Nacra 6.0 cross wire under trampoline - purpose? #9806
08/21/02 10:47 AM
08/21/02 10:47 AM
Jake Offline OP
Jake  Offline OP
Being unfamilar to this new boat of mine, I have found a cable that runs from the starboard end of the forward beam to the port end of the aft beam. I assume this is for rigidity of the boat but would have figured on two crossing wires at 90 degrees instead of just one. Is this just to load up the joints to eliminate slop? How should it be set? There's nothing in the manual about this cable.
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: Jake] #9807
08/21/02 09:50 PM
08/21/02 09:50 PM
jcasto1 Offline
jcasto1  Offline
Sounds like a trick question designed to flush out the smarta**es.
So, here goes :
This cable does provides cross-platform support, in case of a collision. It is asymmetrical because it is only intended to aid in collisions while on port tack, which since they will be your fault, will entail larger $$ outlay. For collisions while on starboard tack, damage will usually be responsibility of other party, so there is no need to carry the extra weight of this kind of cable.
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: jcasto1] #9808
08/21/02 10:39 PM
08/21/02 10:39 PM
Jake Offline OP
Jake  Offline OP
gotta give you credit on that one...you really put some thought into that! [Linked Image]...but seriously...what's this thing for? I'm an enginerd and It's killing me.
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: Jake] #9809
08/21/02 10:59 PM
08/21/02 10:59 PM
Racine, Wisconsin
Leo Offline
Leo  Offline
Racine, Wisconsin
Did the previous owner add it for structural and/or alignment reasons? I have nothing like this on my 6.0 NA. How much tension is in the cable? Enough to cause significant torque at the hull and cross beam joints? Torque translates to stress, not a good thing.
I am disappointed that an enginerd would not include a detailed freebody diagram wth all the important dimensions, forces and couples (we'll pass on material properties this time). Tsk Tsk. Your old statics prof would not be happy about this.
Paul Scott Bartelt 2001 NACRA 6.0 NA #546
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: Jake] #9810
08/22/02 06:58 AM
08/22/02 06:58 AM
I have nothing like this on mine an I can't figure the purpose of it.
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: Leo] #9811
08/22/02 09:45 AM
08/22/02 09:45 AM
Houston, Texas
EasyReiter Offline
EasyReiter  Offline
Houston, Texas
Could it have something to do with righting the boat when capsized? (since it is under the tramp) does it disconnect? used to hook on to when surfing off the back? was the previous owner a fisherman and used it to snag his lobster pots? the other one broke off and was never replaced? If Todd does not know what this cable is used for then it is extra. Ok I admit I am a dumb a&^.
Marc Reiter I 20 #861 Dikes, Ferries and Tramps. www.texascitydike.com
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: EasyReiter] #9812
08/22/02 10:51 AM
08/22/02 10:51 AM
Jake Offline OP
Jake  Offline OP
Apparently I'm the dumb a$*! After a quick glance the other day it looked like it was incorporated into the hull locators and I assumed it was factory. It's not very tight but you definitely feel it if you stand on the trampoline over it (that's how I found it). It has a turnbuckle just like the diamond wires. I'll take another look at it tonight and maybe post some pics. Whatever it is, somebody took some time to construct it. The mystery continues.... Perhaps it's the only thread holding the boat together! (like I said, I just bought it)
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: Jake] #9813
08/23/02 12:28 PM
08/23/02 12:28 PM
Maryland, USA
HoldenBeachin Offline
Maryland, USA
Is this a brand new boat? If not, could this wire have been installed to correct a misalignment in the hulls?
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: HoldenBeachin] #9814
08/23/02 01:24 PM
08/23/02 01:24 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
"If Todd does not know what this cable is used for then it is extra."
Todd here.
I liked the one about the lobster traps.
Did you ask the previous owner? I hope it's not really there for a reason of boat stability.
As others have also posted, it's not something that comes with the boat, or even a common add-on.
My vote is ask who put it there.
Todd Bouton
n6.0na
+sq top and spin/snuffer
#111
F-18 Infusion
#626- SOLD it!
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: Jake] #9815
08/23/02 03:51 PM
08/23/02 03:51 PM
Crystal Beach/Dunedin CSWY Fl.
catsailorp19mx Offline
Just an idea, but I ran into a guy one time that had "what appears" to be what you have. He had installed that wire because his platform was "racked". Might want to check for square. Just a suggestion.
Dave
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: Todd_Sails] #9816
08/23/02 04:17 PM
08/23/02 04:17 PM
Jake Offline OP
Jake  Offline OP
I've been trying to call the person I bought it from was reportedly moving to Alaska in a hurry (that's why the price was so right - no worries - he had the original bill of sale!). I haven't had a chance to look at it again but I think the 'racked' assembly is the leading theory I have now. However, I thought the rear beam brackets on the beams were adjustable so you could take out any misalignment there.
Re: Nacra 6.0 cross wire under trampoline - purpose? [Re: Jake] #9817
08/23/02 10:24 PM
08/23/02 10:24 PM
Racine, Wisconsin
Leo Offline
Leo  Offline
Racine, Wisconsin
With the mystery device in place, measure your boat from corner to opposite corner. Use a definitive set of points such as starboard bow foil tang to port rudder pintle and vice versa. Are those lengths equal? Now remove (de-tension) the mystery device and repeat. Are the cross measurments still equal? If not, you obviously have an alignment issue that is being rectified by the mystery device.
0 registered members (), 439 guests, and 51 spiders.
