Painted Finally #119553
10/08/07 03:12 AM
10/08/07 03:12 AM
Victoria, Oztralia
mattaipan Offline OP
Victoria, Oztralia
Hi All
My paint fella showed up and painted the twins today, reasonably happy with the result, will have to let it sit for a couple of days to cure properly, which isn't goin to be easy for me not to do anything to it. Must show self control.
Regards
Re: Painted Finally [Re: mattaipan] #119554
10/08/07 06:54 AM
10/08/07 06:54 AM
Matt,
It is looking good.
Re: Painted Finally [Re: phill] #119555
10/08/07 06:01 PM
10/08/07 06:01 PM
Central Coast NSW Australia
TonyJ Offline
TonyJ  Offline
I agree it looks great.
It proves that patience in the preperation pays off.
I will try to remember that.
Teach them how to think. Not what to think. Aus Blade 002
Re: Painted Finally [Re: TonyJ] #119556
10/09/07 04:24 AM
10/09/07 04:24 AM
Victoria, Oztralia
Victoria, Oztralia
Thanks Fellas
I'm not sure what the next step is, wet n dry (very fine) or just cut and polish or both? I guess I should wait til the weekend before trying anything though.
Any suggestions would be well recieved.
Regards
Re: Painted Finally [Re: mattaipan] #119557
10/09/07 06:03 PM
10/09/07 06:03 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Sweet!
What type of paint and base coats did you use? Did you apply clear coats and if so, how many?
Re: Painted Finally [Re: mattaipan] #119558
10/10/07 12:36 AM
10/10/07 12:36 AM
Matt,
If polyurethane it takes a bit of work to fine rub as it is very hard. But if you do you will see anything corser than 2,000 grit in the gloss. If really pushed you could do
1,000 as the scratches left are not too bad.
600 is easier but you pay fot it in drop in quality of the finish.
Takes about 16 hous to wet rub.
4 hours per side per hull in 2,000 grit.
I'd still buff with light cutting compound or polish with alight cut in it.
Stay away from the gunwales with both or you'll go through the paint quick smart.
Hope it helps.
Re: Painted Finally [Re: arbo06] #119559
10/10/07 02:47 AM
10/10/07 02:47 AM
Victoria, Oztralia
Victoria, Oztralia
Yep very happy with it.
As per Phills suggestion some time ago, (when I thought I was ready to paint) I have used Dulux Luxepoxy 4 White Primer in the end probably 3 coats with lots of wet sanding and Dulux Luxathane White, paint man tells me 4 coats, I wasn't really expecting that much but its come up pretty good, and he hadn't painted a boat before, so wasn't to know.
No clear coats I don't think its necessary, I think I'll leave it as is for the while, and see what happens over the next 6 months as to what course of action to take.
Regards
Re: Painted Finally [Re: mattaipan] #119560
10/26/07 04:55 PM
10/26/07 04:55 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Please tell me your finished hull weights (within a couple of pounds). Thanks.
Dacarls:
Re: Painted Finally [Re: dacarls] #119561
10/27/07 02:47 AM
10/27/07 02:47 AM
Victoria, Oztralia
Victoria, Oztralia
I'm not really concerned if I;m a bit under or a bit over, so I didn't actually weigh them again after painting, but prior to painting they were at 22kg, I've since beamed it up and the tramp arrived from goodalls on thursday, so thursday night it was on. I could probably give you a platform form weight in the near future, but not individual hulls.
If you can get the right materials and build carefully, which I did most of the time, I've no doubt they can be easily 22kg painted. If I build another theres a lot of things I've learnt along the way, which would ultimatly result in a better, stronger and lighter hull, but you have to start somewhere I guess.
Regards
Re: Painted Finally [Re: mattaipan] #119562
10/27/07 07:01 PM
10/27/07 07:01 PM
arbo06 Offline
arbo06  Offline
Hmm, I could not find a distributer of that product here in the US of A. I think I am going to go with an auto paint such as Sherwinn Williams as was applied by the builder.
Re: Painted Finally [Re: arbo06] #119563
10/27/07 09:07 PM
10/27/07 09:07 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Hey Matt will you be getting her wet this summer wouldn't mind a little trip to see the launch
regards
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Painted Finally [Re: JeffS] #119564
10/27/07 10:32 PM
10/27/07 10:32 PM
Victoria, Oztralia
Victoria, Oztralia
Surely will, was hoping for this coming weekend, Portland Regatta, but I think I'm working Saturday, so probably the week after unfortunatly.
Been working this morning finishing putting the mast together and hoping to find someone to help lift it outside I was going to try and stand it up and throw the sail up for a photo.
Will post it later if it happens.
Regards
Re: Painted Finally [Re: mattaipan] #119565
10/28/07 01:36 AM
10/28/07 01:36 AM
Victoria, Oztralia
Victoria, Oztralia
Beautiful day out, but blowin dogs off chains.
Heres a photo, I put the sail up for a couple of minutes and then down again as to not wreck anything. Couldn't attach boom as I'm making the gooseneck now.
Will be taking so more shortly before dropping the mast, but its been a long time coming and finally I can see the light at the end of the tunnel, it's a good feeling.
Regards
Re: Painted Finally [Re: mattaipan] #119566
10/28/07 07:25 AM
10/28/07 07:25 AM
JeffS Offline
JeffS  Offline
Shes looking good. What sort of turnout do they get at Portland, I havn't seen anything advertised and thats less than 3 hours from here
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Painted Finally [Re: JeffS] #119567
10/28/07 07:44 AM
10/28/07 07:44 AM
JeffS Offline
JeffS  Offline
Thats really funny I post the previous post and then see the next post youve got some details on Portland, Its a bit short notice but I might see if any in the club will consider it . Is it just Taipans or do they have juniors my trailer can two up a 420 above the cat for the kids
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Painted Finally [Re: JeffS] #119568
10/28/07 01:57 PM
10/28/07 01:57 PM
Victoria, Oztralia
Victoria, Oztralia
Hi Jeff
All classes and divisions, from junior to keel boat caterer for. The Taipans are strongest at Portland, there will be 5-6 this year, including myself, as I'm joining their this year (about 2 hours for me).
Its possible another junior 420 would be there, theres one at Warrnambool that would likely attend.
It is part of the Taipan traveller series as well, so that could see quite a few attend.
Re: Painted Finally [Re: mattaipan] #119569
10/28/07 05:22 PM
10/28/07 05:22 PM
JeffS Offline
JeffS  Offline
I looked up Portland on the internet after I posted last night and it looks like they don't have any Stingrays but do have A's, its looking like it will be doubtful to get to this weekend racing but with enough notice we might be able to get our five A's down for a roadtrip next time. I noticed 420's weren't listed but it wouldn't worry my kids sailing with other juniors in different classes. As an early invitation to your club our Lobster regatta where we do a series of races on the Saturday then a morning Run about 15km from Cape Jaffa to Kingston on Sunday morning is 12th and 13th January all classes welcome and juniors encouraged.
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Painted Finally [Re: JeffS] #119570
10/29/07 04:25 AM
10/29/07 04:25 AM
Victoria, Oztralia
Victoria, Oztralia
Hi Jeff
No A's anymore, there is a couple at Warrnambool that would likely attend the regatta. Taipan is the main cat class, and really now days the only cat class. Once there were Hobie 18's, Mosquitos, A Class and Taipans. And the Taipan took over.
Re: Painted Finally [Re: mattaipan] #119571
10/29/07 06:05 AM
10/29/07 06:05 AM
JeffS Offline
JeffS  Offline
Oh well I may just bring the Stingray to bring some stately dignity to the club then my daughter gets to crew wont be this week though. Looks like Berny may let me use his F14 moulds, at the speed you build boats you probably want first use of them to build a boat for your little tacker in the soon to be clear shed space you'll have <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />.
regards
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Painted Finally [Re: JeffS] #119572
10/29/07 06:14 AM
10/29/07 06:14 AM
Victoria, Oztralia
Victoria, Oztralia
Won't be much space when this ones out, next project already brewing.
