Beach Wheel tubes #174675
04/13/09 12:07 PM
04/13/09 12:07 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Having a hard time finding the right size inner tube for the beach wheels(21-12- 8).Can I get away with a larger or smaller size tube?
Re: Beach Wheel tubes [Re: mmadge] #174697
04/13/09 02:31 PM
04/13/09 02:31 PM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Mike,
I do believe that the "Ship's Store" here at CatSailor carries and can supply you w/ the correct size "Inner Tube" for you beach wheels.
Has it stopped snowing up your way yet????
Harry
Re: Beach Wheel tubes [Re: HMurphey] #174702
04/13/09 02:36 PM
04/13/09 02:36 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
make sure your outer tire deosnt have any dry rot...Dont ask me how I know....
Re: Beach Wheel tubes [Re: HMurphey] #174706
04/13/09 03:53 PM
04/13/09 03:53 PM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Yes stopped snowing (for now).
I was hoping to just get one here in Thunder Bay,(save shipping ,duty, exchange).I found a 22-12-8 that the tire shop guy seems to think should work.
Re: Beach Wheel tubes [Re: dave mosley] #174721
04/13/09 05:12 PM
04/13/09 05:12 PM
Dude, you're so far past the "dry rot" stage it's not even funny.
Re: Beach Wheel tubes [Re: Jake] #174745
04/13/09 08:14 PM
04/13/09 08:14 PM
Mike- I just picked up two tubes Saturday. Couldn't get the 21-12-8 size either, ended up just using a 22-11-8 and it seemed to fill everything fine.
Let me know and I'll grab two more for you and I'll bring a set of tire spoons to the regatta and we can swap them out. I think they were about $6.
Re: Beach Wheel tubes [Re: Karl_Brogger] #174747
04/13/09 08:40 PM
04/13/09 08:40 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Karl,
Where did you get them?
Isak Dinesen
E. B. White
Re: Beach Wheel tubes [Re: Team_Cat_Fever] #174749
04/13/09 08:53 PM
04/13/09 08:53 PM
Local Yamaha Honda motorcycle dealership. After years of spending virtually every single dollar I made funding my motorcross habits there, I get the same discount as the employee's. Not a big deal, retail was like $10.50 But some parts have rediculous mark ups, and 5% over cost kicks butt in those scenarios
Re: Beach Wheel tubes [Re: Karl_Brogger] #174789
04/14/09 08:53 AM
04/14/09 08:53 AM
Thunder Bay ON CAN
M
mmadge Offline OP
mmadge  Offline OP
M
Thunder Bay ON CAN
Is it that easy to put the tubes in?
Re: Beach Wheel tubes [Re: mmadge] #174796
04/14/09 09:52 AM
04/14/09 09:52 AM
brucat Offline
brucat  Offline
Not to ask a stupid question, but hey why not...
Why would it matter if there was dry rot on the tires? You're putting a tube in it, and they don't need much pressure to work in the sand.
Also, does anyone here do anything to preserve the life of the tires? Armor All or something to that effect. Does covering them (as in, with a tarp) help for long-term (winter) storage, or is it best to bring them indoors?
Re: Beach Wheel tubes [Re: brucat] #174797
04/14/09 10:02 AM
04/14/09 10:02 AM
It matters when they're dry rotted enough that the bead separates leaving an inner tube partially wrapped with a tire.
Covering them definitely helps. Our N20 was setup with the beachwheels stored under the trampoline of the boat next to the storage box and I've configured my a-cat trailer the same way. Both have trampoline covers so the beach wheels are shaded from the sun.
Re: Beach Wheel tubes [Re: Jake] #174798
04/14/09 10:10 AM
04/14/09 10:10 AM
David needs to post a pic of his tire. That would explain alot. It looks like a tube with a bad re-tread.
Tawd
Isak Dinesen
E. B. White
Re: Beach Wheel tubes [Re: mmadge] #174801
04/14/09 10:26 AM
04/14/09 10:26 AM
Yep, took me longer to find the spoons, a pair of side cutters to cut off the valve stem, and remove the wheels than it did swap em out.
Those tires are stupid soft, the have no tread, a ton of sidewall and no load capacity. Just about as easy as they come.
Re: Beach Wheel tubes [Re: Karl_Brogger] #174837
04/14/09 02:29 PM
04/14/09 02:29 PM
dave mosley Offline
dave mosley  Offline
when I added the inner tube, it was only rotted, but 1 yr later it was a bad retread. The pressure on the old tire was more than enough to have "catastrophic" failure at an inoppurtune time
Last edited by dave mosley; 04/14/09 02:29 PM. Reason: I spell like a 4th grader...no offense 4th graders
Re: Beach Wheel tubes [Re: dave mosley] #174859
04/14/09 07:10 PM
04/14/09 07:10 PM
Lake Murray, SC,USA
Cary Palmer Offline
Cary Palmer  Offline
Lake Murray, SC,USA
Actually the tube was vastly overinflated, caused the old rubber rim to break when it sat out in the sun and increased the pressure even furthur, Catastrophic failure triggered by the weight of that big heavy Marstrom on top of it.
So just put some Salve on it and hush up!
CARY
0 registered members (), 2,523 guests, and 702 spiders.
2 hours ago
