rhino liner #96888
01/21/07 02:39 AM
01/21/07 02:39 AM
tx246 Offline OP
tx246  Offline OP
im not a racer and have an old h16. i am tired of redoing the lower portions of the hulls every two yrs. my "beaches" tend to be comprised of gravel and other sharp objects.
has anybody used rhino liner along the lower hull line? the stuff seems really tough in the back of a truck. i know its way heavier than paint but seems like it would be more durable than fiberglass.
Re: rhino liner [Re: tx246] #96889
01/21/07 08:15 AM
01/21/07 08:15 AM
West Marine carries a material they call "keel guard". I know a lot of power boaters that put it on the front of their boats so they can beach the boat without worries. It's a thick rubber strip that glues around the keel. I'm not sure if it's meant to go the whole length of a boat or if it will wrap tightly enough around the sharp bottom of the H16.
You'll be better off if you could make some sort of landing pad for your boat...old carpet or strips of PVC tubing.
Re: rhino liner [Re: Jake] #96890
01/21/07 10:12 PM
01/21/07 10:12 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Jake.. has this been done before…take some 6” schedule 40 PVC Pipe the length of the keel...cut it in half…heat up one end to form an upsweep...contact cement some carpet on the inside and have a couple short lines from the front of these skids to the forward chain plate so they stay in place when the boatis drug along… might be poor mans beach wheels to transverse soft sand.
Bob
Re: rhino liner [Re: Seeker] #96891
01/21/07 10:24 PM
01/21/07 10:24 PM
TX246:
Just make some of these:
http://dgaleana2.proboards56.com/in...action=display&thread=1143785090
Also check out our website if you are in Texas still?
www.tcdyc.com
Doug
Re: rhino liner [Re: Seeker] #96892
01/21/07 10:48 PM
01/21/07 10:48 PM
Bob
I can't say that I've ever seen that before. (but if you put a series of PVC pipes on the ground perpendicular to the direction of travel, the cat will slide on them like they were ice.
Re: rhino liner [Re: Jake] #96893
01/21/07 11:46 PM
01/21/07 11:46 PM
tx246 Offline OP
tx246  Offline OP
i get wear on my hulls from beaching the cat during the day at stopping points. i launch from a regular boat ramp. the wheel kits look like the bomb as far as a beach launch goes.
ive seen the keel guards but they run 85-100 each and ive considered them.
if the rhinoliner material would work, it would be cost effective.
Re: rhino liner [Re: tx246] #96894
01/22/07 01:41 AM
01/22/07 01:41 AM
MOBILE, AL.
scross Offline
scross  Offline
MOBILE, AL.
The Rhino Liner will work just fine but will compromise some speed. If speed is not a concern then your on the right track. Be sure to tape off a waterline where you want the rhino to stop. Prep by sanding with 80 grit paper & be sure to whipe hull down with a wax & grease remover before application. DOUG
SOUTHERN CROSS FIBERGLASS, LLC. 9301 HWY. 90 EAST MOSS POINT, MS. 39581 251-473-8159 DOUG KLEM
0 registered members (), 629 guests, and 448 spiders.
