F16 Jib for Taipan #185318
07/16/09 11:33 AM
07/16/09 11:33 AM
aodhan Offline OP
aodhan  Offline OP
Hi all,
I am in the process of installing a selftacker on my Taipan 4.9 and was wondering if anyone had a Jib for sale that might work.
Also if anyone had one made would they still have the measurements used.
Thanks
Aidan
Re: F16 Jib for Taipan [Re: aodhan] #185332
07/16/09 02:00 PM
07/16/09 02:00 PM
Annapolis Md.
LuckyDuck Offline
LuckyDuck  Offline
Annapolis Md.
Where are you located Aidan. I have a jib from the Blade that I have never used. Ed
F-16 Falcon #212
Re: F16 Jib for Taipan [Re: LuckyDuck] #185339
07/16/09 02:40 PM
07/16/09 02:40 PM
aodhan Offline OP
aodhan  Offline OP
I am located just outside of Toronto in Canada. I will send you PM to discuss
Re: F16 Jib for Taipan [Re: aodhan] #185539
07/19/09 02:09 PM
07/19/09 02:09 PM
Arkansas, USA
C
CaptainKirt Offline
CaptainKirt  Offline
C
Arkansas, USA
Make sure the distance from the front hull tangs to the main beam are the same between the two boats-
Kirt
Kirt Simmons
Taipan, Flyer
Re: F16 Jib for Taipan [Re: CaptainKirt] #185551
07/19/09 06:55 PM
07/19/09 06:55 PM
aodhan Offline OP
aodhan  Offline OP
Kirt,
Thanks for the advice. I will check it out.
/ Aidan
Re: F16 Jib for Taipan [Re: aodhan] #185552
07/19/09 07:47 PM
07/19/09 07:47 PM
Pensacola, FL
C
Cab Offline
Cab  Offline
C
Pensacola, FL
Also, the blade jib tacks to the spin pole, not to the bridle forestay connection.
Chris
Trident F16
Re: F16 Jib for Taipan [Re: Cab] #185565
07/19/09 10:24 PM
07/19/09 10:24 PM
aodhan Offline OP
aodhan  Offline OP
I was planning on installing a compression post between the bridle connection and spin pole and doing the same on the taipan but thanks for the info
0 registered members (), 344 guests, and 86 spiders.
Posts267,056
