| Re: Rule change
[Re: pgp]
#257500 02/14/13 10:47 AM 02/14/13 10:47 AM |
Posts: 3,969 | The current rule has led to an unintended consequence: the willingness of port tackers to abandon the onus of the rule. I knew you would say that. However, breaking rules is not OK, and there are ways to deal with that. Having one-sided rules will make the game less enjoyable. I know, a broken boat isn't enjoyable either, but there's only so much a rule book can protect you. The rest is best done by culture (protest, pep talk behind woodshed, etc.). Mike | | | Re: Rule change
[Re: pgp]
#257501 02/14/13 11:00 AM 02/14/13 11:00 AM |
Posts: 5,525 | The social dynamic doesn't seem to be upholding the existing rule.
Pete Pollard Blade 702
| | | Re: Rule change
[Re: David Ingram]
#257502 02/14/13 11:04 AM 02/14/13 11:04 AM |
Posts: 5,590 Naples, FL | I'll just be sure to yell louder and earlier and give you friendly advice like "you're not gonna make it" or "don't go in there" you know becuase I'm a giver and Chris is pretty. You're generous to a fault, Ding Perhaps I should revise my strategy to stop your boat: get a pretty driver and push the port tack.... But back to Pete's suggestion. I would have to disagree and reinforce the "it's every sailor's duty to avoid collision". When has a collision served to elevate the sport in any aspect (except maybe parts sales)? This ain't a freakin demolition derby, especially at current boat prices. I'll admit I've "hunted" a few port-tackers on the course or pre-start. If given total immunity on starboard as you suggest, I probably could have rammed a few people if I were so inclined to make my point that way. Can you expound on the exact circumstances of the incident you describe? Was it a total miscalculation of the port tacker causing the collision? Which boat was damaged? What remedies were offered? IIRC, if boats are involved in a collision, aren't they both required to retire? Would the exonerated boat then be given redress in the room?
| | | Re: Rule change
#257510 02/14/13 12:36 PM 02/14/13 12:36 PM |
Posts: 3,906 Clermont, FL, USA |
If you feel that storngly about it put it in your SI's, test the water.
I'm not sure you are allowed to change (technically speaking) those rules in the SI's...per the rules. Since we are doing the "crazy talk" thing... you could chuck the rules and write your own, yes?
| | | Re: Rule change
[Re: David Ingram]
#257511 02/14/13 12:52 PM 02/14/13 12:52 PM |
Posts: 12,310 South Carolina |
I'm not sure you are allowed to change (technically speaking) those rules in the SI's...per the rules. Since we are doing the "crazy talk" thing... you could chuck the rules and write your own, yes? I suppose if we're just saying "to hell with it" anything goes!
Jake Kohl | | |
407
guests, and 47
