| Re: Converting pinhead to squaretop ...
[Re: dsarge]
#13366 11/20/02 06:18 PM 11/20/02 06:18 PM |
Posts: 364 | Cutting to make a sail for what? But to answer your question: Yes, it is possible to convert a sail to squaretop. I had Randy Smyth quote me to square the top of a new Nacra 5.O sait (which I had acquired elsewhere.) I didn't do it at the time, but I would now if I still owned the boat. sail fast
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
[Re: dsarge]
#13369 11/20/02 11:39 PM 11/20/02 11:39 PM |
Posts: 217 | If you just cut off top of sail, you may not have tension in the right parts of the sail for the top "square" piece to stand out. You may either need to add a batten on a diagonal, ending at the outer tip of the square top. I think you should look at some photos of square top mains, or consult a sailmaker, before you just cut off 2 panels.
251
guests, and 100
Mod | | Forums26 Topics22,405 Posts267,056 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
