| Re: Let the debate begin...
[Re: Tony_F18]
#203512 02/15/10 03:38 PM 02/15/10 03:38 PM |
Joined: Jan 2005 Posts: 6,049 Sebring, Florida. Timbo OP
Posts: 6,049 Sebring, Florida. | Anyone have any pictures of the wings the C Class cats are using? I'm wondering if they have a slot like BMWO?
Blade F16 #777
[Re: Timbo]
#203515 02/15/10 03:58 PM 02/15/10 03:58 PM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | I think the C-class wings are more complicated in some ways, and less in others, than BMWO`s wing. The C-class have 3-part wings with 2 slots, as they need to be more efficient as they have no headsails. BMWO has the 9 or so adjustable flaps all the way up the wing - this is actually not a very aerodynamic solution as there must be tip or edge vortices off each top & bottom end of each flap when they are opened to simulate a twisted mainsail. I believe Cogito had a way of inducing twist up the trailing edge of the rear flap of the entire wing, without having any gaps between the sections, which would seem like a more refined solution, probably why they won the LAC several times with the same mostly unaltered design. BMWO designers probably took this all into account and chose the simplest solution which they could, knowing that a headsail would assist the wing develop power, something missing from C-class cats. They also know that they were up against a soft sail, so ultimate efficiency was not a priority, as long as it was more efficient and versatile than a soft sail they knew they had a winner. Stop me now if I`m talking rubbish. | | | Re: Let the debate begin...
[Re: Isotope235]
#203518 02/15/10 04:55 PM 02/15/10 04:55 PM |
Posts: 571 Hamburg | I'm not sure I follow your argument. Are you saying that Alinghi was out of position because the crew couldn't handle the boat? They are far, far better sailors than we. What I wanted to say is that we see only the result but never the reason of what happend on TV. We don't know about wind, waves, other boats around, black out of systems, whatever. We just see the boat is in irons or Alinghi is in the no go zone. And without knowing any details, I will not judge about the crews. Wheels give feedback too. So do the 250 onboard sensors I haved sailed boots with wheels and tiller. I always prefer to have a tiller. Go sailing in the night and you know what I mean. You can have sensors and indicators but the information you get through your hands ears and eyes is the fastest and easiest to understand. My personal opinion, but I think many will agree. One special thing on both boats is that the boards are very forward (in front of the front beam). A normal boat would have inacepatble strong weather helm and might even be directional instable, if not compensated by special means. Maybe the rudder control is an irreversible servo control system, maybe with an artificial feel system. I know that's quite nerdy what I am speaking about and I will not go into detail, but it gives you an idea that these boats are much more than just big beach cats. Cheers, Klaus | | | Re: Let the debate begin...
[Re: Timbo]
#203521 02/15/10 05:21 PM 02/15/10 05:21 PM |
Posts: 5,525 | Anyone have any pictures of the wings the C Class cats are using? I'm wondering if they have a slot like BMWO?
Dig through this. I think there a couple of links with pix. http://forums.sailinganarchy.com/index.php?showtopic=101656&hl=fred
Pete Pollard Blade 702
[Re: Wouter]
#203522 02/15/10 05:29 PM 02/15/10 05:29 PM | DUH
| DUH
Unregistered | Wouter- Dude, I wasted my time beating you down in this forum years and years ago and I'm not going to anymore. It all started eight year ago when I schooled you on the Marshall plan and the US rebuilding Europe. I was just starting back racing catamarans then. If I didn't love the sport so much, I would have never returned to this forum after reading your posts. I guarantee you drive more people away from this forum and catsailing than anything productive you have ever done in your life.
With that being said, goodbye. | | | Re: Let the debate begin...
#203531 02/15/10 07:21 PM 02/15/10 07:21 PM |
Posts: 3,224 Roanoke Island ,N.C. | Jake, Just because the first one of it's kind didn't prove superiority, ...
Hall's mast wasn't the first try; not even inside the A-cat class. Wouter I think you guys are missing my point...while I don't know of other rigid wing attempts in the a-cat class, my point is that it hasn't seen much development on an a-cat platform. Given the fact that it's working quite well for the c-class catamarans, I can't imagine that it won't scale to a similar advantage on the A-cat if the design is perfected. Ben didn't do much sailing with that wing before the worlds or after it. I guarantee you if he built another it would be different and better. I think it all boils down to a point of practicality. The C classes don't race regularly, therefore the hassle of the wing is justifiable,and the venues are spaced(physically) accordingly. If someone wanted to deal with all the inconveniences it could be a dominating force,but it would take a lot of time,money and care.
[Re: Team_Cat_Fever]
#203535 02/15/10 08:18 PM 02/15/10 08:18 PM |
Posts: 1,226 Atlanta | I've raced against Ben at Lake Hopatcong with his wing upwind, and my 50lbs of leverage advantage was about the same as his wing, and we were equal at times, and he (in my opinion) was afraid to put the bows down and use the wing to its full advantage, if he got it right, he was way faster. Downwind the wing was way faster and with practice he would have had a bigger advantage. BMWO proved that wings are faster than soft sails. On a small boat, making it work it is difficult, but with a crew of 10 BWMO absolutely had an advantage. This cup was won by 1. the wing, 2 sailing mistakes made by A. Wouter - where have you been hiding? I also do think the AC is inherently unfair. The USA is afterall a collection of 50 (independent) states under a single name whereas all other nations must find the resources and technology inside a much smaller area with much smaller industrial bases. Wouter you are a socialist idiot. This had nothing to do with 50 states, this was 2 billionaires spending 100M each on a boat race. I've missed your point of view, ever though you are dope. Bill | | | Re: Let the debate begin...
[Re: Karl_Brogger]
#203543 02/15/10 09:09 PM 02/15/10 09:09 PM |
Posts: 6,049 Sebring, Florida. | Karl, if you got it going fast enough and then leaned it sideways, (cant it to windward) or just before you crashed, it would get you ariborne. Keeping yourself airborne is a skill you would then have to learn, kind of like the Moth sailors have to learn how to stay up on the foils. I think the wing concept has a lot of potential, it just needs more development time.
Time and Money that is...If I had unlimited time and money, I'd be on the phone to Mr. Hall right now, talking about a new wing for my new fully foiling, canting wing, 100% carbon A cat. Maybe I could add a kite-board type sail for the downwind work? ;^)
Blade F16 #777
[Re: Timbo]
#203544 02/15/10 09:19 PM 02/15/10 09:19 PM |
Posts: 3,224 Roanoke Island ,N.C. | There was a windsurfer type thing called a wind weapon, that had the sail mounted on a central pivot. You'd turn it vertically to get speed ,then rotate it horizontally and take off and hang from under it. I've still got some VHS tapes(yes Jake, tapes) of them using them in the Gorge.
Another thing a lot of folks aren't thinking about with the wing fever that's going around is that when you flip generally it's catastrophic.Smaller cats tend to flip more than bigger ones so add that into your budget.
[Re: Timbo]
#203546 02/15/10 09:38 PM 02/15/10 09:38 PM |
Posts: 4,119 Northfield Mn | I think the wing concept has a lot of potential, it just needs more development time. Performance potential yes. Worth it, er, um......eek! I'm pissy when I have to take the boat apart anyway. Having to deal with and transport a 30' wing sail would probably end with a click, pop and then the back of my head exploding. | | | Re: Let the debate begin...
[Re: Karl_Brogger]
#203547 02/15/10 09:47 PM 02/15/10 09:47 PM |
Posts: 6,049 Sebring, Florida. | I watched Ben mount his wing, he had it in a box on the trailer, in two sections. It didn't take him too long (less than an hour) and actually it looked much easier than me rigging my spin cat by myself. Now, on the crash thing, yeah, you don't want to land on it! That would slow you down and be expensive, I don't know how hard it would be to right it either, might be easier as it would float quite high and the wind would help you much more than with a conventional sail.
Blade F16 #777
[Re: Timbo]
#203548 02/15/10 10:02 PM 02/15/10 10:02 PM |
Posts: 1,307 Asuncion, Paraguay | Just finished reading the thread and someone asked for photos of C Class wings, maybe you? Anyway, the best pictures were posted here, or at least the link to their site, for I have them on file. Just send me a PM with the email and I'll send them. They exceed the 100Kb size allowed for attachments here.
Luiz
1 registered members (FredL),
2,799
guests, and 283
