Suggestion for Upgrading Tiller Extension? #151197
08/01/08 04:22 AM
08/01/08 04:22 AM
World Citizen
JFR Offline OP
JFR  Offline OP
World Citizen
Standard Telescopic Tiller Extension that comes with most F18s I don't like very much due to glitches etc. I've seen some upgrades to Big T systems but don't know where to get them or if alternatives exist. Suggestions?
JFR
Infusion Mk2
Re: Suggestion for Upgrading Tiller Extension? [Re: JFR] #151198
08/01/08 05:23 AM
08/01/08 05:23 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Solid piece of aluminum works great. 1/2 aluminum tube is $4/foot, usually lasts a couple of seasons before its bent enought to need replacing.
Much lighter, cheaper, and the telescoping action works like a charm.
Re: Suggestion for Upgrading Tiller Extension? [Re: bvining] #151199
08/03/08 03:02 AM
08/03/08 03:02 AM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
I used PVC pipe on my 17 & 18... use Gorrila tape. Been on for 3 yrs. now
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION''
~17,18 Hobies,
~Jet boat~Speedster 150
~2 Kayaks~
~~~~VIETNAM VET. 69-71~~~~
Re: Suggestion for Upgrading Tiller Extension? [Re: popeyez7] #151200
08/03/08 03:51 AM
08/03/08 03:51 AM
Tornado_ALIVE Offline
Ronstan have telescopic and non telescopic
I have never been a fan of any telescopic extensions
non telescopic - http://www.ronstan.com.au/marine/product.asp?ProdNo=RF3137&admin=admin
telescopic - http://www.ronstan.com.au/marine/product.asp?ProdNo=RF3124&admin=admin
Re: Suggestion for Upgrading Tiller Extension? [Re: Tornado_ALIVE] #151201
08/03/08 03:53 AM
08/03/08 03:53 AM
Marstrom telescopic
type in tiller in the search bar - http://shop.marstrom.com/
Re: Suggestion for Upgrading Tiller Extension? [Re: Tornado_ALIVE] #151202
08/03/08 03:58 AM
08/03/08 03:58 AM
And my favorite, from CST.
http://www.cstcomposites.com/tiller_extensions.htm
TILLER EXTENSIONS
CST Tiller Extensions combine the properties and appearance of carbon fibres, aramid fibres and heat cured epoxy to produce what we think is the best tiller extension yet for dinghies like the 49er, laser... the list goes on.
We couldn't see the point of having a tiny tube with added padding - we've made ours 22mm untapered so it's easier to grip. Also the fibres aren't unidirectional -by orienting fibres off axis we've engineered a little bit of bend and improved the durability. The final layer is an open weave spiral helix in aramid (Kevlar) fibre which further improves damage tolerance and grip. It also aids to keep the extension in one piece even if the carbon fibres are broken. This could be the difference between a finish and a DNF...
Suitable for Optimist, Cadet. MJ, Sabot, Flying ant, Laser, Finn, 470, 420, NS14, I14, B14, 49er, Hobie, A-Class Cat, 18' Skiff, and more....
Construction: Carbon and Aramid fibres in heat cured epoxy matrix.
Production Method: Computer controlled filament winding.
The tiller extensions below are supplied with end cap and fitted polyurethane universal unless otherwise stated.
Re: Suggestion for Upgrading Tiller Extension? [Re: Tornado_ALIVE] #151203
08/03/08 06:59 AM
08/03/08 06:59 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Absolutely CST!
5 days before the Mug Race I realized I somehow didn't get a tiller extension with the H20 I bought off Ebay and so I called around for one. The short of it is that I found a reference to CST and emailed them. They are is Austrailia of course. The lady there called me right away.
We had one DHL'd in and amazingly it arrived just in time and it is the best I've ever had.
Nothing fancy...no telescoping...just light and has a nice feel.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: Suggestion for Upgrading Tiller Extension? [Re: bvining] #151204
08/03/08 08:34 AM
08/03/08 08:34 AM
Wow, you can get an 8' stick of 3/4" .065 wall aluminum tubing for a little over $10 at McMaster Carr (plus shipping). I think this is the route I'm going...I can have eight of them for the price of a simple carbon one.
Re: Suggestion for Upgrading Tiller Extension? [Re: Jake] #151205
08/03/08 08:40 AM
08/03/08 08:40 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
I agree that the aluminum stick makes the most practical sense Jake.
I also believe that you have the ability to make a really trick stick out of carbon in your own workshop.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Suggestion for Upgrading Tiller Extension? [Re: Mugrace72] #151206
08/03/08 08:58 AM
08/03/08 08:58 AM
Yeah, maybe...getting it off the mandrel without an elevated heat cure could be tricky though. I've got a great vacuum setup but no oven. The carbon stick I have with my A-cat has had several repairs done to it (and not all too well). I have the original aluminum tiller that actually weighs less than the carbon one.
Re: Suggestion for Upgrading Tiller Extension? [Re: Jake] #151207
08/03/08 09:12 PM
08/03/08 09:12 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Half-inch Aluminum tubing will last a long time. Mine got pretty bent in A-cat learning wrecks. It is still being used 5 years later by the new owner. It is soft enough to take the bending/straightening abuse.
I also got 2 nice gold-anodized aluminum shuffleboard sticks at a junk-yard/recycler for $5 each: perfect! Very light, strong, straight and unbroken after my nice carbon stick has been broken 2 times. #2 is a spare. I smear a little Marine Goop on it once a year for "sticky hands".
Dacarls:
Re: Suggestion for Upgrading Tiller Extension? [Re: dacarls] #151208
08/03/08 09:47 PM
08/03/08 09:47 PM
Cincinnati, Ohio
Tri_X_Troll Offline
Tri_X_Troll  Offline
Cincinnati, Ohio
My Paint-Stick-Pro gets the job done. You can't see it, but it has a snappy plasic handle on the end.
$14 for the telescoping model 50" to 85"
$8 for a fixed length.
Re: Suggestion for Upgrading Tiller Extension? [Re: Tri_X_Troll] #151209
08/04/08 07:54 AM
08/04/08 07:54 AM
Not that it applies to anybody in this thread (except maybe Jack), but if you plan to race Hobies, electrical conducting tiller extensions are prohibited. No aluminum or carbon fiber allowed.
11. TILLER ASSEMBLIES
11.1 The tiller extension may be either an extendable
or non-extendable design but shall be a single
tiller with one end connected to the crossbar in
the same location as the factory supplied tiller.
THE TILLER EXTENSION SHALL BE MADE
OF A NONELECTRICAL CONDUCTIVE MATERIAL
ON ALL NORTH AMERICAN REGION
BOATS. NONELECTRICAL CONDUCTIVE
TILLER EXTENSIONS ARE RECOMMENDED
ON ALL BOATS WORLDWIDE.
I've always used the stock tiller (non-extendable fiberglass) on the 14, 16 and 17. Most of the other racers do too.
Re: Suggestion for Upgrading Tiller Extension? [Re: mbounds] #151210
08/04/08 08:17 AM
08/04/08 08:17 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Hey Matt,
Since I only use the 20 for distance racing, it doesn't really matter, but I tested my carbon core CST extension and it does not conduct electricity. As you probably know, they are heavily coated with epoxy. Without grinding away the epoxy outer skin, i don't think it should be considered a conductor and hence, not class legal however.
The rule does not say "no carbon fiber".
I would say that aluminum sticks definately wouldn't pass the intent of the rule, which I understand and support.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Suggestion for Upgrading Tiller Extension? [Re: Mugrace72] #151211
08/04/08 08:47 AM
08/04/08 08:47 AM
Hey Matt,
Since I only use the 20 for distance racing, it doesn't really matter, but I tested my carbon core CST extension and it does not conduct electricity. As you probably know, they are heavily coated with epoxy. Without grinding away the epoxy outer skin, i don't think it should be considered a conducter and hence, not class legal however.
I would say that aluminum sticks definately wouldn't pass the intent of the rule, which I understand and support. [/quote]
You are correct - the rule doesn't say "no carbon fiber". When the rule went into effect (late 70's as I recall), carbon fiber was still rediculously expensive and nobody ever thought if would be used for something as frivolous as a tiller extension.
There isn't a standard conductivity test for the tiller extensions, nor is there a prohibited material list. It's something the IHCA Rules Committee should consider.
Re: Suggestion for Upgrading Tiller Extension? [Re: mbounds] #151212
08/04/08 09:05 AM
08/04/08 09:05 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Matt,
Perhaps you can shed some wisdom on the whole issue of non-conducting tiller extensions. This has probably been hashed over to nausium in the past.
Comptip masts are one thing, but how does a tiller extension become a target when you are sitting on a metal frame (14, 16) or completely insulated from the mast support network when sitting in the normal helm positon?
What situation would you be worried about by having a metal tiller extension in your hand?
Hard to imagine running into a powerline while trapped....but?
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Suggestion for Upgrading Tiller Extension? [Re: Mugrace72] #151213
08/04/08 09:10 AM
08/04/08 09:10 AM
I don't recall the rationale for the non-conducting tillers. Like I said, the rule was introduced in the mid / late '70's. I would be surprised if it did not have a story similar to the Comptip (it being the result of a lawsuit settlement order).
Re: Suggestion for Upgrading Tiller Extension? [Re: Mugrace72] #151214
08/04/08 10:37 AM
08/04/08 10:37 AM
Thunder Bay ON CAN
M
mmadge Offline
mmadge  Offline
M
Thunder Bay ON CAN
I bought the Nacra carbon fiber telescopic one.Felt great while it lasted but broke like a popsicle stick the first stress it was under.I think it is poorly designed as the end where it connects to the cross bar is really thin and the grip end is thicker.
Mugrace what did they charge you to have that shipped (the CST one).I also looked at there,s and it is really popular on skiffs and catamarans in Australia(some of the guys were using them at the hobie 16 worlds)but the shipping costs were very high.
Re: Suggestion for Upgrading Tiller Extension? [Re: mmadge] #151215
08/04/08 11:16 AM
08/04/08 11:16 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
It was way too much...but I panicked and had DHL priority do it since I just really, really, really wanted the stick!
Just one of those unexplained moments.
The way to get one is to get a bunch...like 10 or 20 shipped at once, without a priority.
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Re: Suggestion for Upgrading Tiller Extension? [Re: Mugrace72] #151216
08/04/08 06:12 PM
08/04/08 06:12 PM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
It's not unusual to have an unused pair of ski poles. Make a long one with both. Very fancy!
0 registered members (), 21,478 guests, and 1,645 spiders.
Most Online23,788
Yesterday at 09:11 PM
