| Plugs/molds #243848 02/10/12 02:20 PM 02/10/12 02:20 PM |
Posts: 72 | Ok guys and girls, I’m about to start building sum hull plugs/molds. Anyone with any info that can save me sum hardship that would be great. So if you have any info/picks that could help me I would appreciate it very much
Open20NA 1337 FOR THE WIN!!!
| | | Re: Plugs/molds
[Re: BadLatitude1337]
#243850 02/10/12 02:29 PM 02/10/12 02:29 PM |
Posts: 3,116 Annapolis, MD | Start here http://www.usaca.info/index.php?option=com_content&view=article&id=476:new-a-cat-design-racer-x-is-back&catid=67:icon&Itemid=122
Tony's A Cat
crac.sailregattas.com
| | | Re: Plugs/molds
#243851 02/10/12 02:32 PM 02/10/12 02:32 PM |
Posts: 72 | awesome that's a good start!!!! thx
| | | Re: Plugs/molds
#243852 02/10/12 02:32 PM 02/10/12 02:32 PM |
Posts: 12,310 South Carolina | Ok guys and girls, I’m about to start building sum hull plugs/molds. Anyone with any info that can save me sum hardship that would be great. So if you have any info/picks that could help me I would appreciate it very much You might as well asked for a manual on world peace! It's a tricky, artful process to make molds on this scale on a normal person budget. I've made a few on a considerably smaller scale and you can see some of it here (you have to read from the bottom up since the posts are chronological). http://www.teamseacats.com/category/other-projects/one-meter/page/11/If I were doing it and intending to build only one boat, I would consider using a strip foam planking method like Ian did on his LR series of a-cats. The process would be the same for you - only the number of layers of fiber would need to increase and you probably need a little more structure in the hulls (including a sub-deck to help with spinnaker and forestay loads). I can't help with the exact lamination schedule but perhaps the Man Shed can shed some light relative to the trimaran he's building. http://lindahlcompositedesign.weebly.com/lr4-build.htmlhttp://www.themanshed.com/tms-20-trimaran.html
Jake Kohl | | | Re: Plugs/molds
#243859 02/10/12 03:04 PM 02/10/12 03:04 PM |
Posts: 1,203 uk | Plugs and molds....are you starting production as opposed to a one off?
| | | Re: Plugs/molds
#243882 02/10/12 10:39 PM 02/10/12 10:39 PM |
Posts: 72 | we are thinking production but are not even close yet.
| | | Re: Plugs/molds
#243895 02/11/12 01:56 PM 02/11/12 01:56 PM |
Posts: 72 | 2 cats a f16 and also a open20
| | | Re: Plugs/molds
#243896 02/11/12 02:06 PM 02/11/12 02:06 PM |
Posts: 1,203 uk | So you want a couple of prototypes before tooling up for a production
Thermoform foam [Corecell/airex] in female formers, skin the inside, fit bulkheads, pull from formers, join the halves and then laminate the outside. Fill, fair and paint
Sail it, then if you are happy with it - you have a plug for production molds.
| | | Re: Plugs/molds
#243897 02/11/12 02:15 PM 02/11/12 02:15 PM |
Posts: 72 | yea that's about what i was planing on. Guess im heading in the right direction.
| | | Re: Plugs/molds
[Re: F-18 5150]
#243900 02/11/12 05:24 PM 02/11/12 05:24 PM |
Posts: 217 Palm Harbor, FL | He's probably worried that he wont be able to make the boat heavy enough. :-)
Daniel T. Taipan F16 - USA 213 | | | Re: Plugs/molds
#243901 02/11/12 05:27 PM 02/11/12 05:27 PM |
Posts: 5,525 | Worked with a guy we called "spoon", for good reason.
Pete Pollard Blade 702
| | | Re: Plugs/molds
#244505 02/22/12 01:10 PM 02/22/12 01:10 PM |
Posts: 72 | who has a good lead to foam core strips?
| | | Re: Plugs/molds
#244509 02/22/12 01:47 PM 02/22/12 01:47 PM |
Posts: 12,310 South Carolina | who has a good lead to foam core strips? Buy sheets, rip the strips on the table saw, and use a router table to machine a radiused bull-nose on one edge and matching relief in the other side. This way they will pivot inside each other to reduce the amount of fairing you need to do and will increase the glued surface area.
#244511 02/22/12 01:58 PM 02/22/12 01:58 PM |
Posts: 1,203 uk | who has a good lead to foam core strips? anyone building a Farrier trimaran - start at f-boat.com
610
guests, and 1,168
