nacra 18 sq in the uk? #100648
03/14/07 08:31 PM
03/14/07 08:31 PM
rictorn Offline OP
rictorn  Offline OP
are their any nacra 18 squares, any in the uk, i realy want one, i don't mind if their are bits missing
Re: nacra 18 sq in the uk? [Re: rictorn] #100649
03/15/07 09:15 AM
03/15/07 09:15 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
There was a guy down in the west country that had one about 15 years ago, not heard any more of it since, it might have gone to europe.
Keep on the lookout for 5.5 hulls and a inter20 mast, then make your own. Talk nicely to the NacraUK guys and see what they can do. There was one put together recently for a US customer - gonna cost a few quid tho!
Re: nacra 18 sq in the uk? [Re: TEAMVMG] #100650
03/15/07 10:33 AM
03/15/07 10:33 AM
Shanghai, China
Dirk Offline
Dirk  Offline
Shanghai, China
you might seriously consider looking for them in the netherlands.
they are offered quite cheap which might balance the extra cost for transportation. good luck!
Re: nacra 18 sq in the uk? [Re: rictorn] #100651
03/15/07 01:56 PM
03/15/07 01:56 PM
www.catamaranparts.nl has a second hand 18 sq on offer.
It is named here http://www.catamaranparts.nl/botenmarkt.htm
Re: nacra 18 sq in the uk? [Re: Wouter] #100652
03/15/07 02:32 PM
03/15/07 02:32 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
thats not a bad buy for about £3K - carbon mast too.
They don't look like nacra bows on that photo, though the daggers do look like nacra.
Re: nacra 18 sq in the uk? [Re: TEAMVMG] #100653
03/16/07 03:08 AM
03/16/07 03:08 AM
The hulls aren't Nacra indeed. It is a custom 18 Square that did use some nacra components like the daggerboards I believe. Are component are however professionally build. The hulls are PESA, they used to commericially build A-cats in the 80's and early 90's I believe. The mast is most likely a Saarberg carbon mast with a landenberger sail if I remember correctly.
So indeed it is not a NACRA 18 sq. even though it is an official 18 sq. (it used to be a formula type of class) and may interest the initial poster just the same.
Re: nacra 18 sq in the uk? [Re: Wouter] #100654
03/16/07 12:41 PM
03/16/07 12:41 PM
Shanghai, China
Dirk Offline
Dirk  Offline
Shanghai, China
rictorn,
as you made some statements of performance somewhere, the nacra 18 sq is bloody heavy and was said to have a tendency to nosedive downwind when trying to do the wildthing... you will never catch a modern A with that. the boat Hans is selling might be a different story. It is a little lighter than the nacra and could have the potential to be as fast/faster upwind than an A in medium winds as it is wider and carrys more sail. The advantage of the old nacras around is that they are quite solid and sold between 1000-2000 € and mostly you just need a new sail on them and thats it. but its a boat which weights more than two A! and you better never capsize it...
Re: nacra 18 sq in the uk? [Re: Dirk] #100655
03/16/07 12:49 PM
03/16/07 12:49 PM
Shanghai, China
Dirk Offline
Dirk  Offline
Shanghai, China
p.s.
if costs is not an issue, you can also contact aicher+egner, the german flyer producer. they used to build the flyer XL which was 85 kg and 2.8m wide with enlarged sailplan. not many of those boats have been build so.
Re: nacra 18 sq in the uk? [Re: Dirk] #100656
03/16/07 02:04 PM
03/16/07 02:04 PM
Re: nacra 18 sq in the uk? [Re: Tony_F18] #100657
03/16/07 10:34 PM
03/16/07 10:34 PM
Shanghai, China
Dirk Offline
Dirk  Offline
Shanghai, China
nice designers signature: it really looks a bit like a baby extreme 40 :-)
Re: nacra 18 sq in the uk? [Re: Dirk] #100658
03/18/07 01:45 PM
03/18/07 01:45 PM
The VX40 was designed by Loday, Loday works with Reg White, Reg White designed the Shadow. Circle complete! <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
(Just realised that I should have posted the Shadow review in the Nacra A3 thread though).
Anyway, a Nacra 18m2 has just been put on sale overhere in Holland:
http://watersport.marktplaats.nl/catamarans/82930369-gemodificeerde-nacra-18m2-aangeboden.html
Re: nacra 18 sq in the uk? [Re: Tony_F18] #100659
03/18/07 03:28 PM
03/18/07 03:28 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Hey rictorn, this one looks to be bit of a bargain. 2 mains, 2 spinnies, snuffer and maybe a trailer for about £1500!
Perhaps TONY FX1 will translate the advert for you?
Re: nacra 18 sq in the uk? [Re: TEAMVMG] #100660
03/18/07 05:32 PM
03/18/07 05:32 PM
Translation:
This completely refurbished 18m2 is equiped with all modern sailinggear.
The boat is equiped with 2x pentax-mainsails, 2x 21m2 spinnakers (repaired),
2 trampolines, new snuffer, boom, and new shrouds.
Last winter the hulls have been have had a bottom job and made completely watertight by Hans Primowees (FYI: He's a well known cat repair guy).
The thread and bolts off the beams have also been replaced, the rudders and boards are original and in good condition.
On the pictures you see both sails, a white and a blue pentax sail.
A good boat with all the bits and pieces.
The boat sits on a good road trailer with sailbox for road-travel, for which it does need to be taken apart.
Option to trade for a 18-20 foot cat.
I even think it includes a road trailer, but I cant really make that out from the text.
Re: nacra 18 sq in the uk? [Re: Tony_F18] #100661
03/21/07 03:53 PM
03/21/07 03:53 PM
rictorn Offline OP
rictorn  Offline OP
hi this is all realy useful stuff thanks, money is an object so the neverlands one is out, inless somone wants to sail it over, i wouldn't care if it was class leagel, i just like the width and sail area, so anything similar is considered, i made a 10 foot wide unicorn about 80kg, with a tornado sport sail, while it lasted the f18's couldn't catch me even with the spinnakers up i matched their speed, unfortionatly the hulls were rotton so it only lasted a few mounths but it had to be as fast as any beach cat around so somthing lighter appeals but its the width i like any suggestions???
1 registered members (Damon Linkous), 2,406 guests, and 274 spiders.
