| Re: Need keel repair advice
[Re: Sunvista]
#57535 09/19/05 07:26 AM 09/19/05 07:26 AM |
Posts: 306 St. Louis, MO | I would go check out the Hobie forum on thier website. Lots of guys on there with lots of experience doing repairs.
My suggestion is to notuse Marine filler but use an epoxy (like West Systems) with a silica filler to make an almost toothpaste consistancy mixture to buld up the keels close to the finished shape. Let ti scure about halfway then add the final layer to build it out the the final shape. Mix this layer with micro ballon filler. This will allow any paint or surface treatment to adhere better.
Nick
Current Boat Looking for one
[Re: hobienick]
#57537 09/19/05 11:49 AM 09/19/05 11:49 AM |
Joined: Sep 2004 Posts: 99 Virginia Beach Sunvista OP
Posts: 99 Virginia Beach | My suggestion is to notuse Marine filler but use an epoxy (like West Systems) with a silica filler to make an almost toothpaste consistancy mixture to buld up the keels close to the finished shape. Actually this is the exact product I did use before. Just dragging the boat into and out of the water wore it away. I think I need to layer it up now. | | | Re: Need keel repair advice
[Re: mmiller]
#57538 09/19/05 01:25 PM 09/19/05 01:25 PM |
Posts: 99 Virginia Beach | Time for a bottom job. You need to use glass cloth if worn through. Layers of woven strips laminated to the keel.
Do a search for "bottom job". How many layers? | | | Re: Need keel repair advice
[Re: hrtsailor]
#57541 09/19/05 04:27 PM 09/19/05 04:27 PM |
Posts: 1,252 California | I have never done one myself, but the basics are: Flip the boat over (keels up) File or grind the keels a bit flatter as a base for the new glass to stack onto. Take 2" glass tape (woven comes on a roll). Use laminating resin and wet out a layer of cloth and resin. Stack up 6-8 layers one at a time. Squeegee down tight between each layer. Let harden (a little) till what we call "green" not yet hard. Use a utility knife or longer blade to trim / carve off the excess glass as best as possible. Would require a lot of grinding if you wait too long. Shape with a rasp or angle grinder when hard. There is a keel-shape template shown in the support area of the Hobie Cat site: Keel Template The guy who did them in San Diego would add a clear coat or gel coat only if desired by the customer. If the keel is split already you have to grind down the gel coat on the sides of the hull on either side of the keel. He would lap the first layer of glass or two over the keep and down the side about an inch to laminate the keel together first and then stack up some layers. | | | Re: Need keel repair advice
[Re: mmiller]
#57542 09/20/05 09:53 PM 09/20/05 09:53 PM |
Posts: 4,119 Northfield Mn | Would any place that does fibreglass repair on boats be capable/qualified in doing this? I'm lazy and would rather pay someone else to do it than to muck it up myself.
[Re: Karl_Brogger]
#57543 09/21/05 12:26 AM 09/21/05 12:26 AM |
Posts: 493 Minnesota | I want to avoid having to do a bottom job, as my hulls have other problems that make it a waste of a good bottom job on crappy hulls (delamination repairs).
Is there a recommended product for 'painting' on several layers of resin to protect the original glass textile, BEFORE it gets damaged? ...and act as a sacrificial coating for new wear?
[Re: Jeff Peterson]
#57544 09/21/05 08:45 AM 09/21/05 08:45 AM |
Posts: 99 Virginia Beach | I want to avoid having to do a bottom job, as my hulls have other problems that make it a waste of a good bottom job on crappy hulls (delamination repairs).
Is there a recommended product for 'painting' on several layers of resin to protect the original glass textile, BEFORE it gets damaged? ...and act as a sacrificial coating for new wear? Well, my original repair, building up keels with marine epoxy filler, lasted two seasons. Too bad Hobie doesn't make a pre-formed FRP keel cap that one could just epoxy onto the bottoms. Now there's a market for some savvy inventor. | | | Re: Need keel repair advice
[Re: Sunvista]
#57545 09/21/05 12:07 PM 09/21/05 12:07 PM |
Posts: 306 St. Louis, MO | I have been looking into using a 2 part epoxy paint. Still looking for feedback from anyone hwo has done it. You might want to try that out.
Nick
[Re: hobienick]
#57546 09/22/05 09:03 AM 09/22/05 09:03 AM |
Posts: 99 Virginia Beach | I have been looking into using a 2 part epoxy paint. Still looking for feedback from anyone hwo has done it. You might want to try that out. My starboard hull has a hole in the keel. No kind of paint is going to plug a hole. I wouldn't waste my time painting the keels on a beach cat. Three drags across the sand and it will be gone. | | | Re: Need keel repair advice
[Re: Sunvista]
#57547 09/29/05 03:33 PM 09/29/05 03:33 PM |
Posts: 493 Minnesota | I thought of using epoxy paint, but quickly dismissed that idea, as the layers would be too thin to quickly build up the thickness required. But a resin product that is a thin gel would be best, but I am not aware of such a product. -Seems to me most products are either 'runny' or 'pastey'.
[Re: Jeff Peterson]
#57548 09/29/05 10:08 PM 09/29/05 10:08 PM |
Posts: 306 St. Louis, MO | I was not suggesting to use teh epoxy paint to build up the hulls. Only as the paint after the hull buildup has been completed.
You can change the consistency of the epoxy by adding fillers until you obtain what you are looking for. It is unlikly that an off the shelf product exists at your desired consistency.
Nick
[Re: JaimeZX]
#57550 09/30/05 10:41 AM 09/30/05 10:41 AM |
Joined: Apr 2005 Posts: 292 Ontario, Canada Captain_Dave
Posts: 292 Ontario, Canada | If I may, I`d like to make a suggestion regarding the dowels that Jaime suggested. Wood dowel is not very suitable for this kind of keel repair. The reason being; as you re-wear those keels (inevitable) the dowel will wick up the water, then swell and bust open the entire repair site. And, once the wicking starts, you`re pretty much toast and the whole repair will have to be cut/ground out. As for what to use, including two-part epoxy and polyurethane for finishing...see my two separate posts titled "major restorations". I have detailed step by step almost everything you are asking. This includes fillers, techniques, product names and even the number of ounces of paint and primer needed. Though my keels were quite worn, they only had to be built up about 3/8 inch max in some spots - usually less. So, I was able to get by with only epoxy (fumed silica as a filler) or plain old VINYL ester resin putty from 3M on the smaller repairs. If you are building up more than this, you really must go with Matt`s suggestion using glass cloth. I personally try to use glass cloth in tape form (as Matt suggested) whenever I can. It is MUCH more convenient than cutting up strips of glass yourself. There are many "before and after" pictures to show you what to expect for your finished product. http://www.catsailor.com/forums/sho...=&sb=5&o=&fpart=all&vc=1http://www.catsailor.com/forums/sho...=&sb=5&o=&fpart=all&vc=1hope it helps, Dave | | | Re: Need keel repair advice
[Re: JaimeZX]
#57552 10/03/05 01:54 AM 10/03/05 01:54 AM |
Posts: 493 Minnesota | I was thinking a non-epoxy resin would be better. Epoxy doesn't have much UV stability, and would require painting...and the paint would just wear off. Are the ester resins thin enough to paint on the hulls?
[Re: Jeff Peterson]
#57553 10/03/05 01:31 PM 10/03/05 01:31 PM |
Posts: 292 Ontario, Canada | Non-epoxy will be less expensive and easier to work with (somewhat), But, it will not be better. Epoxide reactions and the chemical bonds that they form are about a good as it gets for this sort of repair... UV is of no real concern for a keel job and I believe all the resin types can be negatively affected by UV. In general, the quality and relative costs of the common resin types used in this kind of marine construction/repair are as follows (from best/most expensive, to less expensive/effective):
(1) Epoxy (marine grade/quality) (2) Vinyl ester resin (3) Isothalic polyester resin (4) Orthothalic polyester resin.
To these, one can add the filler of choice, or just laminate using glass cloth. Simply "painting resins on" is a common error most of us make when first experimenting with these types of materials. The reason being, if you build up a surface using resins only (without cloth or suitable fillers) you will find that the finshed product will spider-web with cracks and chip apart. This can occur within a few hours to days... or over a season or two depending on several variables. I have found the polyesters much more prone to this than the epoxies. The bottom line is - resins ALONE are only suitable for the very smallest of voids/repairs and no good for structural or abrasive support. It is what we add (fillers, fiberglass) to the resins that give them the qualities we need in the marine field.
Dave
P.S Hey Jaime, I knew you were aware of the dowel thing and were just throwing out ideas... I went to your website a few months back and checked out the impressive (from scratch) fabrication you did on your rudders. Nice work for sure! | | |
1 registered members (vasil),
289
guests, and 39
