| Suggestion for Upgrading Tiller Extension? #151197 08/01/08 04:22 AM 08/01/08 04:22 AM |
Posts: 36 World Citizen | Standard Telescopic Tiller Extension that comes with most F18s I don't like very much due to glitches etc. I've seen some upgrades to Big T systems but don't know where to get them or if alternatives exist. Suggestions?
JFR Infusion Mk2
| | | Re: Suggestion for Upgrading Tiller Extension?
[Re: bvining]
#151199 08/03/08 03:02 AM 08/03/08 03:02 AM |
Joined: Oct 2006 Posts: 119 Bernhards Bay, N.Y. popeyez7
Posts: 119 Bernhards Bay, N.Y. | I used PVC pipe on my 17 & 18... use Gorrila tape. Been on for 3 yrs. now
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION'' ~17,18 Hobies, ~Jet boat~Speedster 150 ~2 Kayaks~ ~~~~VIETNAM VET. 69-71~~~~
[Re: Tornado_ALIVE]
#151202 08/03/08 03:58 AM 08/03/08 03:58 AM |
Posts: 1,669 Melbourne, Australia | And my favorite, from CST. http://www.cstcomposites.com/tiller_extensions.htmTILLER EXTENSIONS CST Tiller Extensions combine the properties and appearance of carbon fibres, aramid fibres and heat cured epoxy to produce what we think is the best tiller extension yet for dinghies like the 49er, laser... the list goes on. We couldn't see the point of having a tiny tube with added padding - we've made ours 22mm untapered so it's easier to grip. Also the fibres aren't unidirectional -by orienting fibres off axis we've engineered a little bit of bend and improved the durability. The final layer is an open weave spiral helix in aramid (Kevlar) fibre which further improves damage tolerance and grip. It also aids to keep the extension in one piece even if the carbon fibres are broken. This could be the difference between a finish and a DNF... Suitable for Optimist, Cadet. MJ, Sabot, Flying ant, Laser, Finn, 470, 420, NS14, I14, B14, 49er, Hobie, A-Class Cat, 18' Skiff, and more.... ![[Linked Image]](http://www.cstcomposites.com/images/Hibrid_Close_1.jpg) Construction: Carbon and Aramid fibres in heat cured epoxy matrix. Production Method: Computer controlled filament winding. The tiller extensions below are supplied with end cap and fitted polyurethane universal unless otherwise stated. ![[Linked Image]](http://www.cstcomposites.com/images/DCP_3867.JPG) | | | Re: Suggestion for Upgrading Tiller Extension?
[Re: Tornado_ALIVE]
#151203 08/03/08 06:59 AM 08/03/08 06:59 AM |
Posts: 921 Alachua, FL | Absolutely CST! 5 days before the Mug Race I realized I somehow didn't get a tiller extension with the H20 I bought off Ebay and so I called around for one. The short of it is that I found a reference to CST and emailed them. They are is Austrailia of course. The lady there called me right away. We had one DHL'd in and amazingly it arrived just in time and it is the best I've ever had. Nothing fancy...no telescoping...just light and has a nice feel.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Suggestion for Upgrading Tiller Extension?
[Re: bvining]
#151204 08/03/08 08:34 AM 08/03/08 08:34 AM |
Posts: 12,310 South Carolina | Solid piece of aluminum works great. 1/2 aluminum tube is $4/foot, usually lasts a couple of seasons before its bent enought to need replacing.
Much lighter, cheaper, and the telescoping action works like a charm. Wow, you can get an 8' stick of 3/4" .065 wall aluminum tubing for a little over $10 at McMaster Carr (plus shipping). I think this is the route I'm going...I can have eight of them for the price of a simple carbon one.
Jake Kohl | | | Re: Suggestion for Upgrading Tiller Extension?
#151205 08/03/08 08:40 AM 08/03/08 08:40 AM |
I agree that the aluminum stick makes the most practical sense Jake. I also believe that you have the ability to make a really trick stick out of carbon in your own workshop.
[Re: Mugrace72]
#151206 08/03/08 08:58 AM 08/03/08 08:58 AM |
I agree that the aluminum stick makes the most practical sense Jake. I also believe that you have the ability to make a really trick stick out of carbon in your own workshop. Yeah, maybe...getting it off the mandrel without an elevated heat cure could be tricky though. I've got a great vacuum setup but no oven. The carbon stick I have with my A-cat has had several repairs done to it (and not all too well). I have the original aluminum tiller that actually weighs less than the carbon one.
#151207 08/03/08 09:12 PM 08/03/08 09:12 PM |
Posts: 805 Gainesville, FL 32607 USA | Half-inch Aluminum tubing will last a long time. Mine got pretty bent in A-cat learning wrecks. It is still being used 5 years later by the new owner. It is soft enough to take the bending/straightening abuse. I also got 2 nice gold-anodized aluminum shuffleboard sticks at a junk-yard/recycler for $5 each: perfect! Very light, strong, straight and unbroken after my nice carbon stick has been broken 2 times. #2 is a spare. I smear a little Marine Goop on it once a year for "sticky hands".
[Re: dacarls]
#151208 08/03/08 09:47 PM 08/03/08 09:47 PM |
Joined: Sep 2007 Posts: 224 Cincinnati, Ohio Tri_X_Troll
Posts: 224 Cincinnati, Ohio | My Paint-Stick-Pro gets the job done. You can't see it, but it has a snappy plasic handle on the end. $14 for the telescoping model 50" to 85" $8 for a fixed length. ![[Linked Image]](http://i19.photobucket.com/albums/b161/Tri_X_Troll/Boat/DSC01864.jpg) ![[Linked Image]](http://i19.photobucket.com/albums/b161/Tri_X_Troll/Boat/DSC01865.jpg)
[Re: Tri_X_Troll]
#151209 08/04/08 07:54 AM 08/04/08 07:54 AM |
Posts: 1,884 Detroit, MI | Not that it applies to anybody in this thread (except maybe Jack), but if you plan to race Hobies, electrical conducting tiller extensions are prohibited. No aluminum or carbon fiber allowed. 11. TILLER ASSEMBLIES 11.1 The tiller extension may be either an extendable or non-extendable design but shall be a single tiller with one end connected to the crossbar in the same location as the factory supplied tiller. THE TILLER EXTENSION SHALL BE MADE OF A NONELECTRICAL CONDUCTIVE MATERIAL ON ALL NORTH AMERICAN REGION BOATS. NONELECTRICAL CONDUCTIVE TILLER EXTENSIONS ARE RECOMMENDED ON ALL BOATS WORLDWIDE. I've always used the stock tiller (non-extendable fiberglass) on the 14, 16 and 17. Most of the other racers do too. | | | Re: Suggestion for Upgrading Tiller Extension?
[Re: mbounds]
#151210 08/04/08 08:17 AM 08/04/08 08:17 AM |
Posts: 921 Alachua, FL | Not that it applies to anybody in this thread (except maybe Jack), but if you plan to race Hobies, electrical conducting tiller extensions are prohibited. No aluminum or carbon fiber allowed. Hey Matt, Since I only use the 20 for distance racing, it doesn't really matter, but I tested my carbon core CST extension and it does not conduct electricity. As you probably know, they are heavily coated with epoxy. Without grinding away the epoxy outer skin, i don't think it should be considered a conductor and hence, not class legal however. The rule does not say "no carbon fiber". I would say that aluminum sticks definately wouldn't pass the intent of the rule, which I understand and support.
[Re: Mugrace72]
#151211 08/04/08 08:47 AM 08/04/08 08:47 AM |
Posts: 1,884 Detroit, MI | Hey Matt,
Since I only use the 20 for distance racing, it doesn't really matter, but I tested my carbon core CST extension and it does not conduct electricity. As you probably know, they are heavily coated with epoxy. Without grinding away the epoxy outer skin, i don't think it should be considered a conducter and hence, not class legal however.
I would say that aluminum sticks definately wouldn't pass the intent of the rule, which I understand and support. [/quote]
You are correct - the rule doesn't say "no carbon fiber". When the rule went into effect (late 70's as I recall), carbon fiber was still rediculously expensive and nobody ever thought if would be used for something as frivolous as a tiller extension.
There isn't a standard conductivity test for the tiller extensions, nor is there a prohibited material list. It's something the IHCA Rules Committee should consider. | | | Re: Suggestion for Upgrading Tiller Extension?
[Re: mbounds]
#151212 08/04/08 09:05 AM 08/04/08 09:05 AM |
Posts: 921 Alachua, FL | Matt,
Perhaps you can shed some wisdom on the whole issue of non-conducting tiller extensions. This has probably been hashed over to nausium in the past.
Comptip masts are one thing, but how does a tiller extension become a target when you are sitting on a metal frame (14, 16) or completely insulated from the mast support network when sitting in the normal helm positon?
What situation would you be worried about by having a metal tiller extension in your hand?
Hard to imagine running into a powerline while trapped....but?
[Re: mmadge]
#151215 08/04/08 11:16 AM 08/04/08 11:16 AM |
Posts: 921 Alachua, FL | Mugrace what did they charge you to have that shipped (the CST one).I also looked at there,s and it is really popular on skiffs and catamarans in Australia(some of the guys were using them at the hobie 16 worlds)but the shipping costs were very high. It was way too much...but I panicked and had DHL priority do it since I just really, really, really wanted the stick! Just one of those unexplained moments. The way to get one is to get a bunch...like 10 or 20 shipped at once, without a priority.
14,959
guests, and 1,083
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online22,490 5 hours ago | | |
