| Carbon cloth(uni and biaxial) and hard foam sourci #113557 08/04/07 08:20 PM 08/04/07 08:20 PM |
Joined: Apr 2002 Posts: 805 Gainesville, FL 32607 USA dacarls OP
Posts: 805 Gainesville, FL 32607 USA | Carbon cloth (uni and biaxial) and hard foam sourcing? Where to get good material in the USA at a fair price? In the Southern US, 3/16 inch 316 alloy S.S. pop rivets have become unavailable: now what? Source?
| | | Re: Carbon cloth(uni and biaxial) and hard foam sourci
[Re: dacarls]
#113558 08/04/07 09:22 PM 08/04/07 09:22 PM |
Posts: 461 Victoria, Oztralia | Monel Pop Rivets. Again not usually available at your local hardware shop, but engineering supplies have them over here.
Regards
Matt Harper
Homebuilt Taipan 4.9
[Re: mattaipan]
#113559 08/05/07 12:46 PM 08/05/07 12:46 PM |
Posts: 805 Gainesville, FL 32607 USA | Monel is generally too hard for use with aluminum or fiberglass.
[Re: dacarls]
#113560 08/05/07 03:14 PM 08/05/07 03:14 PM |
Posts: 461 Victoria, Oztralia | Hi dacarls
Monel is what a lot of riggers use over here, including Greg Goodall who put me on to them. I have just brought a heavy duty rivet gun, with handles like a swaging tool or bolt cutters, makes it alot easier and was about the same price as a quality regular hand rivetter, it was cheap, but its doin the job for the moment, when I went looking for one I expected to pay 2-3 times what I paid.
Regards
Matt Harper
[Re: dacarls]
#113561 08/06/07 08:29 PM 08/06/07 08:29 PM | Anonymous
| Anonymous
Unregistered | Fiberglass Supply in Bingen, WA tries to keep carbon in stock, though they can be out. I think they have foam, they supply the sailboard industry in the Gorge.
dave | | | Re: Carbon cloth(uni and biaxial) and hard foam so #113562 08/07/07 08:50 PM 08/07/07 08:50 PM |
Posts: 190 | I get carbon fiber fron Soller Composites (603 934 10290), peel-ply and sealant tape from Fiberglass Supply (509 493 3464) and mold wax and mold release from Sweet Composites. Also if you want glass at a good price call www.thayercraft.comI am in the process of building an A-Cat and am using their Unidirectional 6.0 OZ cloth.
lesburn1.blogspot.com
A-Cat USA 49 18Sq 49
[Re: dacarls]
#113563 09/24/07 04:38 AM 09/24/07 04:38 AM |
Joined: Dec 2003 Posts: 244 Central Coast NSW Australia TonyJ
Posts: 244 Central Coast NSW Australia | Try here
Gurit (USA) Inc Lauderdale Marine Center 2019 SW 20th Street Suite 234 Fort Lauderdale Florida (USA) 33315 T +1 954 423 9630 F +1 212 419 9498
Teach them how to think.
Not what to think.
Aus
Blade 002
[Re: dacarls]
#113564 10/01/07 06:38 AM 10/01/07 06:38 AM |
Posts: 9,582 North-West Europe | How can monel rivets be too hard to use when compared to stainless steel ones ?
SS ones take alot more force to pop, are harder to remove when damaged and induce galvaic corrosion sooner when used on aluminium.
[Re: avalondarlyn]
#113566 02/07/08 10:16 AM 02/07/08 10:16 AM |
Posts: 190 | I have put a small howto on vacuum bagging and making spreaders and other small carbon parts on my blog site.
[Re: Rolf_Nilsen]
#113568 02/07/08 01:40 PM 02/07/08 01:40 PM |
Posts: 190 | Looking forward to seeing how you do the part where the diamond wires pass over the spreaders! Are there any aerodynamic advantages to "foil shaped" spreaders compared to regular tubes, in real life? As for the diamond wires, a notch cut in the ends and then two holes for SS safety wire to hold the diamond stay in place. The tip of each spreader has a block of ebony, which is very hard stuff and this spreads the compression load out over the hole surface of the spreader. I do not have any numbers to support this, but I don't know how an airfoil shape could not have "aerodynamic advantages" over a round tube.
[Re: Rolf_Nilsen]
#113570 02/07/08 01:59 PM 02/07/08 01:59 PM |
Posts: 190 | When you weigh more then your boat every little bit helps. I building an A-cat and hope to bring it in at 85KG and I am 195 cm and weigh over 100 KG.
[Re: Rolf_Nilsen]
#113572 02/07/08 02:28 PM 02/07/08 02:28 PM |
Joined: Oct 2007 Posts: 199 Constanta, Romania isvflorin
Posts: 199 Constanta, Romania | Build a set of wings, definitely. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
Florin
19,774
guests, and 666
