| How to rig retrieval line on endpole snuffer? #164087 01/05/09 07:16 PM 01/05/09 07:16 PM |
Joined: Sep 2007 Posts: 531 Lake Murray SC FasterDamnit OP
Posts: 531 Lake Murray SC | I have an endpole snuffer and spin about ready to go on the frankencat. I think it is a two patch sail. How do you run the retrieval line?
E-Scow 24' ULDB
| | | Re: How to rig retrieval line on endpole snuffer?
[Re: GeoffS]
#164103 01/05/09 09:48 PM 01/05/09 09:48 PM |
Posts: 1,253 Columbia South Carolina, USA | Dont forget the grommet on the tramp where the line runs from the bag(underneath the tramp) to the mast as a 1 piece halyard/snuffer line. we have mounted our spin cleat(Harken pivoting exit block) on the mast at a little below shoulder height on the starboard side of the mast. Evryone does it different, but this works well for us.
[Re: dave mosley]
#164114 01/05/09 10:50 PM 01/05/09 10:50 PM | andrewscott
| andrewscott
Unregistered | there are many ways to do it,.. but i am sure that each boat, gear and spin have their own optimal way to get it to work best....
i have a 2 patch (mid pole snuffer) and i run the line all on the same side of the spin. i have a little ring on the lower patch (for the line to slide through) and a tie off point on the upper patch.
I would strongly suggest you seek other boats with spins and see their system,.. or even better crew with them to see it in action.
For ME, i was miserable the first 12 times i used it... the next 10 it got better... now i LOVE downwind with the spin.... | | | Re: How to rig retrieval line on endpole snuffer?
[Re: ]
#164133 01/06/09 04:05 AM 01/06/09 04:05 AM |
Posts: 271 Atlanta, Ga | Don't tie off to the bottom patch; just run straight through. I have an endpole ring and bag that I'll get rid of cheap if you're interested. | | | Re: How to rig retrieval line on endpole snuffer?
[Re: BLR_0719]
#164150 01/06/09 09:12 AM 01/06/09 09:12 AM |
Posts: 531 Lake Murray SC | Thanks, BLR. I have an integrated carbon pole/snuffer (currently broken waiting for a splice tube to show up.) But I am interested for a possible backup. PM me!
E-Scow 24' ULDB
[Re: FasterDamnit]
#164155 01/06/09 10:01 AM 01/06/09 10:01 AM | andrewscott
| andrewscott
Unregistered | OK- Do you put a knot in the line at the bottom patch? Hadn't thought of the continuous line- what type of line do you recommend? I assume you mean, a knot to avoid it from bunching up and jamming during retrieval? if that is the case: that didn't work for me... i always had some of the spin hanging out of the basket (may work better on an end snuffer). what does work (FOR ME) is i use a little plastic stopper ball (like the ones that you put on the end of your furler line) and tie a 10inch (est) bowline loop at the top patch. this stops the chute from bunching up Line: i had 6mm Samson XLS, but switched to 4 mm. i think it may be to thin as it FLYs through the spinlock to fast and drops the chute to fast (into the water) and think 5mm may be the way to go...
[Re: ]
#164159 01/06/09 10:30 AM 01/06/09 10:30 AM |
Posts: 1,253 Columbia South Carolina, USA | the line runs thru the middle patch, then ties off to the top patch. You may have to play with it to get the right length and configuration to snuff the whole chute. Its important when you set the pole heigth to make sure the spin luff is the correct tension. Dont skimp on this when rigging the pole system.
[Re: FasterDamnit]
#164167 01/06/09 11:48 AM 01/06/09 11:48 AM |
Posts: 337 Arizona | I have a one line system. 5mm robline run per http://www.catsailor.com/bb files/113750-spintang.gif I hope that gets you there. There is a great write up on the forum with pics that I used, I'll try to find it. I ran the retreval as described previously but found that the spin wouldent go all the way into the bag and sometimes balled up at the hoop. I tied a 12" line to the tack so that it would go deeper into the sock. I also put a tenis ball on the line about 12" from the the upper attachment point on the sail. I attached a bungee across the rear of the tramp and attached a small block which the sheet - retreval runs through to take up some slack. Didnt need a grommet in the tramp as the sock is far enough forward for direct pull out the rear.
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: How to rig retrieval line on endpole snuffer?
[Re: AzCat]
#164178 01/06/09 12:32 PM 01/06/09 12:32 PM | andrewscott
| andrewscott
Unregistered | I I also put a tenis ball on the line about 12" from the the upper attachment point on the sail. TENNIS BALLS???? FOR REAL?????? | | | Re: How to rig retrieval line on endpole snuffer?
[Re: FasterDamnit]
#164210 01/06/09 05:59 PM 01/06/09 05:59 PM | andrewscott
| andrewscott
Unregistered | Line: i had 6mm Samson XLS, but switched to 4 mm. i think it may be to thin as it flies through the spinlock to fast and drops the chute to fast (into the water) and think 5mm may be the way to go...
[Re: ]
#164224 01/06/09 08:53 PM 01/06/09 08:53 PM |
Posts: 1,253 Columbia South Carolina, USA | Ask Treyline about Robline sheets, he is pretty sold on them, I have a Robline main, good hand feel, not sold on it yet though(not tested enough because I suck and dont sail enough)
[Re: ]
#164236 01/07/09 12:46 AM 01/07/09 12:46 AM |
Posts: 337 Arizona | I I also put a tenis ball on the line about 12" from the the upper attachment point on the sail. TENNIS BALLS???? FOR REAL?????? I'll use it till someone gives me a better idea. IT WORKS GREAT. Woops, my finger slipped, I wasn't yelling.
[Re: AzCat]
#164251 01/07/09 09:02 AM 01/07/09 09:02 AM | andrewscott
| andrewscott
Unregistered | I'll use it till someone gives me a better idea. IT WORKS GREAT. It just seems like a lot of weight up there... Robbie Daniels suggested this to me (after i bought my spin from him and Jill) and it works very well for me.... i use a little plastic stopper ball (just above the lower patch) and tie a 10inch (est) bowline loop at the top patch. this stops the chute from bunching up
[Re: dave mosley]
#164252 01/07/09 09:07 AM 01/07/09 09:07 AM |
Posts: 3,906 Clermont, FL, USA | (not tested enough because I suck and dont sail enough) Ah geeze Dave, if you're going to disarm us how are we going to kick you in the nuts?
2,777
guests, and 310
