Rolling Auto Paint #164520
01/08/09 09:30 PM
01/08/09 09:30 PM
South Florida & the Keys
arbo06 Offline OP
arbo06  Offline OP
hmm hmm, gentlemen,
I need to add non skid to the decks of THE BOAT, when I mix the paint should I skip the reducer since I will be rolling and not spraying?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Rolling Auto Paint [Re: arbo06] #164529
01/09/09 03:36 AM
01/09/09 03:36 AM
JACKFLASH Offline
JACKFLASH  Offline
You can use a piece of glass to test consistency before applying. When I did it with two part epoxy auto paint I had to add thinner. How ever in my case I was rolling and tipping and going for a mirrored surface, not doing nonskid. But gut says yes but probably not to the same degree that you would for a mirrored finish.
Collin Casey
Re: Rolling Auto Paint [Re: arbo06] #164535
01/09/09 09:19 AM
01/09/09 09:19 AM
C
Chet
Chet
C
I used awlgrip non skid on THE OTHER BOAT. The best method was to broadcast after rolling and tipping. The base coat needs to be as strong as possible because it will hold the grit. My guess is that some reducer will help the paint set up strong. For awl-grip I used a sheen killer, and overcoated the grit with more stuff to lock it in. The overcoat should be reduced way down to keep it from filling the grip pits.
Awl-grip extra coarse is wicked rough and terriffic non skid,
Awl-grip medium was great for something you must sit upon
Regards
Chet
Re: Rolling Auto Paint [Re: ] #164536
01/09/09 09:34 AM
01/09/09 09:34 AM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
Spray on truck bed liner (rattle can).
Re: Rolling Auto Paint [Re: arbo06] #164553
01/09/09 12:14 PM
01/09/09 12:14 PM
K
Kevin Cook Offline
Kevin Cook  Offline
K
here is something you may want to check out; http://www.grizzlygrip.com I bought a quart to to give it a try. Note that the base is a two part linear alphitic urethane - just like Awlgrip and others. Also, the non-skid is ground rubber instead of glass beads or sand.
Kevin`
Re: Rolling Auto Paint [Re: Kevin Cook] #164560
01/09/09 01:15 PM
01/09/09 01:15 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
Hey Kevin
How does your new tri sail? .... She looks great on the hook. Congratulations on the new build!
Mark
crac.sailregattas.com
Re: Rolling Auto Paint [Re: Mark Schneider] #164565
01/09/09 02:44 PM
01/09/09 02:44 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Kevin finished his Tri?!!? Awesome!! I remember checking out his carbon tornado and him showing me a centerboard for it. Amazing shop Kevin has smile
man that seems like decades ago.
Re: Rolling Auto Paint [Re: FasterDamnit] #164582
01/09/09 05:35 PM
01/09/09 05:35 PM
arbo06 Offline OP
arbo06  Offline OP
Really, spray on? Does it come in colors other than black?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Rolling Auto Paint [Re: ThunderMuffin] #164583
01/09/09 06:01 PM
01/09/09 06:01 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
You've barely been alive "decades" i.e. plural, like two.
Isak Dinesen
E. B. White
Re: Rolling Auto Paint [Re: Team_Cat_Fever] #164584
01/09/09 06:04 PM
01/09/09 06:04 PM
Hey Kevin,
How 'bout some pics of your creation. If your gonna race it and need crew gimme a shout.
Todd Hart
Isak Dinesen
E. B. White
Re: Rolling Auto Paint [Re: Team_Cat_Fever] #164586
01/09/09 06:55 PM
01/09/09 06:55 PM
Lake Murray SC
Lake Murray SC
I don't think so, arbo. Wasn't exactly serious. But it would probably work if you don't mind black...
Re: Rolling Auto Paint [Re: FasterDamnit] #164589
01/09/09 08:17 PM
01/09/09 08:17 PM
arbo06 Offline OP
arbo06  Offline OP
duhh.
Thanx. Always looking for a shortcut.....
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Rolling Auto Paint [Re: arbo06] #164592
01/09/09 09:27 PM
01/09/09 09:27 PM
K
Kevin Cook Offline
Kevin Cook  Offline
K
It's roll or spray. they have about 20 colors.
Re: Rolling Auto Paint [Re: Mark Schneider] #164593
01/09/09 09:44 PM
01/09/09 09:44 PM
K
Kevin Cook Offline
Kevin Cook  Offline
K
Hi Mark, Hi Todd,
The new boat works well which is always a shock to me cause I usually try out some new design ideas. The building seemed to go on forever....and ever. I took Greg, Casey, and Onika out and they seemed to like feel of it too. It's fast, well balanced, but not as responsive as the tornado of course.
I was able to rent the same mooring for next season so you guys are welcome to give it a try anytime. I tried to post some pictures on the forum but couldn't get it to work. Tami was able to get one of them up. I'll have to give it another try. Sailing magazine did an interview and a photo shoot but I don't know when or if they will use it. I wish I could get copies of the pictures though - there was one sailing close by Pitate's Cove pier when a big gust hit. Suspect that was a really cool picture. See you in April,
Kevin http://i377.photobucket.com/albums/oo211/kevincook/136.jpg
Re: Rolling Auto Paint [Re: Team_Cat_Fever] #164609
01/10/09 09:13 AM
01/10/09 09:13 AM
Portland, Maine
Portland, Maine
I know that counting to three is difficult for you, but thats the number of decades that I've nearly been around.
Re: Rolling Auto Paint [Re: ThunderMuffin] #164611
01/10/09 09:30 AM
01/10/09 09:30 AM
"nearly"
That's funny. My 7 year old does that too.
Isak Dinesen
E. B. White
Re: Rolling Auto Paint [Re: Team_Cat_Fever] #164730
01/12/09 10:23 AM
01/12/09 10:23 AM
I'd think that bedliner spray might be a bit on the heavy side, but maybe it's because they spray it on thick...
Why not just apply the two-part coating on as usual, and dust with sugar crystals before it sets? Then you can wash off the sugar after it's dry (the sugar dissolves, leaving the rough surface) for the non-skid??
Surf board builders call it "sugar deck"
A courser finish could be had using Kosher salt or unrefined sugar ("sugar in the raw")
Re: Rolling Auto Paint [Re: waterbug_wpb] #164763
01/12/09 07:56 PM
01/12/09 07:56 PM
arbo06 Offline OP
arbo06  Offline OP
I have the Pettit skidless compound onhand. My concern is that I want to get even distribution of the material. The material will settle to the bottom of the tray or container. Skould I put it in a salt shaker or add it to the paint and mix often?
Eric Arbogast
ARC 2101
Miami Yacht Club
0 registered members (), 17,403 guests, and 435 spiders.
Yesterday at 04:54 AM
