
If the F12 is exactly 12 feet long = 3.66 mtr then its characteric weights (similar to F18 above) are :
range = 31 to 50 kg with 43 kg optimal
if the F12 is 3.90 mtr long then its characteric weights (similar to F18 above) are :
range = 49 to 72 kg with 63 kg optimal.
if the F12 is 4.00 mtr long then its characteric weights (similar to F18 above) are :
range = 57 to 82 kg with 73 kg optimal.
All above boats have been scaled to not perform worse then the F18 when not looking at the other issues associated with scaling like the pitching moment problem (= dive happy).
Additionally, from the point of drag it is always better to sail an boat underweight then overweight. Meaning that being 10 kg overweight is just as bad as being 20 kg underweight. The overweightness just hits harder.
Be sure to note how only 0.1 mtr (= 4 inches) difference in hull length, (from 3.9 to 4.0) moves all characteristics weights up by 10 kg's ! 0.1 differenc in length is nothing on a F18 but it is the world on a F12.
The point of this post is that we need to decide what the F12 should carry in crew weights a choice here will have a direct impact on the required MINIMAL length of the hulls.
Please everybody give your opinions on this, I'll provide my own opinion at the very end of the discussion.
Re: A choice to make ... [Re: Wouter] #96002
01/13/07 07:59 AM
01/13/07 07:59 AM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
I know nothing about working out such figures, but my instinct says go for the greater buoyancy. It can still be called a F12, even if the length is closer to 13ft. When I see a Hobie 14 with it's hull so low in the water, I get worried about a 12ft cat. Even though I know that the hull shapes are different.
Dermot
Catapult 265
Re: A choice to make ... [Re: Dermot] #96003
01/13/07 09:07 AM
01/13/07 09:07 AM
Wouter Offline OP
Wouter  Offline OP
Don't look at the H14.
Picture yourself an F18 or Spitfire / F16.
I'm using the same scaling laws as I did with the F16's
In principle this would lead to a F12 with the same performance as the F18, despite being much smaller. But for true equality it would have to be fitted with jib and spi. Sadly there is a thing that I call the Quad-problem and it limits the amount of sail area you can put on the F12 before it turns into a right submarine. Therefor we are not going to achieve full F18 performance. But I have a feeling that we'll discuss this soon enough.
Re: A choice to make ... [Re: Wouter] #96004
01/13/07 09:35 AM
01/13/07 09:35 AM
Brighton, UK
grob Offline
grob  Offline
Brighton, UK
Stick with 3.6m don't get so hung up on performance. Make the hulls wider to get the increased crew weight. A 12ft boat will be lighter and more practical.
Gareth
Re: A choice to make ... [Re: grob] #96005
01/13/07 05:46 PM
01/13/07 05:46 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
Gareth
12ft might be more practical for home building - using 8ft sheets of ply. Less waste wood.
Dermot
Catapult 265
Re: A choice to make ... [Re: Dermot] #96006
01/13/07 06:23 PM
01/13/07 06:23 PM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Gday
12ft = 3.660m, so I would go 3.7m max, I wouldn't go anymore than that, it will start getting further from the objective if you go more.
I don't think theres any need to make them comparable to F18's, F16's or whatever to terms of performance, remember theres a lot of things that they have that this F12 won't.
Regards
Re: A choice to make ... [Re: mattaipan] #96007
01/13/07 07:02 PM
01/13/07 07:02 PM
Wouter Offline OP
Wouter  Offline OP
What would you name as our objectives ?
Also in an earlier posting you referred to some Aussies having other idea's about the F12, can you elaborate.
Re: A choice to make ... [Re: Wouter] #96008
01/13/07 09:32 PM
01/13/07 09:32 PM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
F12 Great Idea! <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
I’d guess drag is not the big challenge as short boardless cats are a much more difficult to tack, especially without a jib! Rocking horse effect is another matter. What makes you think this design will be any different?
Ease of tacking is an essential element in training new sailors and one reason why the Opti is so popular (less run away boats!).
I suppose a hull design using ultra low profile boards would be make a major difference in the handling characteristics. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: A choice to make ... [Re: Buccaneer] #96009
01/13/07 10:01 PM
01/13/07 10:01 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
The boardless Dart 16 is amazingly responsive. No problem tacking.
Dermot
Catapult 265
Re: A choice to make ... [Re: Wouter] #96010
01/13/07 10:22 PM
01/13/07 10:22 PM
A MAJOR objective, IMHO, would be no boards of any kind. Skegs only.
By the way, has anybody ever heard of a "shoe"? An exremely low-profile "keel" that has been used on cruising catamarans? When I say "low profile," I mean it is only a few inches deep below the bottom of a 35-foot-long boat. It has kind of a fat, upside-down-T shape. The boat we sailed pointed very well with VERY little leeway, and it tacked on a dime. Would that work on a smaller boat, too?
Re: A choice to make ... [Re: Dermot] #96011
01/13/07 10:26 PM
01/13/07 10:26 PM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi Wouter
Well I guess the main objective was a 12ft cat, increasing its length to make it suitable for a larger weight range, you may as well build a Paper Tiger or an Arrow.
I spoke offline to another forum user, who to is interested in introducing a more modern 12ft cat for trainers, for their junior fleet, as we had said earlier, we would prefer and his own kids would prefer to have the option of a trapeze, and probably an optional jib to allow their friends to continue to sail with them after they get the hang of it. We didn't really discuss hull shapes or profiles, but the boat I'm working on, would be tortured ply design, not that I'm a designers little toe, but I'm having a crack at it, I don't find tortured ply difficult at all, when I try to explain it to someone who hasn't a clue what I mean, I think its sounds more technical than it really is.
Regards
Re: A choice to make ... [Re: mattaipan] #96012
01/14/07 12:42 AM
01/14/07 12:42 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
This Hobie Teddy looks to be about 12' with skags but uses a jib for improved tacking. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: A choice to make ... [Re: Buccaneer] #96013
01/14/07 12:46 AM
01/14/07 12:46 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
This one looks even smaller. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: A choice to make ... [Re: Buccaneer] #96014
01/14/07 04:30 AM
01/14/07 04:30 AM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
I saw one once - I think that it has the inverted T shaped skegs that Mary mentioned - made it look a bit agricultural.
Dermot
Catapult 265
Re: A choice to make ... [Re: Buccaneer] #96015
01/14/07 04:36 AM
01/14/07 04:36 AM
The Teddy looks a lot like a scaled down Hobie Tiger
with skegs.
Is the jib self tacking?
Re: A choice to make ... [Re: phill] #96016
01/14/07 04:43 AM
01/14/07 04:43 AM
Just took another look.
The jib does not appear to be self tacking but then I don't
think the Tiger's jib was self tacking first up.
I think the 12ft target audience needs something much simpler to maintain the advantages of the 12 ft size.
Just a personal view.
Re: A choice to make ... [Re: phill] #96017
01/14/07 05:06 AM
01/14/07 05:06 AM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
The Hobie Teddy looks alright, nice clearance under the sail for moving around, never seen one til now.
Regards
Re: A choice to make ... [Re: mattaipan] #96018
01/14/07 06:28 AM
01/14/07 06:28 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Here's one of the skegs.. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: A choice to make ... [Re: Buccaneer] #96019
01/14/07 06:48 AM
01/14/07 06:48 AM
Yes, I think that 'shoe keel' is what I was talking about. It worked phenomenally well on the Witness 35(?). What difference does it make if it LOOKS agricultural but works great? You guys are SO superficial. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Didn't you ever hear that song that goes: "If you want to be happy for the rest of your life, make an ugly woman your wife"? <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: A choice to make ... [Re: Mary] #96020
01/14/07 06:57 AM
01/14/07 06:57 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Just don’t mention that to my wife… <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Page 1 of 4 1 2 3 4
0 registered members (), 668 guests, and 142 spiders.
Posts267,056
