Nacra F18 dagger board stop material #269522
02/19/14 08:54 AM
02/19/14 08:54 AM
H
Hullflyer1 Offline OP
H
The material that was used for the dagger board stop, which will hold it in position when I change setting or pull it up to beach the boat has worn out and cracked due to age and material fatigue. Can anyone tell me what to use for replacement. I considered using the Hobie Tiger parts, but I am not sure if they would work. Getting factory parts from the Netherlands appears to be a major undertaking.
Re: Nacra F18 dagger board stop material [Re: Hullflyer1] #269523
02/19/14 10:05 AM
02/19/14 10:05 AM
Have you checked with a local dealer (I presume you are talking about a Nacra?). This is a very common item and most should have it on hand.
Re: Nacra F18 dagger board stop material [Re: Hullflyer1] #269524
02/19/14 10:35 AM
02/19/14 10:35 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Are we talking about the carpet at the top of the trunk?
Re: Nacra F18 dagger board stop material [Re: bacho] #269525
02/19/14 10:35 AM
02/19/14 10:35 AM
I think he's talking about the rectangular piece of white rubber material that screws into the side of the daggerboard trunk and keeps some side force on the board.
Re: Nacra F18 dagger board stop material [Re: Hullflyer1] #269527
02/19/14 10:42 AM
02/19/14 10:42 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
In a pinch, cut a square out of a piece of vinyl tubing. Actually works better than the factory crap.
Philip
USA #1006
Re: Nacra F18 dagger board stop material [Re: Hullflyer1] #269531
02/19/14 12:48 PM
02/19/14 12:48 PM
Quebec, Canada
A. Bourgault Offline
Quebec, Canada
Re: Nacra F18 dagger board stop material [Re: A. Bourgault] #269563
02/20/14 07:25 AM
02/20/14 07:25 AM
H
H
Yes, thank you
0 registered members (), 16,952 guests, and 774 spiders.
Most Online22,490
7 hours ago
