| Re: n20 mast
[Re: Timbo]
#161587 11/28/08 06:29 AM 11/28/08 06:29 AM |
Posts: 9,582 North-West Europe | I know an A cat mast weighs about half of what the alum. F16 mast weighs (19lbs. vs 36lbs. or there abouts)
Yes, but A-cat mast won't hold up F16 use (2-trap, spi, etc) The lightest F16 carbon masts (without corrector weights) are about 26 lbs or roughtly 75% of an alu F16 wingmast. Note that such a carbon F16 mast requires corrector weights to be F16 compliant ! A compliant F16 carbon mast is about 28 lbs (80%) The F16 carbon masts so far have proven to hold up under general abuse. I think since 2002 two carbon masts have been broken, one because the diamond wire snapped. Wouter
| | | Re: n20 mast
[Re: Wouter]
#161589 11/28/08 07:16 AM 11/28/08 07:16 AM |
Posts: 3,528 Looking for a Job, I got credi... | I know an A cat mast weighs about half of what the alum. F16 mast weighs (19lbs. vs 36lbs. or there abouts)
Yes, but A-cat mast won't hold up F16 use (2-trap, spi, etc) The lightest F16 carbon masts (without corrector weights) are about 26 lbs or roughtly 75% of an alu F16 wingmast. Note that such a carbon F16 mast requires corrector weights to be F16 compliant ! A compliant F16 carbon mast is about 28 lbs (80%) The F16 carbon masts so far have proven to hold up under general abuse. I think since 2002 two carbon masts have been broken, one because the diamond wire snapped. Wouter Wouter, is there a formula to calcualte the weight of a mast (lets make it a uniform tube) based on the tip weight; I can work out a rough approximation based un the summation of torques at points along the tube but that will not be accurate enough for some....
F16 - GBR 553 - SOLD I also talk sport here | | | Re: n20 mast
[Re: Rolf_Nilsen]
#161595 11/28/08 12:37 PM 11/28/08 12:37 PM |
Posts: 3,293 Long Beach, California | In Madrid, the T-class presented their new plan. All hulls will come from the same mould (nearly all already do), one mast has been chosen, one supplier of foils, one sailmaker with only one pattern, one supplier of hardware and all of it mounted in the same place on every boat. They're calling it "total one-design" to distinguish it from the previous one-design Tornado.
| | | Re: n20 mast
[Re: scooby_simon]
#161602 11/28/08 09:27 PM 11/28/08 09:27 PM | Scarecrow
| Scarecrow
Unregistered | [quote=Wouter]
Wouter, is there a formula to calcualte the weight of a mast (lets make it a uniform tube) based on the tip weight; I can work out a rough approximation based un the summation of torques at points along the tube but that will not be accurate enough for some.... I'm not Wouter, but the answer is no. A tip weight of 10.5kg could either be an 11 kg mast (1 kg extrusion with a 10kg weight at end) or a 21kg mast with a constant weight throughout, or for that matter a 1T mast with most of the weight at the base. | | | Re: n20 mast
[Re: JMAC]
#161607 11/28/08 11:38 PM 11/28/08 11:38 PM |
Posts: 2,490 On the Water | This thread went through a lot of side-bars, still waiting to hear exact weight difference and cost of new boat, from people "in the know" (i.e. Nacra Europe). I'm with you John, seems the price has been asked more than a few times, as well as WHO tested the new rig, etc. . .
Philip USA #1006 | | | Re: n20 mast
[Re: P.M.]
#161633 11/30/08 10:05 PM 11/30/08 10:05 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | Most likely there will be more consistency from mast to mast, I'm guessing the weight is comparable. Correct me if I'm wrong, but isn't this one of the reasons why the T went to a carbon stick? Wasn't it because some campaigns were ordering multiple alum sticks and picking which one worked for them since they all differred so greatly from one another? This thread went through a lot of side-bars, still waiting to hear exact weight difference and cost of new boat, from people "in the know" (i.e. Nacra Europe). and I second this statement. (or third..whatever) | | | Re: n20 mast
[Re: John Williams]
#161637 12/01/08 02:57 AM 12/01/08 02:57 AM |
Posts: 1,200 Vancouver, BC | In Madrid, the T-class presented their new plan. All hulls will come from the same mould (nearly all already do), one mast has been chosen, one supplier of foils, one sailmaker with only one pattern, one supplier of hardware and all of it mounted in the same place on every boat. They're calling it "total one-design" to distinguish it from the previous one-design Tornado. So I'm curious on this decision...doesn't the class membership need to vote on such an important issue? We had to vote on previous, less important issues. Decisions with class member consulation (unlike the I20 going to a new alu mast) has always been an important aspect of the T-class...to me any way.
| | | Re: n20 mast
[Re: Tornado]
#161642 12/01/08 06:06 AM 12/01/08 06:06 AM |
Posts: 3,528 Looking for a Job, I got credi... | In Madrid, the T-class presented their new plan. All hulls will come from the same mould (nearly all already do), one mast has been chosen, one supplier of foils, one sailmaker with only one pattern, one supplier of hardware and all of it mounted in the same place on every boat. They're calling it "total one-design" to distinguish it from the previous one-design Tornado. So I'm curious on this decision...doesn't the class membership need to vote on such an important issue? We had to vote on previous, less important issues. Decisions with class member consulation (unlike the I20 going to a new alu mast) has always been an important aspect of the T-class...to me any way. Maybe, there is to be a NEW class called the "one-design Tornado" which will be used by the rockstars for the ollies and campaigns. All current T's will remain "Tornado's".
[Re: Rolf_Nilsen]
#161654 12/01/08 11:20 AM 12/01/08 11:20 AM |
Posts: 5,590 Naples, FL | So if I snap an aluminum mast (any type of boat), do I get any credit toward the purchase of a replacement if I send back the broken parts?
Or should I just drop them off at my local metal salvage station and get the $ per kg credit...?
What's the current cost of aluminum?
And what do I do with a broken carbon mast (presuming it can't be repaired)? Grind it up and use it as landscape mulch?
| | | Re: n20 mast
[Re: waterbug_wpb]
#161657 12/01/08 12:05 PM 12/01/08 12:05 PM |
Posts: 4,451 West coast of Norway |
You cry for a while, try to mount the parts over the fireplace at home only to cry some more when your wife makes you throw your creative work in the bin. Seriously, they can often be repaired. If not, put them in storage or donate them to a project. | | |
1,023
guests, and 41
