mast rake rigging on hc16 #150437
07/25/08 05:21 AM
07/25/08 05:21 AM
amottironi Offline OP
i'm assembling the mast raking system on a hobie 16, does anyone know how much is the workload of the cheek block at the mast base? i was thinking of using a harken bullet cheek block code h092. Even if i noticed than some hc16 use an unknown cheek, must be hobie cat made.
Re: mast rake rigging on hc16 [Re: amottironi] #150438
07/25/08 09:41 AM
07/25/08 09:41 AM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
The stock HC16 mast-mounted cheek blocks are unreliable, as the plastic wheel invariably breaks after 25 years of use. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Dacarls:
Re: mast rake rigging on hc16 [Re: amottironi] #150439
07/25/08 09:57 AM
07/25/08 09:57 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
The standard block is a Ronstan item but the Harken 092 works fine and is class legal.
You should be able to get either one at West or any decent rigger.
Like Dave says, you probably need to replace it every 20 or so years. At 25 it will be a goner!
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: mast rake rigging on hc16 [Re: amottironi] #150440
07/25/08 03:17 PM
07/25/08 03:17 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Mast raking system??
Is the mast adjustable while in flight?
Any photos of such a system??
Re: mast rake rigging on hc16 [Re: warbird] #150441
07/25/08 04:07 PM
07/25/08 04:07 PM
claus Offline
claus  Offline
No problems with load (4:1 or 3:1 on the jib halyard), any cheek block will do.
Re: mast rake rigging on hc16 [Re: warbird] #150442
07/25/08 06:19 PM
07/25/08 06:19 PM
Class legal adjustable jib halyard system:
Re: mast rake rigging on hc16 [Re: mbounds] #150443
07/25/08 06:23 PM
07/25/08 06:23 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
Re: mast rake rigging on hc16 [Re: claus] #150444
07/26/08 06:06 AM
07/26/08 06:06 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
I am not understanding. The photo shown does not depict a reduction unit with any gain in purchase, it just tracks to make the effort go with body weight.
So, this is nothing to do with mast rake, just jib tension or is the mast loose like on a Windrush 14 and the mast can be bent forward by putting pressure on the bridle ring but in the case the jib pulley?
Re: mast rake rigging on hc16 [Re: warbird] #150445
07/26/08 08:36 AM
07/26/08 08:36 AM
thanks everyone, ciao
Re: mast rake rigging on hc16 [Re: mbounds] #150446
07/26/08 08:52 AM
07/26/08 08:52 AM
dacarls Offline
dacarls  Offline
Wow- AND a 6:1 downhaul on the main!
When did that become class legal?
Dacarls:
Re: mast rake rigging on hc16 [Re: dacarls] #150447
07/26/08 03:54 PM
07/26/08 03:54 PM
2004
Re: mast rake rigging on hc16 [Re: warbird] #150448
07/26/08 03:59 PM
07/26/08 03:59 PM
The 3:1 purchase is at the head of the sail, therefore the tension on the line shown in the photo is 1/3 of the tension on the jib.
No, this has everything to do with mast rake. On a Hobie 16, the wire sewn into the jib luff is the forestay when the jib is hoisted. The amount of jib halyard tension controls the amount of mast rake.
0 registered members (), 446 guests, and 324 spiders.
