| Re: Hurricane 4.9
[Re: AntC]
#235433 07/29/11 03:12 PM 07/29/11 03:12 PM |
Posts: 1,382 Essex, UK | Do you definately have a 4.9? that was originally the Condor but changed to a 4.9 when White Formula bought the moulds. AFAIK it didn't use Tornado rudders though. I think the 5.9 did use T rudders.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Hurricane 4.9
[Re: Jalani]
#235440 07/29/11 04:30 PM 07/29/11 04:30 PM |
Posts: 1,203 uk | Grant at G P sails produced the last of the condors just before it changed to the 4.9 and he has lots of tornado bits - try him
| | | Re: Hurricane 4.9
[Re: AntC]
#235478 07/30/11 09:40 AM 07/30/11 09:40 AM |
Posts: 266 UK | Hi all i have just acquired a hurricane 4.9 and am after some info. firstly i need a jib for it. does anyone know where i may be able to get a jib or have a picture of a jib so i can estimate a design. did the jib take any of the rig tension or was it a hank on? and secondly one of the rudders needs replacing. the white formula guys have said that the rudder is not made anymore but it is the same shape as a tornado rudder. so if any one has any info on where i can get a second hand blade that would be amazing. regards Ant C The answer depends to some extent on whether the boat was built as a Condor or upgraded (as a lot were). As far as I know the boats from s/n 999 were foam sandwich boats with the 5.9 system. The boats built as 4.9s (from approx s/n 1046) should also have this system. I understand that there may be exceptions to this as I think John Mazzotti may have passed the rights to IYRU/ISAF and home build may still have been possible. Earlier boats had a very 'square' rudder blade. Cheshirecatman | | | Re: Hurricane 4.9
[Re: AntC]
#235514 07/31/11 04:18 PM 07/31/11 04:18 PM |
Posts: 3,528 Looking for a Job, I got credi... | I THINK that the 4.9's had Hurricane 5.9 rudders with different stocks and arms as the setup was different; Grant Piggot WILL be able to help.
ww.gpsails.com
F16 - GBR 553 - SOLD I also talk sport here | | |
2,369
guests, and 385
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
