| Re: mast rake rigging on hc16
[Re: amottironi]
#150438 07/25/08 09:41 AM 07/25/08 09:41 AM |
Posts: 805 Gainesville, FL 32607 USA | The stock HC16 mast-mounted cheek blocks are unreliable, as the plastic wheel invariably breaks after 25 years of use. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
[Re: amottironi]
#150439 07/25/08 09:57 AM 07/25/08 09:57 AM |
Posts: 921 Alachua, FL | i was thinking of using a harken bullet cheek block code h092. Even if i noticed than some hc16 use an unknown cheek, must be hobie cat made. The standard block is a Ronstan item but the Harken 092 works fine and is class legal. You should be able to get either one at West or any decent rigger. Like Dave says, you probably need to replace it every 20 or so years. At 25 it will be a goner!
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: mast rake rigging on hc16
[Re: amottironi]
#150440 07/25/08 03:17 PM 07/25/08 03:17 PM |
Joined: Jul 2006 Posts: 1,147 Bay of Islands, NZ warbird
Posts: 1,147 Bay of Islands, NZ | i'm assembling the mast raking system on a hobie 16, does anyone know how much is the workload of the cheek block at the mast base? i was thinking of using a harken bullet cheek block code h092. Even if i noticed than some hc16 use an unknown cheek, must be hobie cat made. Mast raking system?? Is the mast adjustable while in flight? Any photos of such a system?? | | | Re: mast rake rigging on hc16
[Re: warbird]
#150441 07/25/08 04:07 PM 07/25/08 04:07 PM |
Posts: 160 | No problems with load (4:1 or 3:1 on the jib halyard), any cheek block will do.
[Re: warbird]
#150442 07/25/08 06:19 PM 07/25/08 06:19 PM |
Posts: 1,884 Detroit, MI | i'm assembling the mast raking system on a hobie 16, does anyone know how much is the workload of the cheek block at the mast base? i was thinking of using a harken bullet cheek block code h092. Even if i noticed than some hc16 use an unknown cheek, must be hobie cat made. Mast raking system?? Is the mast adjustable while in flight? Any photos of such a system?? Class legal adjustable jib halyard system: ![[Linked Image]](http://www.catsailor.com/gallery/albums/userpics/10063/normal_DSCF1602sized.JPG) | | | Re: mast rake rigging on hc16
[Re: claus]
#150444 07/26/08 06:06 AM 07/26/08 06:06 AM |
Posts: 1,147 Bay of Islands, NZ | No problems with load (4:1 or 3:1 on the jib halyard), any cheek block will do. I am not understanding. The photo shown does not depict a reduction unit with any gain in purchase, it just tracks to make the effort go with body weight. So, this is nothing to do with mast rake, just jib tension or is the mast loose like on a Windrush 14 and the mast can be bent forward by putting pressure on the bridle ring but in the case the jib pulley? | | | Re: mast rake rigging on hc16
[Re: warbird]
#150445 07/26/08 08:36 AM 07/26/08 08:36 AM |
Posts: 3 | | | | Re: mast rake rigging on hc16
[Re: mbounds]
#150446 07/26/08 08:52 AM 07/26/08 08:52 AM |
Posts: 805 Gainesville, FL 32607 USA | Wow- AND a 6:1 downhaul on the main! When did that become class legal?
[Re: dacarls]
#150447 07/26/08 03:54 PM 07/26/08 03:54 PM |
Posts: 1,884 Detroit, MI | Wow- AND a 6:1 downhaul on the main! When did that become class legal? 2004 | | | Re: mast rake rigging on hc16
[Re: warbird]
#150448 07/26/08 03:59 PM 07/26/08 03:59 PM |
Posts: 1,884 Detroit, MI | I am not understanding. The photo shown does not depict a reduction unit with any gain in purchase, it just tracks to make the effort go with body weight. The 3:1 purchase is at the head of the sail, therefore the tension on the line shown in the photo is 1/3 of the tension on the jib. So, this is nothing to do with mast rake, just jib tension or is the mast loose like on a Windrush 14 and the mast can be bent forward by putting pressure on the bridle ring but in the case the jib pulley? No, this has everything to do with mast rake. On a Hobie 16, the wire sewn into the jib luff is the forestay when the jib is hoisted. The amount of jib halyard tension controls the amount of mast rake. | | |
551
guests, and 303
