| Re: New UK designed and built foiling catamaran
[Re: NacramanUK]
#274852 08/19/14 05:35 PM 08/19/14 05:35 PM | Scarecrow
| Scarecrow
Unregistered | You can have a "T" foil without it being a "moth style foil" The key to the moth technology is the wand used to control ride height via lift. This has been adopted by both the whisper and the Stunt S.9. | | | Re: New UK designed and built foiling catamaran
[Re: Bille]
#274860 08/20/14 06:51 AM 08/20/14 06:51 AM |
Posts: 12,310 South Carolina | a couple of little things.
1. Moth style foils were tried on C-cats and proved slow. L/J/Z/C foils have proven fast. Obviously there are a lot of things that effect the cross over on where different systems are beneficial but right now the evidence points towards the non-wand systems being faster.
... Moth style foils are called T-foils. T-foils are slower than J-foils. BUT We use T-foils with our kite boards ; and they have gone over 40kts with them. That's NOT too Bad ? Seriously -- if i were to build a catamaran for the purpose of selling it ; i wouldn't Want it to go much faster than 35-kts, because of liability issues !! ? I WOULD want it to be Very stable, and easy to sail. Up-wind on a T-foil with a kite board ; they will Blow-by any conventional devise currently available ; and do it in Less wind. SO a decently designed T-foil should do quite well on a catamaran. Wing loading on the hydrofoil, has proven to be a BIG thing with our kite boards ; wonder if it affects a heavier catamaran as well ? Bille Wait...I think I felt the earth move...Bille is worried about liability?
Jake Kohl | | | Re: New UK designed and built foiling catamaran
#274865 08/20/14 12:46 PM 08/20/14 12:46 PM |
Posts: 190 |
Not completely sure WHY you would say That ? If i were actually Selling Fast Cat's ; then Yes i would be worried about liability in this sue Crazy USA . Crap -- every other advertisement on radio or local TV , is about some Lawyer trying to talk people into hiring them !! Bille | | | Re: New UK designed and built foiling catamaran
[Re: jollyrodgers]
#274866 08/20/14 12:57 PM 08/20/14 12:57 PM |
Posts: 190 | ...
Based on the video, the whisper seems to foil in the light stuff very easily. It seems like there would probably be too much foil area for the heavy winds if this works anything like sail area does. Time will tell on that speculation, but have seen moth videos where they said that it was too windy to get downwind. That could be just from too much sail area, but it could have something to do with foil size as well.
From Kite boarding, i know that Both foil aria and Sail aria must be balanced , to match the riders weight and speed he wants to go, for the wind that day. And that brings up another question : "why are so many cat sailors, so Reluctant to reef a main sail, to match the power of the wind on any given day" ? | | | Re: New UK designed and built foiling catamaran
[Re: jollyrodgers]
#275004 08/26/14 11:34 PM 08/26/14 11:34 PM |
Posts: 493 Minnesota | Oh-oh...Don't let the lawyers see that picture of a Hobie without a comp tip!
[Re: waterbug_wpb]
#275023 08/27/14 02:42 PM 08/27/14 02:42 PM |
Posts: 190 | I like that the mainsail is reefed... YES !!!!!!!! I was kite boarding on lake Mohave a few years back ; there was a Hobie regatta going on that day , with 50 + cats on the beach. They were ALL looking at the 30+ mph wind and nobody was actually out on the water but one guy and his daughter, (and they were tearing it up) !! As a kite boarder i had No problem with that wind, because i simply matched the sail-aria to the power needed for the day. I did the Same with my buddy on our Hobie 20 ; if it was blowing 30+, we reefed the main to the size of a Hobie 16 for the day, (Or even sailed without the main, and just used a jib). I do NOT understand why most cat sailors won't reef a main and match the sail aria to the wind conditions for the day ; it seams beyond DUMB, to me ? !!! Bille | | | Re: New UK designed and built foiling catamaran
[Re: Rolf_Nilsen]
#275025 08/27/14 04:00 PM 08/27/14 04:00 PM |
Posts: 4,119 Northfield Mn |
No hardware for it on new boats. Mainsail shape is ruined when reefed as the luff curve dont match the mast. If racing and the windspeed changes, you loose if reefed.
As the boats today are mostly racing oriented. They are simply not ready.
Now back to the brit foiler?
This. Upwind isn't the problem. Diamonds maxed, downhaul maxed, rotation back, sheeted hard and drop a couple of inches of traveler and you're there. You're spilling so much air, and the sail is so flat that unless you had a way to properly make use of your downhaul, you'd probably be making more unwanted power than if you made use of what you've already got. Floppy masts and squaretop mains have an amazing amount of control. Downwind though, better bring the beef. and yes, back to the Limey Flyer.
[Re: Karl_Brogger]
#275032 08/27/14 06:42 PM 08/27/14 06:42 PM |
This. Upwind isn't the problem. Diamonds maxed, downhaul maxed, rotation back, sheeted hard and drop a couple of inches of traveler and you're there. You're spilling so much air, and the sail is so flat that unless you had a way to properly make use of your downhaul, you'd probably be making more unwanted power than if you made use of what you've already got. Floppy masts and squaretop mains have an amazing amount of control. Downwind though, better bring the beef. and yes, back to the Limey Flyer. In a straight line - I'll buy that a little...but maneuvering (tacking / gybing) with a reefed rig is MUCH easier.
[Re: Karl_Brogger]
#275033 08/27/14 09:48 PM 08/27/14 09:48 PM |
Posts: 2,844 42.904444 N; 88.008586 W |
This. Upwind isn't the problem. Diamonds maxed, downhaul maxed, rotation back, sheeted hard and drop a couple of inches of traveler and you're there. You're spilling so much air, and the sail is so flat that unless you had a way to properly make use of your downhaul, you'd probably be making more unwanted power than if you made use of what you've already got. Floppy masts and squaretop mains have an amazing amount of control. Downwind though, better bring the beef. and yes, back to the Limey Flyer. This.
F-18 Infusion #626- SOLD it!
[Re: NacramanUK]
#275036 08/27/14 11:40 PM 08/27/14 11:40 PM | Scarecrow
| Scarecrow
Unregistered | Sense the boat's height above water and use it to control the amount of lift generated by automatically adjusting either angle of incidence or flap angle.
[Re: Bille]
#275040 08/28/14 08:13 AM 08/28/14 08:13 AM |
Posts: 5,590 Naples, FL | I do NOT understand why most cat sailors won't reef a main and match the sail aria to the wind conditions for the day ; it seams beyond DUMB, to me ? !!!
Bille
Bring enough gun to the fight. I was originally thinking of reefing for long-distance type races where conditions deteriorate during the race. Sure, going out around the buoys when it's 30+ may not make sense in the first place, but in a controlled area it may be worth finding your "limit". Now, based on the conversations, if there were an easy way to reef/unreef I think you'd see more people take advantage of that in longer races. The time you spend reefing/unreefing (if it's a straightforward process) would more than make up for the time spent sideways. My roller-furling boom makes reefing a snap: Three cranks and two grommets (downhaul and outhaul) and it's reefed. Even easier if I don't need to shape the sail (just roll and go). Un-reefing is the reverse. Perhaps this could be adapted to smaller boats, as I have teardrop rotating/canting mast just like you short-boaters.
[Re: waterbug_wpb]
#275062 08/28/14 10:53 PM 08/28/14 10:53 PM |
Posts: 493 Minnesota | Let's stop hijacking this thread and start a new thread specific to reefing, as it is an underdiscussed topic. I'll create the topic thread under "Reefer Madness". See you there.
Back to the original dream of owning a boat that will cost more than my house!
[Re: Jeff Peterson]
#275075 08/29/14 10:59 AM 08/29/14 10:59 AM |
Posts: 5,590 Naples, FL | sure thing. Thanks
BUT, would this speed demon need to be reefed in heavy air to reduce the chance of the foils ventilating?
I'm sure at some point you'll have to depower, even if it's at 40 kts boatspeed rather than 30.
21,598
guests, and 1,533
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 35 minutes ago | | |
