| Rolling Auto Paint #164520 01/08/09 09:30 PM 01/08/09 09:30 PM |
Joined: Jun 2001 Posts: 1,911 South Florida & the Keys arbo06 OP
Posts: 1,911 South Florida & the Keys | hmm hmm, gentlemen,
I need to add non skid to the decks of THE BOAT, when I mix the paint should I skip the reducer since I will be rolling and not spraying?
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Rolling Auto Paint
[Re: arbo06]
#164529 01/09/09 03:36 AM 01/09/09 03:36 AM |
Posts: 291 | You can use a piece of glass to test consistency before applying. When I did it with two part epoxy auto paint I had to add thinner. How ever in my case I was rolling and tipping and going for a mirrored surface, not doing nonskid. But gut says yes but probably not to the same degree that you would for a mirrored finish.
[Re: arbo06]
#164535 01/09/09 09:19 AM 01/09/09 09:19 AM | Chet
| Chet
Unregistered | I used awlgrip non skid on THE OTHER BOAT. The best method was to broadcast after rolling and tipping. The base coat needs to be as strong as possible because it will hold the grit. My guess is that some reducer will help the paint set up strong. For awl-grip I used a sheen killer, and overcoated the grit with more stuff to lock it in. The overcoat should be reduced way down to keep it from filling the grip pits.
Awl-grip extra coarse is wicked rough and terriffic non skid, Awl-grip medium was great for something you must sit upon
Regards Chet | | | Re: Rolling Auto Paint
[Re: arbo06]
#164553 01/09/09 12:14 PM 01/09/09 12:14 PM |
Posts: 115 | here is something you may want to check out; http://www.grizzlygrip.com I bought a quart to to give it a try. Note that the base is a two part linear alphitic urethane - just like Awlgrip and others. Also, the non-skid is ground rubber instead of glass beads or sand. Kevin` | | | Re: Rolling Auto Paint
[Re: Kevin Cook]
#164560 01/09/09 01:15 PM 01/09/09 01:15 PM |
Posts: 3,116 Annapolis, MD | Hey Kevin
How does your new tri sail? .... She looks great on the hook. Congratulations on the new build!
Mark
crac.sailregattas.com
[Re: ThunderMuffin]
#164583 01/09/09 06:01 PM 01/09/09 06:01 PM |
Posts: 3,224 Roanoke Island ,N.C. | Kevin finished his Tri?!!? Awesome!! I remember checking out his carbon tornado and him showing me a centerboard for it. Amazing shop Kevin has  man that seems like decades ago. You've barely been alive "decades" i.e. plural, like two.
[Re: Team_Cat_Fever]
#164584 01/09/09 06:04 PM 01/09/09 06:04 PM |
Posts: 3,224 Roanoke Island ,N.C. | Hey Kevin, How 'bout some pics of your creation. If your gonna race it and need crew gimme a shout. Todd Hart
[Re: arbo06]
#164592 01/09/09 09:27 PM 01/09/09 09:27 PM |
Posts: 115 | It's roll or spray. they have about 20 colors. Really, spray on? Does it come in colors other than black? | | | Re: Rolling Auto Paint
[Re: Mark Schneider]
#164593 01/09/09 09:44 PM 01/09/09 09:44 PM |
Posts: 115 | Hi Mark, Hi Todd, The new boat works well which is always a shock to me cause I usually try out some new design ideas. The building seemed to go on forever....and ever. I took Greg, Casey, and Onika out and they seemed to like feel of it too. It's fast, well balanced, but not as responsive as the tornado of course. I was able to rent the same mooring for next season so you guys are welcome to give it a try anytime. I tried to post some pictures on the forum but couldn't get it to work. Tami was able to get one of them up. I'll have to give it another try. Sailing magazine did an interview and a photo shoot but I don't know when or if they will use it. I wish I could get copies of the pictures though - there was one sailing close by Pitate's Cove pier when a big gust hit. Suspect that was a really cool picture. See you in April, Kevin http://i377.photobucket.com/albums/oo211/kevincook/136.jpg | | | Re: Rolling Auto Paint
#164609 01/10/09 09:13 AM 01/10/09 09:13 AM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | You've barely been alive "decades" i.e. plural, like two. I know that counting to three is difficult for you, but thats the number of decades that I've nearly been around. | | | Re: Rolling Auto Paint
[Re: ThunderMuffin]
#164611 01/10/09 09:30 AM 01/10/09 09:30 AM |
Posts: 3,224 Roanoke Island ,N.C. | You've barely been alive "decades" i.e. plural, like two. I know that counting to three is difficult for you, but thats the number of decades that I've nearly been around. "nearly" That's funny. My 7 year old does that too.
#164730 01/12/09 10:23 AM 01/12/09 10:23 AM |
Posts: 5,590 Naples, FL | I'd think that bedliner spray might be a bit on the heavy side, but maybe it's because they spray it on thick...
Why not just apply the two-part coating on as usual, and dust with sugar crystals before it sets? Then you can wash off the sugar after it's dry (the sugar dissolves, leaving the rough surface) for the non-skid??
Surf board builders call it "sugar deck"
A courser finish could be had using Kosher salt or unrefined sugar ("sugar in the raw")
[Re: waterbug_wpb]
#164763 01/12/09 07:56 PM 01/12/09 07:56 PM |
Posts: 1,911 South Florida & the Keys | I have the Pettit skidless compound onhand. My concern is that I want to get even distribution of the material. The material will settle to the bottom of the tray or container. Skould I put it in a salt shaker or add it to the paint and mix often?
2,406
guests, and 274
