Carbon cloth(uni and biaxial) and hard foam sourci #113557
08/04/07 08:20 PM
08/04/07 08:20 PM
Gainesville, FL 32607 USA
dacarls Offline OP
dacarls  Offline OP
Carbon cloth (uni and biaxial) and hard foam sourcing? Where to get good material in the USA at a fair price?
In the Southern US, 3/16 inch 316 alloy S.S. pop rivets have become unavailable: now what? Source?
Dacarls:
Re: Carbon cloth(uni and biaxial) and hard foam sourci [Re: dacarls] #113558
08/04/07 09:22 PM
08/04/07 09:22 PM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Monel Pop Rivets. Again not usually available at your local hardware shop, but engineering supplies have them over here.
Regards
Re: Carbon cloth(uni and biaxial) and hard foam sourci [Re: mattaipan] #113559
08/05/07 12:46 PM
08/05/07 12:46 PM
dacarls Offline OP
dacarls  Offline OP
Monel is generally too hard for use with aluminum or fiberglass.
Dacarls:
Re: Carbon cloth(uni and biaxial) and hard foam sourci [Re: dacarls] #113560
08/05/07 03:14 PM
08/05/07 03:14 PM
Victoria, Oztralia
mattaipan Offline
mattaipan  Offline
Victoria, Oztralia
Hi dacarls
Monel is what a lot of riggers use over here, including Greg Goodall who put me on to them. I have just brought a heavy duty rivet gun, with handles like a swaging tool or bolt cutters, makes it alot easier and was about the same price as a quality regular hand rivetter, it was cheap, but its doin the job for the moment, when I went looking for one I expected to pay 2-3 times what I paid.
Regards
Re: Carbon cloth(uni and biaxial) and hard foam so [Re: dacarls] #113561
08/06/07 08:29 PM
08/06/07 08:29 PM
Fiberglass Supply in Bingen, WA tries to keep carbon in stock, though they can be out. I think they have foam, they supply the sailboard industry in the Gorge.
dave
Re: Carbon cloth(uni and biaxial) and hard foam so #113562
08/07/07 08:50 PM
08/07/07 08:50 PM
lesburn1 Offline
lesburn1  Offline
I get carbon fiber fron Soller Composites (603 934 10290),
peel-ply and sealant tape from Fiberglass Supply (509 493 3464) and mold wax and mold release from Sweet Composites.
Also if you want glass at a good price call www.thayercraft.com
I am in the process of building an A-Cat and am using their
Unidirectional 6.0 OZ cloth.
lesburn1.blogspot.com
A-Cat USA 49
18Sq 49
Re: Carbon cloth(uni and biaxial) and hard foam sourci [Re: dacarls] #113563
09/24/07 04:38 AM
09/24/07 04:38 AM
Central Coast NSW Australia
TonyJ Offline
TonyJ  Offline
Try here
Gurit (USA) Inc
Lauderdale Marine Center
2019 SW 20th Street
Suite 234
Fort Lauderdale
Florida (USA)
33315
T +1 954 423 9630
F +1 212 419 9498
Teach them how to think. Not what to think. Aus Blade 002
Re: Carbon cloth(uni and biaxial) and hard foam sourci [Re: dacarls] #113564
10/01/07 06:38 AM
10/01/07 06:38 AM
How can monel rivets be too hard to use when compared to stainless steel ones ?
SS ones take alot more force to pop, are harder to remove when damaged and induce galvaic corrosion sooner when used on aluminium.
Re: Carbon cloth(uni and biaxial) and hard foam sourci [Re: Wouter] #113565
11/22/07 12:22 PM
11/22/07 12:22 PM
Hollister CA, Plano TX
avalondarlyn Offline
for cloth and resins www.aircraftspruce.com for foam i use www.flyingfoam.com what the they call "spyder" foam is the hardest. bob will even cut it to exact specs on his cnc machine. I made a set of daggers for a viva 27, 8'4" tall. bob cut the cores. i used the knitted rutan unidirectional times about 10-15 layers.
Re: Carbon cloth(uni and biaxial) and hard foam so [Re: avalondarlyn] #113566
02/07/08 10:16 AM
02/07/08 10:16 AM
lesburn1 Offline
lesburn1  Offline
I have put a small howto on vacuum bagging and making spreaders and other small carbon parts on my blog site.
A-Cat USA 49
18Sq 49
Re: Carbon cloth(uni and biaxial) and hard foam so [Re: lesburn1] #113567
02/07/08 11:47 AM
02/07/08 11:47 AM
Looking forward to seeing how you do the part where the diamond wires pass over the spreaders!
Are there any aerodynamic advantages to "foil shaped" spreaders compared to regular tubes, in real life?
Re: Carbon cloth(uni and biaxial) and hard foam so [Re: Rolf_Nilsen] #113568
02/07/08 01:40 PM
02/07/08 01:40 PM
lesburn1 Offline
lesburn1  Offline
As for the diamond wires, a notch cut in the ends and then two holes for SS safety wire to hold the diamond stay in place. The tip of each spreader has a block of ebony, which is very hard stuff and this spreads the compression load out over the hole surface of the spreader.
I do not have any numbers to support this, but I don't know how an airfoil shape could not have "aerodynamic advantages" over a round tube.
A-Cat USA 49
18Sq 49
Re: Carbon cloth(uni and biaxial) and hard foam so [Re: lesburn1] #113569
02/07/08 01:43 PM
02/07/08 01:43 PM
Thank you, good idea with the ebony!
The question about the airfoil shape was how much it means in real life. The "standard" tubes are about as bad as it can be, but in the larger pictures, how much faster can it be..
Re: Carbon cloth(uni and biaxial) and hard foam so [Re: Rolf_Nilsen] #113570
02/07/08 01:59 PM
02/07/08 01:59 PM
lesburn1 Offline
lesburn1  Offline
When you weigh more then your boat every little bit helps.
I building an A-cat and hope to bring it in at 85KG and I am 195 cm and weigh over 100 KG.
A-Cat USA 49
18Sq 49
Re: Carbon cloth(uni and biaxial) and hard foam so [Re: lesburn1] #113571
02/07/08 02:04 PM
02/07/08 02:04 PM
Being 178cm and having just dropped below 100Kgs, I know what you mean <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
It all adds up of course, but I was curious becouse we have a Tornado alu mast with one broken spreader arm. Build a set of wings or buy a replacement part from Marstrøm..
Re: Carbon cloth(uni and biaxial) and hard foam so [Re: Rolf_Nilsen] #113572
02/07/08 02:28 PM
02/07/08 02:28 PM
Constanta, Romania
isvflorin Offline
isvflorin  Offline
Constanta, Romania
Build a set of wings, definitely. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
Florin
Re: Carbon cloth(uni and biaxial) and hard foam so [Re: isvflorin] #113573
04/09/08 09:44 AM
04/09/08 09:44 AM
lesburn1 Offline
lesburn1  Offline
For those home builders looking to find out how the "big boys" do it.
http://valenciasailing.blogspot.com/2008/04/bmw-oracle-progress-well-advanced-on.html
A-Cat USA 49
18Sq 49
0 registered members (), 21,527 guests, and 653 spiders.
Yesterday at 04:54 AM
