F16 VIper and F18 C2 Shroud anchor upgrade. If you have a Viper and have not had your Shroud anchors upgraded and are coming to the Nationals in Sarasota, please contact Jill at 727-734-0799 or funinthesunweb@gmail.com We are going to try and replace these at the F16 Nationals in Sarasota in October. Replacement days will be Oct 16 & 17 for the C2.s and the 27th & 28th for the Vipers. You must be on the list to do it then.
"Do or do not. There is no try." - Yoda "Excuses are the tools of the weak and incompetent" - Two sista's I overheard in the hall "You don't have to be a brain surgeon to be a complete idiot, but it helps"
They snap off inside the hull. Check with Jill or Goodall Design when they stopped shipping boats that had the issue. You'll be able to tell if yours have been fixed post delivery because there will be a 1 inch scar in the gelcoat around the chain plate.
PM me your email address and I'll send you Jim Boyer's guide on how to effect the repair.
I had heard of some kind of campaign to replace these, but have to admit I hadn't taken it very seriously. Not liking the idea of a sudden failure. Not sure when or if I'll have my boat in Florida this winter. Will send a pm.
No the tang is a machined lug with a drilled and tapped thread that screws down onto the thread shown in the third last image. I believe from Rehmbo that this detail might have changed as he describes his as more like an eye bolt.
Scarecrow, that is the old capricorn tangs, the C2 / Viper uses and eye bolt. this has nothing to do with that repair nor are there any forecast failures.
changing metric eye bolts for imperial ones.. or so i have heard...
That is not correct. The eye bolts have been known to fail and are being swapped out for larger ones. The new ones may be imperial but that has nothing to do with the issue.
Jeff, I doubt your boat was been swapped out, email Jill and ask her to send you the hardware and the instructions I'm sure it's not that difficult.
Jeff, I doubt your boat was swapped out, email Jill and ask here to send you the hardware and the instructions I'm sure it's not that difficult.
That is pretty incredible dealer support...I have to say.
Re: C2 and Viper Owners
#280488 09/10/1508:10 AM09/10/1508:10 AM
In my case its not their fault. I'm about 1200 miles from them and haven't had my boat in FL in a couple years (something I need to rectify this year!)
Yep! Steeplechase, Tradewinds and Charlotte Harbour is a great winter series. Plus there is that week long event in October :-)
