| Re: roller furling question
[Re: DangerMouse]
#149923 07/22/08 09:57 PM 07/22/08 09:57 PM | Anonymous
| Anonymous
Unregistered | Your untrained eye is semi-correct ... The tracks act as a travler to move your jib in and out on the beam... but this only is good if your boat and jib was designed for that.
the barberhauler is an outhaul that pulls your jib out towards the outer limits of the beam/hull. HOWEVER this is desirable (mostly) downwind when you want to make a FULL (round) sail shape on your jib. If you sail by your tell-tales (as you should IMHO) you will see downwind your jib needs to be full and upwind flat... (generally speaking)
If you outhaul (with a barber hauler) when going upwind you will have a miss shaped jib (as mentioned above you will be pulling from to much of the leach and not enough foot of the sail).
I think (IMHO) you should install the bungie (higher than the turnbuckles) for $2, tape up the turnbuckles with electical tape $.50 (or rigging tape) and learn how to work with the jib (i used to have to shake my Hobie16 jib every now and again while sailing).
If you feel like you want more items to adjust and want to tinker with jib shape, then install a barber hauler.
It is not a huge advantage in either handling your jib/hangup problems because it is mainly for downwind sailing... and creates a little more work (and deck clutter) to cleat and uncleat when you tack....
if you do put your rudders in a bag/on your tramp... you may want to wrap them up individually because when your trailer jumps over potholes and other bumps they will bang against eachother they can scrape, scratch, bend, ding and just break off each other. Deep scratches can cause water to get in the rudder, swell, and split the rudders. So just be sure to secure them, and protect them and you should be fine!
OR you could put your baby in the bag on the tramp.. that should give you room in your car for the rudders (kidding)
But most of all. just have fun!
[Re: DangerMouse]
#149925 07/22/08 10:16 PM 07/22/08 10:16 PM | Anonymous
| Anonymous
Unregistered | LOL, i don't have a sailing newsletter (although i do publish 2 health ones for work) but i do have LOTS of sailing pics you can see at http://www.metalfree.com/a/CAT | | | Re: roller furling question
[Re: DangerMouse]
#149927 07/24/08 07:58 AM 07/24/08 07:58 AM | Anonymous
| Anonymous
Unregistered | ummmmm.... try the decaf! | | | Re: roller furling question
[Re: DangerMouse]
#149929 07/24/08 09:26 AM 07/24/08 09:26 AM | Anonymous
| Anonymous
Unregistered | Rick White's "CAT RACING: FOR THE 90S" is for sale in the Store here (link above)
This book covers all these topics.
Price $29.95
(PS this is Rick's website) <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
To summarize the difference for the barber hauler and the front beam travler (tracks): The barber hauler is an OUThaul used for getting a rounder shape in your jib for down wind sailing. It does this by pulling the jib tack (where the sheets attach) out and forward to the beam.
The travler (track) that comes on a (very) few boats does not shape the sail (generally), it simply moves the jib in (closer to the mainsail) for upwind and out for downwind.
Hold your right hand fingers tips in place (with your other hand) and cup your hand and look at the shape.. it is rounder because the middle has moved out and the back of your hand (under your thumb) has moved in. Now keep your finger tips in place and simply slide the back of your hand to the right. It doesnt change the shape of your hand, just the angle.... this is the same as the travler on a beam... doesnt really change the shape, just the angle.
The fromt beam track is for boats with jibs designed (shorter foot) to be set (secured) at the beam... most cats have a jib cut that requires it to be further back on the boat to have the correct/desired shapes.
[Re: DangerMouse]
#149930 07/24/08 09:29 AM 07/24/08 09:29 AM |
Posts: 35 | The Art and Science of Sails by Tom Whidden has more than you want to know. This website has the basic trimming guide. http://www.ukhalsey.com/LearningCenter/encyclopedia/encyclopedia5b.aspEverybody has been telling you the right things, but in pieces. Put two sets of telltales on your jib, one set high, one set low about 1/3 and 2/3s up. If your fore and aft position of the jib block is correct for upwind sailing, both sets of telltales will luff at the same time. Move the jib block forward a little and the sheet will pull more down than aft than before and tension the leech a little more than the foot. This will pull in the top of the sail more than the bottom and the top leeward telltale will show that the top of the sail is stalled (sheeted in too tight) relative to the bottom of the sail. On your boat moving the jib block all the way forward to the front crossbeam will be much worse. A boat with the jib block on the front crossbeam has a sail sized and cut such that the angle of the jib sheet is proper to that point. Yours is not. Now turn a little downwind from the close hauled course we've been sailing and sheet out the jib a little. As soon as you sheet out a little, since there is more tension in the leech than the foot, the clew will rise and the top of the sail will be luffing relative to the bottom, so you will need to move the jib block forward if you want to keep perfect trim. As you sail a lower course the block will have to move forward and outboard to keep the entire sail from top to bottom trimmed correctly at the same time. For your best point of sail to go downwind, approximately a beam reach apparent wind, the sheet point is around the outer end of the crossbeam. So a barberhaul to effectively move your sheet point there is for sailing downwind. John | | |
408
guests, and 20
