| Re: A cat mainsail/mast compatability
[Re: davefarmer]
#96908 01/21/07 03:44 PM 01/21/07 03:44 PM |
Posts: 221 Netherlands | Hi Dave, I understand the point of the mast measurement but when you have two sails you can see which one is the flatter one and can make a choise that one of the 2 sails is best for you and than you can let try a sailmaker to copy this sail but this is still difficult. The point about the mast is that it is a pretty old mast and it is not to compare anymore with todays masts but what the cheapest way of doing is buy a sail of 1 year old and give it a shot. The point about the bending is that everybody is doing this different so this is always a problem but a good sailmaker should do the job. Otherwise look at the A-class IACA website or contact us at info@catamaranparts.nl maybe we can help you, we are doing the A-class and Blade F16 in Europe. Regards, Hans | | | Re: A cat mainsail/mast compatability
[Re: davefarmer]
#96909 01/21/07 04:04 PM 01/21/07 04:04 PM |
Posts: 163 Atlanta | is there a way to identify this mast, or determine it's bend characteristics? A 2005 XJ that I sail against at Lake Lanier has a Riba mast. There is actually a Riba sticker under the clear-coat near where you feed in the sail. It is difficult to see. If Bimare was using Riba masts in 96 you might look for a similar sticker under the clear-coat to help ID the mast. | | | Re: A cat mainsail/mast compatability
[Re: Hans_Ned_111]
#96910 01/21/07 09:43 PM 01/21/07 09:43 PM |
Posts: 713 WA, ID, MT | Yeah, I recognize that a nice position to be in, is to be more than happy to be downstream of racers who have little use for last years sail. But if they are only going to be compatible with new masts, then the idea of getting a fun(non racing) solo boat for relatively cheap ($3 to 4 K?), might not be so practical. So how would a good Acat sailmaker build a sail for a 10 year old mast that I may or may not be able to identify. Would it help if he had the mast? Are there ways to quantify mast bend that I could do? Could a one year old main be affordably recut for an older mast?. How much for a 2 year old mast that a sail could be found or built to match ( I think I'm venturing beyond my budget). What I'm hoping to do is determine whether I can by a cheap boat, sail it for a season or two without much further investment, and then be able to find a newer (new?) sail that will work well with the existing mast. Am I hoping for too much with too little financial committment? It just seems that it's possible to get 85 to 90 percent of the performance of a new A, for about a third of the cost of a new one, because this is almost exlusively a race boat, and in a class that is developing steadily. Opinions?
Dave | | |
2,803
guests, and 612
