Page 1 of 3 1 2 3
How to rig retrieval line on endpole snuffer? #164087
01/05/09 07:16 PM
01/05/09 07:16 PM
Lake Murray SC
FasterDamnit Offline OP
Lake Murray SC
I have an endpole snuffer and spin about ready to go on the frankencat. I think it is a two patch sail. How do you run the retrieval line?
E-Scow
24' ULDB
Re: How to rig retrieval line on endpole snuffer? [Re: FasterDamnit] #164098
01/05/09 09:24 PM
01/05/09 09:24 PM
Atlanta
GeoffS Offline
GeoffS  Offline
Atlanta
I used to have an end pole snuffer and 2 patch spin on an I17R. Here is how it was routed on that boat:
through bag -> out of hoop -> up back side of spin -> through lower patch -> up front side of spin -> terminate at upper patch
"back" and "front" of spin correspond to the spin on the side of the boat where you do most of your take downs.
Geoff
Re: How to rig retrieval line on endpole snuffer? [Re: GeoffS] #164103
01/05/09 09:48 PM
01/05/09 09:48 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
Dont forget the grommet on the tramp where the line runs from the bag(underneath the tramp) to the mast as a 1 piece halyard/snuffer line. we have mounted our spin cleat(Harken pivoting exit block) on the mast at a little below shoulder height on the starboard side of the mast. Evryone does it different, but this works well for us.
Re: How to rig retrieval line on endpole snuffer? [Re: dave mosley] #164111
01/05/09 10:42 PM
01/05/09 10:42 PM
Lake Murray SC
Lake Murray SC
OK-
Do you put a knot in the line at the bottom patch? Hadn't thought of the continuous line- what type of line do you recommend?
Re: How to rig retrieval line on endpole snuffer? [Re: dave mosley] #164114
01/05/09 10:50 PM
01/05/09 10:50 PM
andrewscott
andrewscott
there are many ways to do it,.. but i am sure that each boat, gear and spin have their own optimal way to get it to work best....
i have a 2 patch (mid pole snuffer) and i run the line all on the same side of the spin. i have a little ring on the lower patch (for the line to slide through) and a tie off point on the upper patch.
I would strongly suggest you seek other boats with spins and see their system,.. or even better crew with them to see it in action.
For ME, i was miserable the first 12 times i used it... the next 10 it got better... now i LOVE downwind with the spin....
Re: How to rig retrieval line on endpole snuffer? [Re: ] #164133
01/06/09 04:05 AM
01/06/09 04:05 AM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
Don't tie off to the bottom patch; just run straight through. I have an endpole ring and bag that I'll get rid of cheap if you're interested.
Re: How to rig retrieval line on endpole snuffer? [Re: BLR_0719] #164150
01/06/09 09:12 AM
01/06/09 09:12 AM
Lake Murray SC
Lake Murray SC
Thanks, BLR. I have an integrated carbon pole/snuffer (currently broken waiting for a splice tube to show up.) But I am interested for a possible backup. PM me!
E-Scow
24' ULDB
Re: How to rig retrieval line on endpole snuffer? [Re: FasterDamnit] #164155
01/06/09 10:01 AM
01/06/09 10:01 AM
andrewscott
andrewscott
Originally Posted by FasterDamnit
OK-
I assume you mean, a knot to avoid it from bunching up and jamming during retrieval? if that is the case: that didn't work for me... i always had some of the spin hanging out of the basket (may work better on an end snuffer). what does work (FOR ME) is i use a little plastic stopper ball (like the ones that you put on the end of your furler line) and tie a 10inch (est) bowline loop at the top patch. this stops the chute from bunching up
Line: i had 6mm Samson XLS, but switched to 4 mm. i think it may be to thin as it FLYs through the spinlock to fast and drops the chute to fast (into the water) and think 5mm may be the way to go...
Re: How to rig retrieval line on endpole snuffer? [Re: ] #164159
01/06/09 10:30 AM
01/06/09 10:30 AM
dave mosley Offline
dave mosley  Offline
the line runs thru the middle patch, then ties off to the top patch. You may have to play with it to get the right length and configuration to snuff the whole chute. Its important when you set the pole heigth to make sure the spin luff is the correct tension. Dont skimp on this when rigging the pole system.
Re: How to rig retrieval line on endpole snuffer? [Re: FasterDamnit] #164167
01/06/09 11:48 AM
01/06/09 11:48 AM
Arizona
AzCat Offline
AzCat  Offline
Arizona
I have a one line system. 5mm robline run per http://www.catsailor.com/bb files/113750-spintang.gif
I hope that gets you there. There is a great write up on the forum with pics that I used, I'll try to find it.
I ran the retreval as described previously but found that the spin wouldent go all the way into the bag and sometimes balled up at the hoop. I tied a 12" line to the tack so that it would go deeper into the sock. I also put a tenis ball on the line about 12" from the the upper attachment point on the sail.
I attached a bungee across the rear of the tramp and attached a small block which the sheet - retreval runs through to take up some slack. Didnt need a grommet in the tramp as the sock is far enough forward for direct pull out the rear.
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: How to rig retrieval line on endpole snuffer? [Re: AzCat] #164174
01/06/09 12:25 PM
01/06/09 12:25 PM
dave mosley Offline
dave mosley  Offline
Re: How to rig retrieval line on endpole snuffer? [Re: AzCat] #164178
01/06/09 12:32 PM
01/06/09 12:32 PM
andrewscott
andrewscott
Originally Posted by azcat
I I also put a tenis ball on the line about 12" from the the upper attachment point on the sail.
TENNIS BALLS???? FOR REAL??????
Re: How to rig retrieval line on endpole snuffer? [Re: ] #164209
01/06/09 05:54 PM
01/06/09 05:54 PM
Lake Murray SC
Lake Murray SC
Just ordered the Harken exit block and have dyneema for the bow bridle. Have Ronstan auto ratchet blocks and turning blocks from Harken. Pole has a bag on it.
What should I get for sheets?
Re: How to rig retrieval line on endpole snuffer? [Re: FasterDamnit] #164210
01/06/09 05:59 PM
01/06/09 05:59 PM
andrewscott
andrewscott
Line: i had 6mm Samson XLS, but switched to 4 mm. i think it may be to thin as it flies through the spinlock to fast and drops the chute to fast (into the water) and think 5mm may be the way to go...
Re: How to rig retrieval line on endpole snuffer? [Re: ] #164224
01/06/09 08:53 PM
01/06/09 08:53 PM
dave mosley Offline
dave mosley  Offline
Ask Treyline about Robline sheets, he is pretty sold on them, I have a Robline main, good hand feel, not sold on it yet though(not tested enough because I suck and dont sail enough)
Re: How to rig retrieval line on endpole snuffer? [Re: ] #164236
01/07/09 12:46 AM
01/07/09 12:46 AM
Arizona
AzCat Offline
AzCat  Offline
Arizona
I'll use it till someone gives me a better idea. IT WORKS GREAT.
Woops, my finger slipped, I wasn't yelling.
Re: How to rig retrieval line on endpole snuffer? [Re: AzCat] #164251
01/07/09 09:02 AM
01/07/09 09:02 AM
andrewscott
andrewscott
It just seems like a lot of weight up there... Robbie Daniels suggested this to me (after i bought my spin from him and Jill) and it works very well for me....
i use a little plastic stopper ball (just above the lower patch) and tie a 10inch (est) bowline loop at the top patch. this stops the chute from bunching up
Re: How to rig retrieval line on endpole snuffer? [Re: dave mosley] #164252
01/07/09 09:07 AM
01/07/09 09:07 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Ah geeze Dave, if you're going to disarm us how are we going to kick you in the nuts?
F18 USA 242
http://www.solarwind.solar
Re: How to rig retrieval line on endpole snuffer? [Re: David Ingram] #164257
01/07/09 09:37 AM
01/07/09 09:37 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
On the lower patch I use a small piece of line with a loop in one end and a small stopper ball on the other. The loop is on the side you want to douse from and the snuffer line runs thru it. Maybe this has already been covered. Know that I am thinking of it maybe the line should be a little longer allowing the top patch to offset from the lower patch and the top patch to enter the snuffer head first....hmmm
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: How to rig retrieval line on endpole snuffer? [Re: Chris9] #164260
01/07/09 09:44 AM
01/07/09 09:44 AM
Lake Murray SC
Lake Murray SC
Great stuff guys-
Thanks!
Page 1 of 3 1 2 3
0 registered members (), 650 guests, and 165 spiders.
Posts267,056
