| Re: Nacra F18 dagger board stop material
[Re: Hullflyer1]
#269523 02/19/14 10:05 AM 02/19/14 10:05 AM |
Posts: 12,310 South Carolina | The material that was used for the dagger board stop, which will hold it in position when I change setting or pull it up to beach the boat has worn out and cracked due to age and material fatigue. Can anyone tell me what to use for replacement. I considered using the Hobie Tiger parts, but I am not sure if they would work. Getting factory parts from the Netherlands appears to be a major undertaking. Have you checked with a local dealer (I presume you are talking about a Nacra?). This is a very common item and most should have it on hand.
Jake Kohl | | | Re: Nacra F18 dagger board stop material
[Re: bacho]
#269525 02/19/14 10:35 AM 02/19/14 10:35 AM |
Posts: 12,310 South Carolina | Are we talking about the carpet at the top of the trunk? I think he's talking about the rectangular piece of white rubber material that screws into the side of the daggerboard trunk and keeps some side force on the board.
[Re: Hullflyer1]
#269527 02/19/14 10:42 AM 02/19/14 10:42 AM |
Posts: 2,490 On the Water | In a pinch, cut a square out of a piece of vinyl tubing. Actually works better than the factory crap.
Philip USA #1006 | | | Re: Nacra F18 dagger board stop material
[Re: A. Bourgault]
#269563 02/20/14 07:25 AM 02/20/14 07:25 AM |
Posts: 304 | | | |
20,017
guests, and 446
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
