Carbon spin pole- repair how to? #153696
08/31/08 10:04 PM
08/31/08 10:04 PM
Lake Murray SC
FasterDamnit Offline OP
Lake Murray SC
We have an end snuffer pole w/ a clean break and some carbon cloth left over from Scollon Productions (mascot costumes.)
Can we use the same resin as for fiberglass? What would you use as internal piece to keep it aligned while the CF sets up?
Thanks.
Jim.
E-Scow
24' ULDB
Re: Carbon spin pole- repair how to? [Re: FasterDamnit] #153697
09/01/08 02:42 AM
09/01/08 02:42 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
same resin.
use a binding cloth or tape to squeeze the carbon flat and tight to the surface. Squeezes out excess resin and strengthens job.
Re: Carbon spin pole- repair how to? [Re: FasterDamnit] #153698
09/01/08 08:30 AM
09/01/08 08:30 AM
use epoxy resin (the same you would use with glass). Don't use polyester - it is a weaker material and it doesn't adhere to the carbon fibers as well. For squeezing the wetted fabric, use two layers of electrical tape. It will remove cleanly once cured.
I recently repaired my hotstick by making a jig to align the two broken pieces, then wrapping with several layers of wetted carbon (epoxy), taped with electrical tape, lightly perforated the electrical tape with a nail, and let it cure. (the perforations allow excess resin to seep out). A light sanding after removal of the vinyl tape is all that's needed.
Re: Carbon spin pole- repair how to? [Re: Jake] #153699
09/01/08 09:14 AM
09/01/08 09:14 AM
Lake Murray SC
Lake Murray SC
Awesome!
Thanks, guys.
Re: Carbon spin pole- repair how to? [Re: FasterDamnit] #153700
09/01/08 09:49 AM
09/01/08 09:49 AM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
Jim, what the hell are you making, and when are we going to see it?
Re: Carbon spin pole- repair how to? [Re: dave mosley] #153701
09/01/08 10:06 AM
09/01/08 10:06 AM
Breakwater Offline
Breakwater  Offline
Here's a good video instruction.
It's for building a spin pole new, but the principles are the same for repair.
http://www.youtube.com/watch?v=xblAy-lAN0E
Re: Carbon spin pole- repair how to? [Re: dave mosley] #153702
09/01/08 10:08 AM
09/01/08 10:08 AM
Lake Murray SC
Lake Murray SC
Dave,
Check the boat home building forum.
Just 18HT hulls w/ Gcat rig for now. If we don't make Catfest, we should make Outback.
It won't be pretty...
E-Scow
24' ULDB
Re: Carbon spin pole- repair how to? [Re: FasterDamnit] #153703
09/01/08 11:34 AM
09/01/08 11:34 AM
dave mosley Offline
dave mosley  Offline
coming soon- 18 ft of "W*T*F?"
Thats funny, but who knows until it hits the water....Looks like TS Hanna may bring some good wind in for Catfest, we are scheduled to go at the moment....
Re: Carbon spin pole- repair how to? [Re: dave mosley] #153704
09/01/08 11:41 AM
09/01/08 11:41 AM
Lake Murray SC
Lake Murray SC
So are you only racing the A these days?
Re: Carbon spin pole- repair how to? [Re: FasterDamnit] #153705
09/01/08 02:33 PM
09/01/08 02:33 PM
dave mosley Offline
dave mosley  Offline
its the only boat I have, other than my son's H14 and his Opti. I havent been able to sail much lately, but hope to be back on the water for a few Fall races.
david
Re: Carbon spin pole- repair how to? [Re: FasterDamnit] #153706
09/01/08 02:40 PM
09/01/08 02:40 PM
Is it an optical illusion or is that jib tack look way too close to the mast? I suppose you had to use the tangs already in the bows for the cross piece for the tack?
Why did you go with this rig instead of the original mast? Is it broken?
I have thought about putting up my H14 sail on my F16 when it's blowing 25+ but have yet to try it.
Re: Carbon spin pole- repair how to? [Re: Timbo] #153707
09/01/08 03:35 PM
09/01/08 03:35 PM
Lake Murray SC
Lake Murray SC
The jib is close, but it is a work in progress. We are starting with existing front stay mounts to set the cross bar since this does not require any modifications to the hulls. Also, the original G-cat rig did have a lot of jib overlap (damn near a genoa.)
The hulls came with just crossbars, tramp and traveler with the rest coming from our totaled G-cat.
This is phase 1. Long term it will have a square top main and high aspect jib w/ spin.
If it sails respectably with this rig, next step will be to get the spinnaker working.
Re: Carbon spin pole- repair how to? [Re: dave mosley] #153708
09/01/08 03:40 PM
09/01/08 03:40 PM
Lake Murray SC
Lake Murray SC
david
Same here. Hope to see you there.
Re: Carbon spin pole- repair how to? [Re: dave mosley] #153709
09/01/08 09:33 PM
09/01/08 09:33 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Franken-boats are so much fun! Genetic engineering sometimes yield surprises!
Dacarls:
Re: Carbon spin pole- repair how to? [Re: dacarls] #153710
09/01/08 09:49 PM
09/01/08 09:49 PM
Lake Murray SC
Lake Murray SC
True.
And honestly, the building is as important in this case as the sailing. Maybe more so...
E-Scow
24' ULDB
Re: Carbon spin pole- repair how to? [Re: FasterDamnit] #153711
09/02/08 08:42 AM
09/02/08 08:42 AM
SC
zander Offline
zander  Offline
SC
Hey Mosely. What's the word on the outback cup?
Always borrow money from a pessimist. He won't expect it back.
Re: Carbon spin pole- repair how to? [Re: zander] #153712
09/02/08 11:47 AM
09/02/08 11:47 AM
dave mosley Offline
dave mosley  Offline
Outback is on, and I hear they have a great band lined up.....
Carraba's cooking friday night, Outback Saturday night...how could you go wrong or hungry?
Re: Carbon spin pole- repair how to? [Re: dave mosley] #153713
09/02/08 11:59 AM
09/02/08 11:59 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
is it "Who's Bad"?
http://www.myspace.com/whosbadmusic
(sorry for the shameless plug of my friends' band)
Re: Carbon spin pole- repair how to? [Re: ThunderMuffin] #153714
09/02/08 12:46 PM
09/02/08 12:46 PM
SC
zander Offline
zander  Offline
SC
We're used to you being shameless. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
0 registered members (), 655 guests, and 139 spiders.
Posts267,056
