| Re: replacing track rivets
[Re: Pascal]
#97478 01/31/07 12:17 PM 01/31/07 12:17 PM |
Posts: 284 Norfolk, VA | There are a few tricks. First, I use a little piece of scotch tape on the back of the rivet to hold the shaft in so that it doesn't fall through the rivet and into the beam. Usually when that happens, it is on the second squeeze, so you end up having to drill the rivet back out again. You need to use stainless countersunk rivets and they run about a buck each.
I have one of those industrial rivet pullers that has long handles and looks like bolt cutters. You can get them on eBay at a great price and I really recommend them if you are dealing with stainless rivets. I took the head and ground off two sides so that it fits into the traveler track and sits flat on top of the rivet on the bottom of the track. Works like a charm.
Also, when using stainless, don't be in a hurry to aqueeze it. You end up poping the rivet too soon and it doesn't set well. The best way is to slowly but firmly squeeze it and get as many pulls as you can.
Man, that sounds perverted, but I'm talking boat parts!
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
[Re: mmiller]
#97480 01/31/07 07:25 PM 01/31/07 07:25 PM |
Posts: 4,119 Northfield Mn | If you can borrow a pnuematic riveter it makes life much easier. Those stainless rivets are tough on the hands, and they seem to set more consistantly, and tighter.
[Re: rictorn]
#97483 03/27/07 08:13 PM 03/27/07 08:13 PM |
Posts: 5,582 “an island in the Pacifi... | i replaced my main travaler rivets with small bolts, it worked a treet but you need a tool to make a thread in the holes you drill in your beam A tap? US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: replacing track rivets
[Re: rictorn]
#97484 03/27/07 09:31 PM 03/27/07 09:31 PM |
Posts: 4,119 Northfield Mn | How does the traveler clear the bolts? If the rivets stick up a little bit it gets snagged.
2,533
guests, and 195
