| Re: Rules Question, rounding at a leeward gate:
[Re: Timbo]
#254011 10/26/12 11:58 AM 10/26/12 11:58 AM |
Posts: 1,203 uk | [quote=Timbo Thanks Jeff, I am thinking back to the original situation that started this thread. We were going downwind into a gate, starboard boat coming in on three overlapped port boats, all about to round the same (left, looking upwind) gate mark. The port boats got to the 3 boat lenght circle first, so even though they are on port, they had right of way to round, and the starboard boat had to give them room, correct?
[/quote]
Well yes, but its not the fact that the port tackers entered the circle first. Its the fact that when the starboard tacker entered the circle, the port tackers were over lapped with him. As i said, the port tackers can be a mile away and still be overlapped because they are infront of a line extended across the starboard tacker's transoms.
If a starboard tacker bears off just as he enters the circle, he can break the overlap that some port tackers may have.
[Re: ]
#254016 10/26/12 12:37 PM 10/26/12 12:37 PM |
Posts: 807 Hillsborough, NC USA | "originally established overlap from clear astern within two boatlengths" Can you elaborate on this for a novice racer? There are several ways in which two boats can become overlapped on the same tack within two boatlengths. One boat could overtake another either to windward or to leeward. A boat could tack or gybe next to another boat. Two boats overlapped more than two boatlengths apart sailing different courses could converge. If a boat that was clear astern, overtakes another boat and becomes overlapped to leeward of her, then the leeward boat may not sail above her proper course (see rule 17 for full details). This rule exists so that: - If a boat overtakes you to windward, you can luff her up to protect yourself from getting rolled, and
- If a boat overtakes you to leeward, she cannot luff you up in order to pass.
Does that help clear it up? Regards, Eric | | | Re: Rules Question, rounding at a leeward gate:
[Re: TEAMVMG]
#254017 10/26/12 12:41 PM 10/26/12 12:41 PM |
Posts: 807 Hillsborough, NC USA | If a starboard tacker bears off just as he enters the circle, he can break the overlap that some port tackers may have. The starboard tack boat had better bear off well before entering the zone, and hold that course until she is definitely in the zone. Otherwise, rule 18.2(d) comes into play: "if there is reasonable doubt that a boat obtained or broke an overlap in time, it shall be presumed that she did not". Regards, Eric | | | Re: Rules Question, rounding at a leeward gate:
[Re: John Williams]
#254019 10/26/12 03:49 PM 10/26/12 03:49 PM |
Posts: 3,906 Clermont, FL, USA | ...I luffed him up enough to cause both boats to go almost into wind, at which stage he then purposely turned into my boat, shouted protest and demanded I do a 720. So as the leeward boat, you took him up and he cried foul? Baffling... did he have a case for proper course? Leaving the mark, I'd guess not... judges have patiently explained to me that proper course is a little subjective, but it becomes clearer once you pass the midpoint between marks of the course. Regardless, as leeward boat, obviously you can take him up. One thing I try to say as an overtaking, faster boat - "This will only hurt for a second." I say it with a smile. Yeah, you might want to rethink the conversation starters it does nothing for the agro. Just do what you are gonna do and move on quietly. Unless it is Ricky then by all means carry on.
[Re: Timbo]
#254022 10/26/12 05:58 PM 10/26/12 05:58 PM |
Posts: 337 Arizona | GREAT, NOW IM REALLY CONFUSED!!!
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: Rules Question, rounding at a leeward gate:
[Re: Isotope235]
#254033 10/27/12 04:36 AM 10/27/12 04:36 AM |
Posts: 893 | So as the leeward boat, you took him up and he cried foul? Baffling... did he have a case for proper course? ... Regardless, as leeward boat, obviously you can take him up. If a leeward boat originally established overlap from clear astern within two boatlengths, and later heads the windward boat up "almost into the wind", then she breaks rule 17 "On The Same Tack; Proper Course". The windward boat would be entirely correct to protest. The leeward boat may not sail above her proper course. I hope that helps, Eric But we had gone beyond 3 boat lengths from the mark and in my view he should have had ample time to sail his proper course to the next mark. His biggest complaint was that because he had been forced to turn ( bigger boat and taller mast ) I could then pass him coming out of the mark. | | | Re: Rules Question, rounding at a leeward gate:
[Re: Rolf_Nilsen]
#254047 10/27/12 05:03 PM 10/27/12 05:03 PM |
Joined: Jun 2001 Posts: 425 Toledo, Ohio (western end of ... Mike Fahle
Posts: 425 Toledo, Ohio (western end of ... | Here we go again - no rules conversation would be complete w/o the obigatory whining about how complex the rules are. First of all Rolf, the mast abeam call went out a LOOOONG time ago. Second, those common situations are what are complex, not the rules. Third, the rules have major changes only every four years, and often they do not change much as is the case this year. Fourth, the actual R-O-W rules are amazingly brief considering all that they have to cover - just compare them to practically any other set of game rules. Finally, the rules are changed only to make them work better, be briefer, clearer, and to correct unintended consequences, and only after being reviewed ad nauseum by rules experts all aroud the world so that they CONTINUE to work very well when followed.
How much time and effort have you (and each racer) spent reading, studying, and learning the rules? For the vast majority of racers, it is not much. When you consider that tactics derive directly from application of the rules, it is basic to racing that you understand the rules, not just a good idea. Has anyone considered what they are saying about themselves when they have been racing for a while and whine about the rules being too complex? Hint: it is not complimentary.
[Re: Timbo]
#254065 10/28/12 01:28 PM 10/28/12 01:28 PM |
Posts: 4,451 West coast of Norway | Mike, if I were you I would focus less on whining. You seem obsessed by the word. Of course it is valid to point out the complexity of the current RRS without having to present a new solution. Scientifical proof is more or less based on questioning instead of finished solutions. Trying to have the establishment take a radical new approach never happens until a collapse of the system is near. Same with the RRS. Eg. the proposal Gurra Krantz made which earned no limit of ridicule. The proposal did have real merit though and obviously it works becouse this is the rule most beginners sail by: "Avoid all other boats". Ref: http://rrsstudy.blogspot.no/2008/10/no-rules.htmlI would start with this is the foundation and perhaps even stay with it. If you want to discuss this, I propose you start a new thread. | | | Re: Rules Question, rounding at a leeward gate:
[Re: Clayton]
#254101 10/29/12 11:43 AM 10/29/12 11:43 AM |
Posts: 5,590 Naples, FL | tactics are slow. Hitting boats is even slower.
Find the clean air and steer that way...
[Re: waterbug_wpb]
#254116 10/29/12 08:54 PM 10/29/12 08:54 PM |
Posts: 337 Arizona | Out here in Az, We are trying to get more people into sailing and into racing. Its attitudes like yours that scare people away who might otherwise get into sailing and or racing. Maybe you don't care about that. I do.
CHILL MAN!!!
We are all learning the rules and how they apply to the many gray areas created in racing. You probably shouldn't come out here any time soon and race with us, because you will be PISSED!!! But we have a great bunch of guys with really cool boats! The rest of you, come on out and race with us this winter, Im sure you can teach us desert dwellers a bunch. But guess what. We have gone from a couple cats at a few events a year, to 10 to 15 cats on the third weekend of every month and growing. We will do anything to get people to come back out to the lake at the next event! Last weekend, I left my 2 cats at home so that I could climb aboard a new members cat and teach them how to keep it pointy side up.
At club racing, enjoy the racing, don't hit anyone, learn and / or teach the rules as you go. Just because you memorized the rule book doesn't make you an expert on the rules.
[Re: Clayton]
#254124 10/30/12 09:24 AM 10/30/12 09:24 AM |
Posts: 3,906 Clermont, FL, USA | Don't call me a whiner as I'm probably old enough to be your dad and would you call him that?
Uh yes, I call my dad on his sh!t and he certianly doesn't hesitate to call me on mine. Just becuase we're old doens't mean we get a pass. Oh wait... Ricky I'm old so STFU.
2,580
guests, and 215
