Nacra 6.0 What? #185761
07/21/09 08:26 PM
07/21/09 08:26 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
I have an '89 N6.0 which was built and sold in '88, sail #38. I am wondering what its configuation was called and how I can max out its performance without tearing the mast in half.
Performance is adamant that if I add a square top, it will snap the mast, I have also heard this from other first hand sources so that is out. Performance was also against adding a second set of diamonds and larger spreaders to acomodate a sq top.
This boat has a self tacking jib which I want to keep. It has no overlap, and travels on a track full leingth on the front of the main beam. This is not a curved track---yet.(N20)
This leaves the main, which is boomless.
I have read that the express had a massive main compared to the original(mine?). Was that a sq top? I have also been told that the jib configuration is an Express.(?)
What about increasing the foot leingth and a larger roach, leavin most of the increase low on the mast. Would this leave the sail too full and unable to depower? Also an un-managable leech?
What was done in europe to increase Ball size.
Any input is appreciated, other than "sell the boat".
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: Nacra 6.0 What? [Re: AzCat] #185773
07/22/09 01:44 AM
07/22/09 01:44 AM
TeamChums Offline
TeamChums  Offline
I'm pretty sure I know the boat you have. It's a Nacra 6.0 original, not a North American. You have a Morrelli main and an EP main. The EP is the larger one for the N/A version. It simply has a bit more roach to it and generates a bit more power. In heavier air, you could break the mast if you don't upgrade to the longer spreaders and internal diamond wires. I'm sure it's the same mast extrusion as the N/A. You should contact Skip Elliot at E/P sails since he was one of the big designers along with Roy Seaman on this rig. Bullsheet on the square top crap. I sailed one a few weeks ago with a square top and ran the piss out of it. The mast did just fine with us double trapped. I would get the curved jib traveler track and stay with the jib configuration. The front spreader you have is the old version (round bar) and you should keep an eye on it and possibly upgrade to the foil type at some time. I have one for that boat if you're interested or you can get them through Murray's or Performance.
You have a great boat. If you upgrade to the longer spreaders and internal diamonds, they can be a pain to adjust. Get intouch with Rick Bliss from New England Catamarans for some inside tips.
Lee
Re: Nacra 6.0 What? [Re: TeamChums] #185802
07/22/09 09:23 AM
07/22/09 09:23 AM
andrewscott
andrewscott
whats an internal diamond wire???
Re: Nacra 6.0 What? [Re: ] #185811
07/22/09 10:25 AM
07/22/09 10:25 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
My Nacra 6.0 NA has 2 sets of diamond wires, with one set sitting inside the other. So I guess that he means the smaller inside set as being internal.
Re: Nacra 6.0 What? [Re: Hullflyer1] #185813
07/22/09 10:30 AM
07/22/09 10:30 AM
andrewscott
andrewscott
Gotcha... i couldn't figure out how a wire would be run "Inside the mast".
Re: Nacra 6.0 What? [Re: ] #185851
07/22/09 03:48 PM
07/22/09 03:48 PM
Texas
TexasTuma Offline
TexasTuma  Offline
Texas
Better known as intermediate-diamonds... that confused me at first... I designed and ran a square top for a couple of years... makes the sail plan very powerful, butcan depower it quickly also... I do agree with sticking with the self-tacking jib...
cheers...
Scott
Cheers...
Scott Tuma
P 18-2 Mod Turbo "FrankenKitty"
Tornado Classic "Fast Furniture"
Re: Nacra 6.0 What? [Re: TexasTuma] #185888
07/22/09 09:05 PM
07/22/09 09:05 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Scott, PM sent, check your mailbox here!
F-18 Infusion
#626- SOLD it!
Re: Nacra 6.0 What? [Re: TeamChums] #185896
07/22/09 09:53 PM
07/22/09 09:53 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
I spoke with the guys at performance and was told that it is a lighter extrusion than the NA. I thought about adding the internal wires, but the NA mast configuration is a lot different. hounds nearly 2' higherspreaders 18"higher. I have been told that if I make these changes, the existing holes will weaken the mast and defeat the purpose of the changes.
I thought about adding the longer spreader in the current position, using the existing bottom diamond tang and one higher up than the current upper position to attach a longer outer diamond wire. and use the existing upper tang along with a new tang near the base of the mast for the inners. I just dont know how these measurements were derived on the NA, and how doing this willi nilli will affect mast bend and performance. If someone would post the measurements of their 6.0NA wires, I guess I could make a more educated decision.
I am just about to place an order for new shrouds, forestay and regular spreader bars, and dont want to do it twice.
This boat has original EP jib and main, and untii I got caught in a storm in rocky point a month ago, they were in pristine condition. The boat has hardly been used and is in beautiful condition, so I want to do what I can to optomise performance without making it a $10,000 boat. I would like to get a sq top when i upgrade the sails this fall, or sooner. But need to make the rig changes first.
How about some of you engineer types, any ideas about rig configuration?
Also, It does have the foil spreader. When I was in Mexico, the center strut on the foil curled up like a pretzel and got stuck into my furler. Performance said i am the first one ever to have this happen to their knowledge. Im lucky the foil held up when the wind started gusting over 40 and snapping power poles in Los Conches.
Re: Nacra 6.0 What? [Re: AzCat] #185898
07/22/09 09:56 PM
07/22/09 09:56 PM
V
Ventucky Red Offline
V
This boat come from Santa Barbara?
Re: Nacra 6.0 What? [Re: Ventucky Red] #185899
07/22/09 10:02 PM
07/22/09 10:02 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Yes
Re: Nacra 6.0 What? [Re: AzCat] #185908
07/22/09 11:11 PM
07/22/09 11:11 PM
TeamChums Offline
TeamChums  Offline
Hmmm. Not the boat I thought it was. It's not purple by chance, is it? You may want to either buy a new mast, or have Skipp Elliot make you a square top that will work with the softer mast.
Lee
Re: Nacra 6.0 What? [Re: TeamChums] #185909
07/22/09 11:15 PM
07/22/09 11:15 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Um, no, not purple.
If I could find an NA mast I would probably go that route.
Re: Nacra 6.0 What? [Re: AzCat] #185911
07/23/09 12:04 AM
07/23/09 12:04 AM
V
V
Originally Posted by azcat
Yes
Ohh Kay!!!! If this is the boat I am thinking about; the guy you bought it from got it for him and his son to go sailing? I believe he put on a new tramp, and got a set of beach wheels for it. If so, this is an awesome boat as it sits and the sails etc.... are in great shape. I had talked to the original owner at length and was on my way to look at it when the guy you bought it from jumped on it.
In speaking to the original owner he and another guy bought this boat to do the Worrell 1000, and they never had the chance to do it. It was sailed a few times for set up and practice and then sat in a warehouse in West Hills, CA for a number of years. From what I was able to find out from Performance there were only a handful of these built in this configuration. I may be wrong, but I think you have a slightly larger mainsail that the standard 6.0, but smaller then the NA, and a slightly smaller jib to accommodate the self tacker. I believe the spinnaker was never used and if you’re looking to upgrade you may want to go with the newer style Inter 20 hardware setup (pole and snuffer).
Congrats on your boat, this was an awesome deal and thought about it again when it was up for sale this past spring.
Bring that bad boy on over for the Tri-Point, and if ya need a crew we'll find ya one
Re: Nacra 6.0 What? [Re: Ventucky Red] #185918
07/23/09 12:41 AM
07/23/09 12:41 AM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Yes, that's the boat.Clean as a whistle. and the spin is still un-used. I have a large F-18 spin on it now. I also saw it the first time it sold and tried to talk a friend into buying it, he passed. I had just sold my N5.7 (after winning the innaugural Border run) when it came up for sale again.
Only thing I dont like is the whimpy mast.
On a related subject,
The self tacker system seems to leave the jib pretty loose at the leech. Even when using the top hole on the clew plate. How tight should the leech get?
Also, if anyone knows where to find a used curved tacker track, It would be a great addition.
I am looking into thre tri point, maybe the W&R.
Re: Nacra 6.0 What? [Re: AzCat] #185987
07/23/09 03:08 PM
07/23/09 03:08 PM
V
V
Something else I forgot and it may be nothing, but check the measurement of your bridal tangs from the main beam.
The reason I say this is that when I spoke to Performance they had mentioned the name Roy Seaman a few times pertaining to these boats. In looking at a few of the 6.0 he had brought to the Milt and the other ocean race we do here in Ventura, he was all about huge jibs and radical mast rake. To accommodate the jibs, he had the bridal tangs almost to the front of the bows.
fyi - This may screw you when getting new rigging
Re: Nacra 6.0 What? [Re: Ventucky Red] #185989
07/23/09 03:21 PM
07/23/09 03:21 PM
TeamChums Offline
TeamChums  Offline
Those boats that Roy did that on had holes drilled in the bows like we did your spinn pole John and the regluar tangs were still in place. Since you brought that up, the converted 6.0 I saw in Ventura (franken boat) had the tangs just behind the front of the decklid. This boat was a 5.8 that was converted to a 6.0. The normal production 6.0 has the tangs just ahead of the decklid.
Lee
Re: Nacra 6.0 What? [Re: AzCat] #185998
07/23/09 04:07 PM
07/23/09 04:07 PM
Arizona
Team Chums II Offline
Arizona
You won the border run??? I thought a boat with black sails won this little race...
Matt-Man
Team Chums II
Boatless???
Re: Nacra 6.0 What? [Re: Team Chums II] #186004
07/23/09 04:48 PM
07/23/09 04:48 PM
V
V
These boats were not retrofitted by Roy like Frankenboat or the guy from Morro Bay that had a whole custom stainless steel piece mounted to the front of the bows. They were production boats.. Not speaking gospel here, just an after thought of something to check.
Sounds like you need to make it to the Tri-Point to set the record straight grin
Re: Nacra 6.0 What? [Re: Ventucky Red] #186011
07/23/09 05:46 PM
07/23/09 05:46 PM
Arizona
Arizona
[/quote]
I have the trophy. As for tripoint, I would love to come shred it up, but I sold my boat last week and I have a newborn on the way... No worries though, I will have a new boat soon enough.
matt
Re: Nacra 6.0 What? [Re: Ventucky Red] #186019
07/23/09 07:01 PM
07/23/09 07:01 PM
Buzz258 Offline
Buzz258  Offline
John you are right, Performance did build eight 6.0s with self tacking jibs for the Worrell. Gary and I owned one of these boats for awhile. I thought the mast was the weakest point on this boat. Boat also had big spinnaker with broad shoulders ... DDW. This boat also came out of the Santa Barbara area and had very little use. Not sure if it raced in the Worrell or not.
Buzz
0 registered members (), 21,922 guests, and 1,500 spiders.
Most Online23,433
7 seconds ago
