| Nacra 6.0 cross wire under trampoline - purpose? #9806 08/21/02 10:47 AM 08/21/02 10:47 AM |
Joined: Jun 2001 Posts: 12,310 South Carolina Jake OP
Posts: 12,310 South Carolina | Being unfamilar to this new boat of mine, I have found a cable that runs from the starboard end of the forward beam to the port end of the aft beam. I assume this is for rigidity of the boat but would have figured on two crossing wires at 90 degrees instead of just one. Is this just to load up the joints to eliminate slop? How should it be set? There's nothing in the manual about this cable.
Jake Kohl | | | Re: Nacra 6.0 cross wire under trampoline - purpose?
#9807 08/21/02 09:50 PM 08/21/02 09:50 PM |
Posts: 217 | Sounds like a trick question designed to flush out the smarta**es.
So, here goes :
This cable does provides cross-platform support, in case of a collision. It is asymmetrical because it is only intended to aid in collisions while on port tack, which since they will be your fault, will entail larger $$ outlay. For collisions while on starboard tack, damage will usually be responsibility of other party, so there is no need to carry the extra weight of this kind of cable.
[Re: jcasto1]
#9808 08/21/02 10:39 PM 08/21/02 10:39 PM |
Posts: 12,310 South Carolina | gotta give you credit on that one...you really put some thought into that! ![[Linked Image]](/forums/images/icons/wink.gif) ...but seriously...what's this thing for? I'm an enginerd and It's killing me.
#9809 08/21/02 10:59 PM 08/21/02 10:59 PM |
Posts: 96 Racine, Wisconsin | Did the previous owner add it for structural and/or alignment reasons? I have nothing like this on my 6.0 NA. How much tension is in the cable? Enough to cause significant torque at the hull and cross beam joints? Torque translates to stress, not a good thing.
I am disappointed that an enginerd would not include a detailed freebody diagram wth all the important dimensions, forces and couples (we'll pass on material properties this time). Tsk Tsk. Your old statics prof would not be happy about this.
Paul Scott Bartelt
2001 NACRA 6.0 NA #546
#9810 08/22/02 06:58 AM 08/22/02 06:58 AM | Anonymous
| Anonymous
Unregistered | I have nothing like this on mine an I can't figure the purpose of it. | | | Re: Nacra 6.0 cross wire under trampoline - purpose?
[Re: EasyReiter]
#9812 08/22/02 10:51 AM 08/22/02 10:51 AM |
Posts: 12,310 South Carolina | Apparently I'm the dumb a$*! After a quick glance the other day it looked like it was incorporated into the hull locators and I assumed it was factory. It's not very tight but you definitely feel it if you stand on the trampoline over it (that's how I found it). It has a turnbuckle just like the diamond wires. I'll take another look at it tonight and maybe post some pics. Whatever it is, somebody took some time to construct it. The mystery continues.... Perhaps it's the only thread holding the boat together! (like I said, I just bought it)
[Re: HoldenBeachin]
#9814 08/23/02 01:24 PM 08/23/02 01:24 PM |
Posts: 2,844 42.904444 N; 88.008586 W | "If Todd does not know what this cable is used for then it is extra."
Todd here.
I liked the one about the lobster traps.
Did you ask the previous owner? I hope it's not really there for a reason of boat stability.
As others have also posted, it's not something that comes with the boat, or even a common add-on.
My vote is ask who put it there.
Todd Bouton
n6.0na
+sq top and spin/snuffer
#111
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#9816 08/23/02 04:17 PM 08/23/02 04:17 PM |
Posts: 12,310 South Carolina | I've been trying to call the person I bought it from was reportedly moving to Alaska in a hurry (that's why the price was so right - no worries - he had the original bill of sale!). I haven't had a chance to look at it again but I think the 'racked' assembly is the leading theory I have now. However, I thought the rear beam brackets on the beams were adjustable so you could take out any misalignment there.
#9817 08/23/02 10:24 PM 08/23/02 10:24 PM |
Posts: 96 Racine, Wisconsin | With the mystery device in place, measure your boat from corner to opposite corner. Use a definitive set of points such as starboard bow foil tang to port rudder pintle and vice versa. Are those lengths equal? Now remove (de-tension) the mystery device and repeat. Are the cross measurments still equal? If not, you obviously have an alignment issue that is being rectified by the mystery device.
Paul Scott Bartelt
273
guests, and 54
