Page 1 of 3 1 2 3
Plugs/molds #243848
02/10/12 02:20 PM
02/10/12 02:20 PM
BadLatitude1337 Offline OP
Ok guys and girls, I’m about to start building sum hull plugs/molds. Anyone with any info that can save me sum hardship that would be great. So if you have any info/picks that could help me I would appreciate it very much
Open20NA 1337 FOR THE WIN!!!
Re: Plugs/molds [Re: BadLatitude1337] #243850
02/10/12 02:29 PM
02/10/12 02:29 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
Start here
http://www.usaca.info/index.php?option=com_content&view=article&id=476:new-a-cat-design-racer-x-is-back&catid=67:icon&Itemid=122
Tony's A Cat
crac.sailregattas.com
Re: Plugs/molds [Re: BadLatitude1337] #243851
02/10/12 02:32 PM
02/10/12 02:32 PM
awesome that's a good start!!!! thx
Re: Plugs/molds [Re: BadLatitude1337] #243852
02/10/12 02:32 PM
02/10/12 02:32 PM
You might as well asked for a manual on world peace! It's a tricky, artful process to make molds on this scale on a normal person budget. I've made a few on a considerably smaller scale and you can see some of it here (you have to read from the bottom up since the posts are chronological).
http://www.teamseacats.com/category/other-projects/one-meter/page/11/
If I were doing it and intending to build only one boat, I would consider using a strip foam planking method like Ian did on his LR series of a-cats. The process would be the same for you - only the number of layers of fiber would need to increase and you probably need a little more structure in the hulls (including a sub-deck to help with spinnaker and forestay loads). I can't help with the exact lamination schedule but perhaps the Man Shed can shed some light relative to the trimaran he's building.
http://lindahlcompositedesign.weebly.com/lr4-build.html
http://www.themanshed.com/tms-20-trimaran.html
Re: Plugs/molds [Re: BadLatitude1337] #243859
02/10/12 03:04 PM
02/10/12 03:04 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Plugs and molds....are you starting production as opposed to a one off?
Re: Plugs/molds [Re: BadLatitude1337] #243882
02/10/12 10:39 PM
02/10/12 10:39 PM
we are thinking production but are not even close yet.
Re: Plugs/molds [Re: BadLatitude1337] #243883
02/10/12 10:49 PM
02/10/12 10:49 PM
catandahalf Offline
catandahalf  Offline
Hobie, Micky, and Phil started with two surfboard blanks. Hobie Alter shaped the original Hobie 14 by eye and simple tools.
CAD programs suffice for now smile
Re: Plugs/molds [Re: BadLatitude1337] #243884
02/10/12 11:14 PM
02/10/12 11:14 PM
haha I hear u smile
Re: Plugs/molds [Re: BadLatitude1337] #243886
02/11/12 07:55 AM
02/11/12 07:55 AM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
ok who did the design? Do you have renderings?
Re: Plugs/molds [Re: BadLatitude1337] #243889
02/11/12 11:21 AM
02/11/12 11:21 AM
california
F-18 5150 Offline
F-18 5150  Offline
california
What you making?
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Plugs/molds [Re: BadLatitude1337] #243895
02/11/12 01:56 PM
02/11/12 01:56 PM
2 cats a f16 and also a open20
Re: Plugs/molds [Re: BadLatitude1337] #243896
02/11/12 02:06 PM
02/11/12 02:06 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
So you want a couple of prototypes before tooling up for a production
Thermoform foam [Corecell/airex] in female formers, skin the inside, fit bulkheads, pull from formers, join the halves and then laminate the outside. Fill, fair and paint
Sail it, then if you are happy with it - you have a plug for production molds.
Re: Plugs/molds [Re: BadLatitude1337] #243897
02/11/12 02:15 PM
02/11/12 02:15 PM
yea that's about what i was planing on. Guess im heading in the right direction.
Re: Plugs/molds [Re: BadLatitude1337] #243898
02/11/12 04:54 PM
02/11/12 04:54 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Why not an F-18 too?
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Plugs/molds [Re: F-18 5150] #243899
02/11/12 05:12 PM
02/11/12 05:12 PM
dead class......
Just kidding, wanted to jerk Dave's chain. laugh
Re: Plugs/molds [Re: F-18 5150] #243900
02/11/12 05:24 PM
02/11/12 05:24 PM
Palm Harbor, FL
daniel_t Offline
daniel_t  Offline
Palm Harbor, FL
He's probably worried that he wont be able to make the boat heavy enough.
Daniel T.
Taipan F16 - USA 213
Re: Plugs/molds [Re: BadLatitude1337] #243901
02/11/12 05:27 PM
02/11/12 05:27 PM
pgp Offline
pgp  Offline
Worked with a guy we called "spoon", for good reason.
Pete Pollard
Blade 702
Re: Plugs/molds [Re: BadLatitude1337] #244505
02/22/12 01:10 PM
02/22/12 01:10 PM
who has a good lead to foam core strips?
Re: Plugs/molds [Re: BadLatitude1337] #244509
02/22/12 01:47 PM
02/22/12 01:47 PM
Buy sheets, rip the strips on the table saw, and use a router table to machine a radiused bull-nose on one edge and matching relief in the other side. This way they will pivot inside each other to reduce the amount of fairing you need to do and will increase the glued surface area.
Re: Plugs/molds [Re: BadLatitude1337] #244511
02/22/12 01:58 PM
02/22/12 01:58 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
anyone building a Farrier trimaran - start at f-boat.com
Page 1 of 3 1 2 3
0 registered members (), 512 guests, and 601 spiders.
