| Re: Blade or VIper
[Re: Gilo]
#186269 07/27/09 02:20 PM 07/27/09 02:20 PM |
Posts: 1,121 Eastern NC, USA | Pepin, Allowing older designs to make the class more accessible is something I can only applaud. However, when a new design comes on the market as an F16 (as it carries the logo in the sail), but at the same time shows a different rating on the schrs tables I find it very confusing and not good for the class. On Carnac for example I raced the Blade at 1.008 (Blade F16), the Viper as 1.035 (Viper F16)...
Do you have the same hesitation about racing 1-up F16s on a different number? Do all other formula classes rate out to the same number on SCHRS or Texel (they do on USSA Portsmouth)? I cannot check out the sites from this computer.
Tom | | | Re: Blade or VIper
[Re: tshan]
#186271 07/27/09 02:37 PM 07/27/09 02:37 PM |
Posts: 439 Memphis, TN | The base F16 calculations in SCHRS uses a crew of two. I think if you recalc with one, it will go down, but I'm not a SCHRS person....
Formula 16 rating: 1.008 Rating Data Points CW Number of Crew 2 AL Max. overall length (Post 2007) 5m CM Max. Mainsail area 15.00m² WS Min. sailing weight 107kg VLM Max. Mainsail Vertical Luff 8.1m CJ Max. Jib Area 3.7m² VLJ Max. Jib Vertical Luff 6.00m (C)SPI Max. Spinnaker area 17.5m² CB Max. Board area 0.2m² VLB Max. Board depth 0.9m BM Maximum Beam of the boat 2.500m NT Number of Crew using Trapeze 2 Rating Calculations L Rated Length 5m WC Crew Weight 150kg W Rated Weight 257kg XM Mainsail Aspect Ratio 4.374 ME Mainsail Efficiency 87.871% XJ Jib Aspect Ratio 9.73 JE Jib Efficiency 96.225% A Rated Sail Area 18.121m² SP Forward Area 4.94m² XB Board Aspect Ratio 4.05 BC Board Correction 4.038
Please note the calculations above are for illustration only and are rounded to 3 decimal places
Viper USA 132
1984 Hobie 18
| | | Re: Blade or VIper
[Re: mikeborden]
#186295 07/27/09 07:35 PM 07/27/09 07:35 PM |
Posts: 976 France | The single handed F16 has a SCHRS rating lower than the double handed. That's the rating of the box rule. If your boat is optimized to the rule like the Blade, the Falcon or the Stealth F16, that's your rating. Now if your boat is measured and it turns out for some reason the rating is higher on that particular boat or design I don't see why it should race with the lower rating.
Note that this applies to handicap races only. On handicap I'll take any advantage I can get. And every single boat is entitled to its measured handicap.
So yes, the Viper *is* a F16, as my oldish Stealth is, after all they fit the box rule. But we have higher handicaps because the measured boat is what it is.
Now, if we are talking about a F16 event, like the UK TT our our nationals coming up next week end, well, there is no handicap there, first one over the line wins. If like me you have a slower boat, well, tough.
| | | Re: Blade or VIper
[Re: pepin]
#186298 07/27/09 07:55 PM 07/27/09 07:55 PM |
Posts: 3,528 Looking for a Job, I got credi... | The single handed F16 has a SCHRS rating lower than the double handed. That's the rating of the box rule. If your boat is optimized to the rule like the Blade, the Falcon or the Stealth F16, that's your rating. Now if your boat is measured and it turns out for some reason the rating is higher on that particular boat or design I don't see why it should race with the lower rating.
Now, if we are talking about a F16 event, like the UK TT our our nationals coming up next week end, well, there is no handicap there, first one over the line wins. If like me you have a slower boat, well, tough. Eric says what I would have said. See here: http://www.schrs.com/ratings.php?pageNum_List=0&totalRows_List=261 The F16 Viper sails as an F16. AHPC F16 Viper Refer to F16 The Viper sails on 1.041. If you sail a Viper at an F16 event, you are a F16 and sail first boat wins If you sail a Handicap event, you can choose to sail as an F16, and use the F16 rating, and win an F16 prize if one is available, or you can sail as a VIPER (note no F16 in the name), claim the slower rating BUT YOU CANNOT win an F16 prize if they are awarded.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Blade or VIper
[Re: Gilo]
#186300 07/27/09 08:11 PM 07/27/09 08:11 PM |
Posts: 9,582 North-West Europe | Now because of this decision of the dealer in EU ...
Who is the EU dealor for the Viper F16 exactly ? Wouter
| | | Re: Blade or VIper
[Re: Wouter]
#186305 07/27/09 10:27 PM 07/27/09 10:27 PM | DougSnell
| DougSnell
Unregistered | ? What is the opinion on center sheeting option on Viper?
Doug | | | Re: Blade or VIper
[Re: Wouter]
#186309 07/28/09 06:27 AM 07/28/09 06:27 AM |
Posts: 976 France | Who is the EU dealor for the Viper F16 exactly ? There are 5 european dealers: < http://www.ahpc.com.au/Brett_Dealers.htm>. One of them is Francis Ferrari from sailfast.fr. For him having a cat that is rating between 1.03 and 1.04 is important as it is the sweet spot for the F104, the french class that's not really a class. | | | Re: Blade or VIper
[Re: pepin]
#186310 07/28/09 06:47 AM 07/28/09 06:47 AM |
Posts: 3,528 Looking for a Job, I got credi... | Who is the EU dealor for the Viper F16 exactly ? There are 5 european dealers: < http://www.ahpc.com.au/Brett_Dealers.htm>. One of them is Francis Ferrari from sailfast.fr. For him having a cat that is rating between 1.03 and 1.04 is important as it is the sweet spot for the F104, the french class that's not really a class. Eric, As far as I understand F104, it's between 1.035 and 1.045; Viper rates 1.041 2 up.
[Re: scooby_simon]
#186313 07/28/09 07:35 AM 07/28/09 07:35 AM |
Posts: 118 Pensacola, FL | Doug, I would get a ride on each of the boats and then decide which one you like/can get the best deal on. To me, there seems to be very little performance difference between them. I think each boat has its advantages and conditions it excels in. AHPC and the Viper have been great for F16 in the pan handle. There are 5 new Vipers within easy driving distance of local regattas. Also, AHPC's support of the Alter Cup will give F16 a lot of publicity and bring 10+ new boats to the US.
Chris Trident F16
| | | Re: Blade or VIper
[Re: Tornado_ALIVE]
#186320 07/28/09 08:25 AM 07/28/09 08:25 AM |
Posts: 439 Memphis, TN | Can not vote, so I'll post Viper.
I would be carefull when discussing 'Optimised F16' The Viper could be lighter but also ticks the right boxes in other areas to make up for it's weight over the other F16s. Pretty quick also for a 'heavyweight' if you look at the F16 results. As far as I am concerned, there has not been an optimised F16 built yet. Still plenty of pace to squeeze out of the box rule.
What I would really lke is a full carbon Viper down to min weight. You aren't the first person to make this comment. So, I'm curious has to what you would do to make it "full" compliant other than making it full carbon to get down to minimum weight. I have one, so I can say anything I want... However, I'm pretty much a beginner, so I don't know what I'm doing. Mike
Viper USA 132
1984 Hobie 18
| | | Re: Blade or VIper
[Re: ]
#186323 07/28/09 08:51 AM 07/28/09 08:51 AM |
Posts: 1,121 Eastern NC, USA | ? What is the opinion on center sheeting option on Viper?
Doug My personal opinions and concerns: 1. Concerns about the clew attachment and luff tension (sail does not currently attach to the boom) 2. Is the boom beefy enough? 3. Is the tramp reinforced for it? 4. How does a mushy tramp affect performance? and one that cannot be overcome is: 5. The tramp is too small for 2-up and center sheeting  That being said, I have never tried it.
[Re: ckuang]
#186326 07/28/09 09:15 AM 07/28/09 09:15 AM |
Posts: 5,525 | Don't be so quick to write off the Blade, especially from the used market. I get a little better performance each time I sail.
I haven't seen that either the Viper or Falcon is any better. At this point, it's all still about the sailor.
What I have noticed is that sailing uni in 6-8 knots the sloops are hard pressed.
Pete Pollard Blade 702
| | | Re: Blade or VIper
[Re: tshan]
#186405 07/29/09 12:56 AM 07/29/09 12:56 AM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | Tom- If anybody knows how to make center sheeting work, AHPC does- it's a common setup in AUS apparently- my Taipan (1997 model and was Greg's personal "demo" before I got it) came with it, and the tramp on a (stock) Taipan is considerably more crowded than any of the new F16's due to narrower boat and jib that sheets to tramp. The center sheeting boom is larger diameter, tramps come w/ reinforcing and grommet for just that purpose. It IS very different from rear sheeting however as you pass "through" the "window" between the mainsheet blocks at stern and blocks that lead down to center-sheeting. Another option is to put the last block on the boom itself, rather than running down to the tramp, and some Taipan sailors have done that, all depends on what feels more comfortable to you. Center sheeting very popular in "A" class (but no crew to worry about there!).
Kirt
Kirt Simmons Taipan, Flyer
1 registered members (FredL),
2,406
guests, and 222
