| Alt 8:1 reeve #245307 03/07/12 09:09 AM 03/07/12 09:09 AM | MN3
| MN3
Unregistered | Can anyone post the alternative way to reeve an 8:1?
Thanks | | | Re: Alt 8:1 reeve
[Re: ]
#245312 03/07/12 11:22 AM 03/07/12 11:22 AM |
Joined: Apr 2006 Posts: 699 SE Pa. or Chesapeak Bay HMurphey
Posts: 699 SE Pa. or Chesapeak Bay | ... And I gave you hints ...
Ok, since I don't know how to post pic's/diagrams I'll walk you through it ... maybe someone can post a pic or diagram
1) Start w/ a Harken Quad Block for the top "Boom Block" and a Triple Block w/ becket and camcleat for the Bottom "Traveler Block" Now you need to modify/add to the bottom Block a "Single Block" attached above the camcleat to a eyestrap that you install on the (2) mach screws that hold the Camcleat on. Now here is the "BIG TRICK" ... the single block must be installed so that it is orientated across, orthogonally (that means 90* to ...)to the triple block ... I tie mine on w/ 1/8" spectra/vectra ... OK?
Now wreaving/threading as follows ....
2) Start w/ the mainsheet passing through the Triple block at the camcleat and center shive .... (the mainsheat exits the triple at the back).... up to the Quad Block to the second shive on the left (this can work both ways, I just picked "left"), thread the mainsheat through over the top from back to front ... next down to the Triple Block to outboard left shive, threading the mainsheet from front to back ... continue up to the Quad Block to the outboard left shive, again threading the mainsheat through over the top from back to front .... NOW FOR THE TRICK .... continue w/ the mainsheat down to the SINGLE BLOCK(!!!) attached to the Triple at the camcleat, threading the mainsheat from left to right through the "single block" ... now up to the Quad Block to the outboard right shive and thread the mainsheat through over the top from front to back ... now down to the triple block, threading the mainsheat through the outboard right shive back to front ... continue up to the Quad Block, the inboard right shive and thread through over the top front to back ... continue down and tie off at the becket on the triple. There you have it ....
Now when you weave/thread an 8X1 Mainsheat Stack this way you will notice that by having the "Single Block" attached to the camcleat the mainsheat will not rub anywhere as it crosses from the left side shives to the right side shives. This works best if the "Single Block" shive is the same size diameter as the "Triple Block's" shives (ie: smaller is NOT better). I use the Harken Quad as my "Top/Boom" block as I know of no other manufacture making a "Quad Block" (but there maybe someone) For the Traverler/Bottom Triple w/ Becket and Camcleat you can use any manufacture you please ... I determined my preference based on the finer adjustment ability and on the angle of the camcleat ... (I like Lewmars personally ... but the Harken "Carbo" series is good also )
(I can't explain "how" I can do this, but I can close my eyes and visualize things in 3D ... rotating it and viewing it from different angles ... something that amazed my Architectural/Engineering Drafting Teacher in those ol' days where you actually used a lead pencil and drew drawings on paper ....)
Harry Murphey H18Mag/P19MX | | | Re: Alt 8:1 reeve
[Re: ]
#245314 03/07/12 12:24 PM 03/07/12 12:24 PM | MN3
| MN3
Unregistered | Thanks Harry, Cheers!
| | | Re: Alt 8:1 reeve
[Re: engineer]
#245342 03/08/12 10:12 AM 03/08/12 10:12 AM | MN3
| MN3
Unregistered | Thanks but i am lookking for an image of how to reeve (run the lines), not of a quad block | | | Re: Alt 8:1 reeve
[Re: ]
#245351 03/08/12 11:41 AM 03/08/12 11:41 AM | MN3
| MN3
Unregistered | harken 8:1 (upgraded to a 9:1 - I added a double eye-spliced line through the top quad, added a 40mm below)
ratch-o-matic 57(?)mm
| | | Re: Alt 8:1 reeve
[Re: yurdle]
#245354 03/08/12 01:37 PM 03/08/12 01:37 PM | MN3
| MN3
Unregistered | I have mine almost identical to the pic in the other thread, with the exception that I swap #1 and #4, which uncrosses them. ditto yurdle, but it was mentioned in the previous thread (above), there is a better way to run the main. | | | Re: Alt 8:1 reeve
[Re: HMurphey]
#245355 03/08/12 02:00 PM 03/08/12 02:00 PM |
Joined: Aug 2003 Posts: 351 Santiago, Chile Andinista
Posts: 351 Santiago, Chile | ... And I gave you hints ...
Ok, since I don't know how to post pic's/diagrams It's easy: - Create your message using the "post reply" button at the top, instead of the "Quick Reply" box at the bottom. - Click at "File Manager" (below, at Post Options) - Select your file - Click Add File - Click Done adding files Then sumbit your message. You will attach the file to the message, it won't be visible yet but from there anyone can make it visible and can explain how. | | | Re: Alt 8:1 reeve
[Re: ]
#245356 03/08/12 02:13 PM 03/08/12 02:13 PM |
Posts: 351 Santiago, Chile | Ok, Step 2:
After sumbitting the message with the attached file, you will edit it to put the image:
- click the link of the attached file on your message, the image will open (on a different window) - Right click on the image - "Copy image url" - Go back to your message - Click Edit - Place the cursor where you want the image - click at the "Enter image" icon - Click any of the options (non floating, left, right,..) - At the text box, right click, "paste"
There you go
| | | Re: Alt 8:1 reeve
[Re: engineer]
#245382 03/09/12 11:04 AM 03/09/12 11:04 AM | MN3
| MN3
Unregistered | Thanks but that is not the same. That one has a double block on the bottom becket, i added a single and still have 9:1
| | | Re: Alt 8:1 reeve
[Re: ]
#245420 03/11/12 09:15 AM 03/11/12 09:15 AM |
Posts: 117 Cairns FNQ | oh well, just trying to help mate....
Nacra 430 Rocket
| | | Re: Alt 8:1 reeve
[Re: ]
#245483 03/13/12 08:35 AM 03/13/12 08:35 AM | MN3
| MN3
Unregistered | Thanks to all (including engineer for trying!) | | | Re: Alt 8:1 reeve
[Re: ]
#246058 03/24/12 10:51 PM 03/24/12 10:51 PM |
Posts: 53 | I stumbled across it today. It's in the hobie tiger manual. The blocks aren't perpendicular...never seen that before. | | |
22,658
guests, and 1,004
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,788 27 minutes ago | | |
