Page 3 of 4 1 2 3 4
Re: Trailering wind resistance [Re: hobienick] #71204
04/12/06 02:15 PM
04/12/06 02:15 PM
Sacramento, Ca
acdavis Offline
acdavis  Offline
Sacramento, Ca
I totally agree with Nick here. Your trailer essentially drafts behind your car in NASCAR and bicycle racing. An easy way to tell what is causing an increase in drag is to look at the front of your car dead on and see what sticks out above and on the sides.
As far as designing some type of cowl to increase your fuel efficiency it is extremely difficult and I think you’d end up spending much more building the stupid thing than you’d ever see in fuel savings in a hundred years.
Awhile back there was a group of the best of the best engineers working for Porsche that had supposedly used all of this new cutting edge technology to cut down on drag on some new sports car. When they did the wind tunnel tests they found that they did cut down on the drag. Just for fun they put the car in the wind tunnel backwards and the test results were phenomenally better with the car backwards than forwards. Aerodynamics is difficult for even the best of the best.
Re: Trailering wind resistance [Re: PTP] #71205
04/12/06 02:25 PM
04/12/06 02:25 PM
Sacramento, Ca
acdavis Offline
acdavis  Offline
Sacramento, Ca
PTP,
You're probably fine. Just look at your bearing buddies, if they're sunk into the hub a bit then add some grease, if they're popped out all the way then you're fine.
I don't know if it's bad or not, but before a long trip I always give mine a shot of grease till it oozes out a bit, then I wipe the excess off. I also always have some type of grease gun with me for long trips, my bearings are older and the seals tend to leak a bit. You can get a whole tube of marine grade grease at the big orange home improvement store for about 2 bucks and a grease gun for less than $10. With all the money we dump into our boats, this is one of the cheapest and most important investments we can all make.
Re: trailering [Re: Andrew] #71206
04/12/06 02:42 PM
04/12/06 02:42 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Fuel weighs 5.8 to 6.5 lbs. Ethanol is 6.59 lbs. Diesel is 7.0 to 7.3 lbs.
Then fuel weighs 5.8 to 7.3 lbs (per gallon), right?
Depending on whether is gas, gas/alcohol or diesel.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: trailering [Re: steveh] #71207
04/12/06 03:35 PM
04/12/06 03:35 PM
So far from this thread I have gleaned that a narrower axle will tow better than a wider axle, if the tongue length is the same for both and they are both carrying the same load and with the same tongue weight and same percentage of weight forward of the axle.
So, it sounds like the wider the axle, the longer the tongue you need to maintain the same towing stability, as far as tracking straight behind the tow vehicle.
AND, it also sounds like you are better off with a narrower axle because it is easier on your bearings if most of the weight is distributed to the outside of the wheels rather between the wheels and directly over the axle.
Am I getting this image correctly? This is really interesting stuff .
Re: trailering [Re: steveh] #71208
04/12/06 04:30 PM
04/12/06 04:30 PM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
Steve,
I never said a narrow axel will tow better or worse than a wider one. I said that a longer tounge length will have more effect that a change of a few feet in the axel width.
I think you and I are on the same page here:
Longer tounge = more stable trailer.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: trailering [Re: Mary] #71209
04/12/06 04:40 PM
04/12/06 04:40 PM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
Mary, It doesn't matter how wide or narrow your axel is. The wheel are cantilevered (supported on only one end) no matter what. You need to have an axel/bearing/wheel combo that is designed for the appropriate weight.
That is correct. And as Steve's formula confrimed the longer the tounge the better it will track. In real work application a few foot change in the width of the axel will not have an appreciable effect on the stability of a trailer with a 16' tounge length.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: trailering [Re: hobienick] #71210
04/12/06 05:02 PM
04/12/06 05:02 PM
Panama City Beach, FL
steveh Offline
steveh  Offline
The tracking of the trailer has very little (if anything) to do with the stance of the wheels.
I took stance to mean width. If you meant camber, well, having the tires cambered inward helps stability, too. So does toe-in.
Re: trailering [Re: steveh] #71211
04/12/06 05:24 PM
04/12/06 05:24 PM
Fort Lauderdale, FL, USA
ReefedOne Offline
ReefedOne  Offline
PTP:
I have brand new springs/bearings/hubs/tires (12) that were installed about 6 months ago and I have maybe trailered 100 miles since. Do I need to do anything to the bearings before a long trip?
Its not so much the mileage (minimal in your case), but how many times have they been SUBMERGED IN WATER at the boat ramp, DEEP puddles, etc. during those 6 months? Axle grease is water RESISTANT, to a point, but if water STAYS in there, the churning at 80MPH will eventually cause the soap-base of the grease to "mayonnaise" and break-down... then, the "bad thing" happens... almost always at a very inconvenient--and even dangerous--time and place.
You're probably fine, but hey, pump some MORE grease in there and CHECK closely if the overflow that oozes out is grease... or WATER? Even if they have NOT been dunked during that period, if you live in a humid climate, there's condensation too...
Re: bearing buddy CAPS [Re: ReefedOne] #71212
04/12/06 05:31 PM
04/12/06 05:31 PM
ReefedOne Offline
ReefedOne  Offline
Is it just me, or am I seeing more and more bearing buddy type hubs withOUT the rubber slip caps on them? No, they don't keep out water, but they do keep out SAND, which is important, given the sliding piston, the need to keep grease nipple clean, etc.
Re: trailering [Re: hobienick] #71213
04/12/06 05:32 PM
04/12/06 05:32 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
longer tongue makes it easier to back it up.
Ever tried to back up a short little trailer? very hard if you're used to a long tongue.
Re: Trailering wind resistance [Re: acdavis] #71214
04/12/06 06:56 PM
04/12/06 06:56 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
So that's why the boxster looks the same which ever end you're looking at...
Re: Trailering wind resistance [Re: pdwarren] #71215
04/12/06 07:21 PM
04/12/06 07:21 PM
Upstate, South Carolina
SunnyZ Offline
SunnyZ  Offline
I have noticed that cars are starting to resemble jelly beans. What is with that body style? The next time you drive down the street look at them. Jelly beans...Mine is Kiwi.
Re: Trailering wind resistance [Re: SunnyZ] #71216
04/12/06 07:25 PM
04/12/06 07:25 PM
hobie1616 Offline
hobie1616  Offline
Aerodynamics. Less drag means lower fuel usage. Vans have the same aerodynamic characteristics as a sheet of plywood.
Re: trailering [Re: Mary] #71217
04/12/06 07:40 PM
04/12/06 07:40 PM
Victoria, Australia
C2 Mike Offline
C2 Mike  Offline
Victoria, Australia
Which works better for trailer stability: having a wide axle with the wheels far apart or having a narrow axle with the wheels close together? And whichever way is better, WHY?
The further apart your wheels are, the more stable you are on the road. As somebody else mentioned, draw bar length (how far back the wheels are relative to your car) will reduce any tendancy for the trailer to weave all over the road.
Furthermore, larger diameter wheels are better than the smaller ones as the bearings are not working anywhere near as hard. I use 15" car rims on mine. Went to a wrecker and found 3 mag wheels with good tyres for $25 the lot The negative is your boat is higher off the ground but then if you match the trailer wheels to your car, you can use the car spare if you ever get a flat
Tiger Mike
Re: trailering [Re: steveh] #71218
04/13/06 08:01 AM
04/13/06 08:01 AM
St. Louis, MO
hobienick Offline
hobienick  Offline
St. Louis, MO
I did mean width, but I as said in a later post the 2-4 foot difference in width is not going to make any appreciable difference on a trail with a 16 foot plus tounge length. On a much shorter (5-6 feet) utility trailer, yes the width will have a profound difference.
An easy was to exaggerate the effect of axel width and tounge length is to back the trailer up. The easier it is (removing practice and skill at backing trailers up from the variables) the more stable it will be behind your tow vehicle.
Nick
Current Boat
Looking for one
Previous Boats
'84 H16
'82 H18 Magnum
'74 Pearson 30
St. Louis, MO
Re: trailering [Re: hobienick] #71219
04/13/06 08:06 AM
04/13/06 08:06 AM
just heard from Trey last night on his way down to spring fever. One of the TheMightyHobie18 trailer axles blew up. Not the bearings, he said the axle just folded in three places.
Re: trailering [Re: C2 Mike] #71220
04/13/06 03:25 PM
04/13/06 03:25 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
"I use 15" car rims on mine. Went to a wrecker and found 3 mag wheels with good tyres for $25 the lot"
I don't know with a light weight cat trailer if it makes much difference...but for trailers in general you are not suppose to use car tires because the sidewalls are too flexible in comparison to trailer tires.
Bob
Re: trailering [Re: Seeker] #71221
04/13/06 05:56 PM
04/13/06 05:56 PM
Victoria, Australia
C2 Mike Offline
C2 Mike  Offline
Victoria, Australia
Bob
The average car tyre will have a working load of approx 1200 lbs and my trailer weight is around 1000 lbs per wheel so the loadings will be similar. (I usually have 2 boats and all my stuff in the trailer). You should use a tyre designed for whatever load you are putting on it.
Tiger Mike
Re: trailering [Re: C2 Mike] #71222
04/13/06 09:27 PM
04/13/06 09:27 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
"The average car tyre will have a working load of approx 1200 lbs and my trailer weight is around 1000 lbs per wheel so the loadings will be similar. (I usually have 2 boats and all my stuff in the trailer). You should use a tyre designed for whatever load you are putting on it."
Hi Mike
It's not so much the load, as the flex of the sidewall...from what I have read on the subject, the sidewalls are much stiffer on dedicated trailer tires which helps to keep trailer sway to a minimum...granted this is a much bigger issue with a heavy utility or power boat trailers.
Bob
Re: trailering [Re: Seeker] #71223
04/13/06 10:55 PM
04/13/06 10:55 PM
Colorado
SteveT Offline
SteveT  Offline
Colorado
So here's a little twist: How many people tow a train, as in a camper and the boat or a fifth wheel and the boat. A few of our fleet members do this successfully with the fifth-wheel types having better luck. Also, how many people use a sway brace. Reese makes a really good one that I'm thinking of installing.
H-20 #896
Page 3 of 4 1 2 3 4
0 registered members (), 741 guests, and 84 spiders.
Posts267,056
