Converting pinhead to squaretop ... #13365
11/20/02 05:49 PM
11/20/02 05:49 PM
Lake Charles, Louisiana, USA
dsarge Offline OP
dsarge  Offline OP
Hi all,
Is it possible (without buying a new sail) to convert a pinhead to squaretop. I have a hobie 16 mainsail that I was contemplating cutting above the 2nd batten from the top.
Will this work?
David
Re: Converting pinhead to squaretop ... [Re: dsarge] #13366
11/20/02 06:18 PM
11/20/02 06:18 PM
Andrew Offline
Andrew  Offline
Cutting to make a sail for what? But to answer your question: Yes, it is possible to convert a sail to squaretop. I had Randy Smyth quote me to square the top of a new Nacra 5.O sait (which I had acquired elsewhere.) I didn't do it at the time, but I would now if I still owned the boat.
sail fast
Re: Converting pinhead to squaretop ... [Re: dsarge] #13367
11/20/02 06:32 PM
11/20/02 06:32 PM
Tampa, FL
dave taylor Offline
dave taylor  Offline
Tampa, FL
i don't think you can simply cut off the top of the sail to make a squaretop sail. although the shape may be right, the sail would be too short. i'm not a sailmaker, but i think you would need to add a panel to the bottom or middle of the sail.
Re: Converting pinhead to squaretop ... [Re: Andrew] #13368
11/20/02 08:06 PM
11/20/02 08:06 PM
dsarge Offline OP
dsarge  Offline OP
I've cut a H16 mast to 21' for a 20' catamaran I built. The sail would fit without adding panels.
Thanks
David
Re: Converting pinhead to squaretop ... [Re: dsarge] #13369
11/20/02 11:39 PM
11/20/02 11:39 PM
jcasto1 Offline
jcasto1  Offline
If you just cut off top of sail, you may not have tension in the right parts of the sail for the top "square" piece to stand out. You may either need to add a batten on a diagonal, ending at the outer tip of the square top.
I think you should look at some photos of square top mains, or consult a sailmaker, before you just cut off 2 panels.
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
0 registered members (), 618 guests, and 65 spiders.
