| Re: rhino liner
[Re: tx246]
#96889 01/21/07 08:15 AM 01/21/07 08:15 AM |
Posts: 12,310 South Carolina | West Marine carries a material they call "keel guard". I know a lot of power boaters that put it on the front of their boats so they can beach the boat without worries. It's a thick rubber strip that glues around the keel. I'm not sure if it's meant to go the whole length of a boat or if it will wrap tightly enough around the sharp bottom of the H16.
You'll be better off if you could make some sort of landing pad for your boat...old carpet or strips of PVC tubing.
Jake Kohl | | | Re: rhino liner
[Re: Seeker]
#96892 01/21/07 10:48 PM 01/21/07 10:48 PM |
Posts: 12,310 South Carolina | Jake.. has this been done before…take some 6” schedule 40 PVC Pipe the length of the keel...cut it in half…heat up one end to form an upsweep...contact cement some carpet on the inside and have a couple short lines from the front of these skids to the forward chain plate so they stay in place when the boatis drug along… might be poor mans beach wheels to transverse soft sand.
Regards, Bob I can't say that I've ever seen that before. (but if you put a series of PVC pipes on the ground perpendicular to the direction of travel, the cat will slide on them like they were ice.
[Re: tx246]
#96894 01/22/07 01:41 AM 01/22/07 01:41 AM |
Posts: 36 MOBILE, AL. | The Rhino Liner will work just fine but will compromise some speed. If speed is not a concern then your on the right track. Be sure to tape off a waterline where you want the rhino to stop. Prep by sanding with 80 grit paper & be sure to whipe hull down with a wax & grease remover before application. DOUG
SOUTHERN CROSS FIBERGLASS, LLC.
9301 HWY. 90 EAST
MOSS POINT, MS. 39581
251-473-8159 DOUG KLEM
2,883
guests, and 311
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
