| Harken traveler issue #219302 09/13/10 03:57 AM 09/13/10 03:57 AM |
Posts: 465 Oxford, UK | I've got one of these travelers on my Falcon, and the screws that hold the metal plate for the swivel cam cleat to the car have started to come loose. Does anyone know how to tighten them? You can't get a screwdriver onto them because the sheaves are in the way, so I guess you need to take the sheave assembly off, but I can't see how to do that. Any ideas? | | | Re: Harken traveler issue
[Re: pdwarren]
#219305 09/13/10 04:44 AM 09/13/10 04:44 AM |
Posts: 1,382 Essex, UK | I was under the impression that it is the studs that pass throught the sheaves that hold that plate on? If so, then the whole assembly should be loose.... On mine (from memory) there are a couple of nylock nuts holding the sheaves and eye onto the car.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Harken traveler issue
[Re: pdwarren]
#219311 09/13/10 06:57 AM 09/13/10 06:57 AM |
Posts: 1,383 Kingston SE South Australia | If you can lever the assembly up firmly with a screwdriver you should put enough tension on the bolt to stop it rotating as you do the nylock up. good luck
[Re: pdwarren]
#219313 09/13/10 07:18 AM 09/13/10 07:18 AM |
Posts: 12,310 South Carolina | there should be a small short pin that holds that top pivoting stainless steel bracket in place. On the old cars, I believe you had to take the end cap off each end of the traveler to slide out (by shaking) the pins. I'm not certain how you remove them on that traveler though - if my memory serves, the pin might be threaded and have a small flat-head slot on it...you would stick a small screwdriver into each end of the car to unscrew those pins.
Once you have that stainless bracket out of the car, you will have full access to the heads of the screws. Use locktight when putting it back together.
Jake Kohl | | | Re: Harken traveler issue
[Re: pdwarren]
#219364 09/13/10 01:12 PM 09/13/10 01:12 PM |
Posts: 465 Oxford, UK | OK, job done, but what a pain. Even with the right size screwdriver, the stupid little plastic screws got pretty mangled, and even when they're out, you're still stuck with small metal dowels stuck in a horizontal hole and no way to push them out. Would be easy given the right sized magnet, or the ability to turn the car on its side, but I eventually got them with a hand operated vacuum pump and some rubber tubing...
The grub screws got completely mangled going back in, but the loose screws are now done up proper tight with added threadlock so hopefully I'll never be doing that job again! | | | Re: Harken traveler issue
[Re: pdwarren]
#219375 09/13/10 03:22 PM 09/13/10 03:22 PM |
Posts: 1,253 Columbia South Carolina, USA | Harken usually gives good advice when you call customer support just fyi for next time...
304
guests, and 61
