| Question on the main downhaul #98383 02/07/07 09:28 AM 02/07/07 09:28 AM |
Joined: Jan 2007 Posts: 71 Lake Norman, NC Special_Treat_P182 OP
Posts: 71 Lake Norman, NC | I believe this is the very first time I have started a thread here. I'm fairly new to Catsailor although I've been sailing for close to 22 years (cats being Trac-16, Hobie-16/18 and Prindle 18-2). I've never been a big racer and have sailed for mainly pleasure (as you can tell by the lack of Inters, Tigers, Formulas, etc. in the list above). So all you hard core racers... go easy on me. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> In fact, in recent years have been on 'hiatus' from sailing all together due to babies and faily/work issues. But I can't restrain the bug any longer and I'm stoked for the '07 season!
Anyway, back to my question: I picked up Rick's DVD and while just about everything is a refresher, the use of the downhaul to de-power in heavy wind conditions is somewhat new to me. Never been used on the older boats. I currently sail an Prindle 18-2 #590. It's stock downhaul doesn't lend itself at all to adjustments under sail. Even with a longer line, it seems to have been designed to be set on the beach and left in place while under sail.
If I spend any money at all this year on the boat, is an 8:1 or 16:1 power downhaul kit an absolute necessity for me to upgrade from stock? $200-$250 is a bit of a stretch for me (like I said, go easy on me you hard core racers!) Do you find yourself making frequent adjustments on the downhaul from the wire? I've been sailing my boat stock for the (on/off) 8 years that I've owned it. Is this a definite upgrade consideration for this year? I've never been happy with the stock downhaul to begin with. It's difficult even on the beach and don't think a crewman would have fun adjusting it while under sail. | | | Re: Question on the main downhaul
[Re: Special_Treat_P182]
#98385 02/07/07 10:37 AM 02/07/07 10:37 AM |
Posts: 12,310 South Carolina | Yeah, downhaul is a must to be 'fast'. To be 'fast', when there is plenty of breeze, you need to control your throttle every few seconds and the main downhaul is the fine control on the throttle. You want to avoid steering up into the wind to depower as this requires a significant movement of the rudders (drag) and dramatically decreases the efficiency of the sails when you point up too high.
Downhaul works on any boat but it really came on when our boats designers started raking the diamond wire spreaders aft giving the mast "pre-bend". With this system, when you crank the downhaul, it bends the mast significantly more - which flattens the sail by moving the mid-luff forward. However, even on non-prebent systems, stretching the sail material with downhaul also serves to move the draft further forward making the sail more efficient and a little less powerful.
So yes, I suspect you will experience quite a difference when you are trapezed. When a gust hits, quickly tighten the downhaul and you can literally feel the boat squirt forward as the sails become more efficient and turn what would normally be excess power into speed. Without tweaking the "throttle" this way, your boat just heals excessively and you have to pinch up to keep it from flipping over.
6:1 and maybe 4:1 should be plenty for a dacron sail but you probably need to start thinking about 8:1 or better for laminate sails.
Jake Kohl | | | Re: Question on the main downhaul
[Re: drbinkle]
#98386 02/07/07 10:37 AM 02/07/07 10:37 AM |
Posts: 902 Norman,OK | I know where you are, I am mainly a recreational sailor and keep seeing all this stuff about downhaul. I have just decided that I will stick with what I have because I can adjust mine with just a pull even though it is only 3:1.
#98387 02/07/07 10:42 AM 02/07/07 10:42 AM |
Posts: 1,459 Annapolis,MD | Even before I raced, I upgraded the downhaul on my Hobie-18. I usually set it for whether I was upwind or downwind, didn't play it for puffs, but if the wind came up I put more downhaul in. I pretty much used it that way even when racing.
The Hobie-20 was very sensitive to downhaul - we could be driving upwind and control the hull flying by playing the downhaul and leaving the main trim alone, very nice.
The 6.0 as that way too, although we found ourselves again playing the sheets and traveler more for some reason - probably because the luff was stretched out (old sail) and just taking the wrinkles out used up much of the range. Would still adjust the downhaul for point of sail and for changing gears when the wind went up or down.
The N-20 we seem to work the sheet and traveler more, but still pay attention to the downhaul more than setting on the beach.
My advice - whether racing or not, fix up your downhaul and learn to use it while sailing. I think you'll be happy you did. | | | Re: Question on the main downhaul
[Re: drbinkle]
#98388 02/07/07 10:50 AM 02/07/07 10:50 AM |
Posts: 71 Lake Norman, NC | I'll sail in almost any air (up to 20'ish). I've always adjusted traveler/mainsheet and heading in bigger air. I always sail with the jib because my boat goes like crap to weather even with it. Without it, I might as well have a gaff-rig. I would like to try my hand at racing. I've done a little as crew in the past, but never with my boat and me skippering. I know I've got some big hurdles to overcome: Gaining racing experience, finding regular/dedicated crew to practice with, finding a race with people willing to accept a newbie such as myself, and be willing to sail in an open class as surely, there are very few 18.2's out there.
I'm cheap as well. But I do want the ability to easily control the boat when I need to when either racing or pleasure sailing. And certainly when the wind picks up, youre adrenaline starts flowing, and the pucker-factor is increasing - you want to know that you have the ability to control and depower when you need to. Rick seems repeatedly adament that the downhaul is one of the most critical controls on the boat. And it's something I have not been taking advantage of. In fact, I may have been sailing INCORRECTLY for over 20 years as I've been making up for a lack of downhaul control while under sail. And no sailor wants to sail incorrectly. If $200 and some practice makes me that much better, faster and more confident in controling my boat, to me it's worth it.
I haven't sailed with any of the LNYC guys mainly because I could never afford to join the club and I haven't done Catfest. I would like to do the regatta this year though. I know they're a nice group by reputation. I just never knew how open they were to outsiders who wouldn't be paying any club dues. Almost ten years of living in Mooresville and sometimes I still feel like an outsider. | | | Re: Question on the main downhaul
#98393 02/07/07 12:43 PM 02/07/07 12:43 PM |
Posts: 1,203 uk | What Jake says is right, but if you dont want to go to the expense of having a system that can be controled while sailing make sure that you have one that at least works. If its windy, park the boat up stand on the tramp and whack loads of downhaul on and leave it. I seem to remember standing on the tramp and pushing the rope down with my foot whilst holding the tail was the way to go on the standard system. You will find the 18.2 much easier to sail in a blow with lots of downhaul. Remember to let it off before you hit the beach, its a shame to see sailors wrestling a wild stallion onto its launcher when they have left the downhaul on.
[Re: TEAMVMG]
#98394 02/07/07 01:17 PM 02/07/07 01:17 PM |
Posts: 9,582 North-West Europe | More easy is to turn the boat head to wind on the beach (or on the water) and pull the mainsheet tight and only then pull on the downhaul. The mainsheet will bend the mast to a large extend making it FAR easier to pull on the downhaul and cleat it. Then release the mainsheet and the mast will stay bend (as you want) and you are ready to go of to some heavy wind sailing.
No expensive cleats needed for this. I use to preset my downhaul on my 1974 Prindle 16 that way and it used a horn cleat and only 1:4 purchase.
#98398 02/07/07 03:21 PM 02/07/07 03:21 PM |
Posts: 1,459 Annapolis,MD | And I'm guessing I would want to remove my beer cooler frame as well? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Don't remove it. But do add an air cannon that will fire the empties at your competitors! | | | Re: Question on the main downhaul
#98401 02/07/07 04:43 PM 02/07/07 04:43 PM |
Posts: 12,310 South Carolina | No sweat! That I already have! <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> Need more information on this...how is this propelled? (hair spray?), does it do potatoes?
Jake Kohl | | |
2,883
guests, and 311
