F16 Jib for Taipan
F16 Jib for Taipan
#185318
07/16/09
11:33 AM
07/16/09
11:33 AM
Feb 2005
aodhan
aodhan
Feb 2005
Hi all,
I am in the process of installing a selftacker on my Taipan 4.9 and was wondering if anyone had a Jib for sale that might work.
Also if anyone had one made would they still have the measurements used.
Thanks
Aidan
Re: F16 Jib for Taipan
Re: aodhan
#185332
07/16/09
02:00 PM
07/16/09
02:00 PM
Aug 2002
Annapolis Md.
LuckyDuck
LuckyDuck
Aug 2002
Annapolis Md.
Where are you located Aidan. I have a jib from the Blade that I have never used. Ed
F-16 Falcon #212
Re: LuckyDuck
#185339
07/16/09
02:40 PM
07/16/09
02:40 PM
Feb 2005
aodhan
aodhan
Feb 2005
I am located just outside of Toronto in Canada. I will send you PM to discuss
Re: aodhan
#185539
07/19/09
02:09 PM
07/19/09
02:09 PM
Jan 2004
Arkansas, USA
C
CaptainKirt
CaptainKirt
C
Jan 2004
Arkansas, USA
Make sure the distance from the front hull tangs to the main beam are the same between the two boats-
Kirt
Kirt Simmons
Taipan, Flyer
Re: CaptainKirt
#185551
07/19/09
06:55 PM
07/19/09
06:55 PM
Feb 2005
aodhan
aodhan
Feb 2005
Kirt,
Thanks for the advice. I will check it out.
/ Aidan
Re: aodhan
#185552
07/19/09
07:47 PM
07/19/09
07:47 PM
Aug 2007
Pensacola, FL
C
Cab
Cab
C
Aug 2007
Pensacola, FL
Also, the blade jib tacks to the spin pole, not to the bridle forestay connection.
Chris
Trident F16
Re: Cab
#185565
07/19/09
10:24 PM
07/19/09
10:24 PM
Feb 2005
aodhan
aodhan
Feb 2005
I was planning on installing a compression post between the bridle connection and spin pole and doing the same on the taipan but thanks for the info
phill
Switch to Threaded Mode
0 registered members (), 655 guests, and 139 spiders.
'81 Hobie 16 Lac Leman
