Rating: 5
Page 4 of 7 1 2 3 4 5 6 7
Re: Good start would be ... [Re: Jalani] #87859
11/07/06 02:29 PM
11/07/06 02:29 PM
Yes but the Stealth mast is carbon and probably its stiffness distributing is optimized in various spots. The top taper is up there as well.
If a plain alu mast keeps level with this then the alu mast is at least good. If it is better then it will ve very good indeed. The alu masts are extruded so you have less variables to play in order to get the best mast bending characteristics.
But it will never be a race winning secret wapon. The differences are too small for that.
Re: Good start would be ... [Re: _flatlander_] #87860
11/07/06 02:31 PM
11/07/06 02:31 PM
What boat are you sailing now flatlander ?
Re: Good start would be ... [Re: Rolf_Nilsen] #87861
11/07/06 02:33 PM
11/07/06 02:33 PM
A-cat mast profiles and superwing profile are very much the same with the superwing profile being scaled up a bit.
Re: Good start would be ... [Re: Jalani] #87862
11/07/06 02:38 PM
11/07/06 02:38 PM
I have actually put quite a bit of volume up front, especially low down
One way of comparing this designs to other is to calculate where the 150 kg crew needs to sit in order to put the boat at its intended waterline in absolutely no wind. This is then easily compared to the other F16's out there. Just test sail your own boat and see how far you need to sit up front in extreme light winds for the same to happen. The relative distance between positions is a relatively good indication how the volume is distributed. Is the bow more or less resistant to pushing its bows in.
We can then all do this measurement on our own boats and produce an overview and make founded design choice. More or less volume or a different distribution.
Can the software calculate the total volume of the boat. You want it at to be above 500 kg's or it will be a total dud for sitting to deep in the water.
Re: Good start would be ... [Re: Jalani] #87863
11/07/06 03:03 PM
11/07/06 03:03 PM
The Stealth already has hulls canted at 4.5 degrees, I don't know that it makes a huge difference over vertically set hulls though.
I would assume the advantages would be when the hulls are lifted, no flat sailing.
Canting the boards has a lot of theoretical advantages and banana boards even more so. However, I don't think the F16 class want to be getting into the sorts of arguments that have taken place in the A Class......
But we dont have a rule that rules them out, so I dont see how this can be a disadvantage. Im thinking more like straight canted boards, not bannana shaped.
Robi, I'd point out that the Stealth doen't use a wingmast and it's every bit as competitive as the Blade/Taipan....
Good point, so there is a good way to keep cost down. It would interesting to know how much more or less the Stealth's rig cost compared to the Taipan's and Blade's superwing is. This is a good way of keeping the cost down.
Re: Good start would be ... [Re: Robi] #87864
11/08/06 10:56 AM
11/08/06 10:56 AM
Bump - to cant or not to cant.
Canted hulls with canted daggerboards?
Regular hulls with canted daggerboards?
Canted hulls with regular daggerboards?
Re: Good start would be ... [Re: Robi] #87865
11/08/06 11:02 AM
11/08/06 11:02 AM
You missed one Robi;
Regular hulls with regular daggerboards <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Re: Good start would be ... [Re: Jalani] #87866
11/08/06 11:11 AM
11/08/06 11:11 AM
True!
Re: Good start would be ... [Re: Robi] #87867
11/08/06 11:13 AM
11/08/06 11:13 AM
Looking at how well Matt/Gina did at the Alter Cup qualifier I say that uncanted/uncanted is probably a very good place to start our Open source project.
Re: Good start would be ... [Re: Wouter] #87868
11/08/06 11:22 AM
11/08/06 11:22 AM
OK so regular uncanted/uncanted - GOOD start!
Now to some hull dimensions. This is where I usually have the hardest time.
Just as a square, how tall and wide should the hulls be at the tallest and widest point? We know it will be 16'4" or 5.0meters long.
I am going to try to go one step at a time, starting by the hulls. I might even consider building this project after it looks good on paper.
Re: Good start would be ... [Re: Robi] #87869
11/08/06 11:58 AM
11/08/06 11:58 AM
I think my Taipan hull is 0.34 mtr wide at the widest point; shall we start at 0.35 mtr.
Again the hulls volume must at lead be 500 liters or it will sit to deep in the water. I think 550 liters is the total volume of the Taipan hull and that one is a bit to deep in the water when sailed by crews heavier then 145 kg. So lets start for our project with a total hull volume of at least 600 kg. That would be a good start also.
Can you tell that I've done this before ? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Ohh, lets decide to ONLY use SI units like mtr. kg, liter, newtons and no US or imperial units. Till save alot of work and miscalculations.
For example under SI the displacement of a volume is simply the product of the volume in mtr^3 times 1000.
Re: Good start would be ... [Re: Wouter] #87870
11/08/06 02:29 PM
11/08/06 02:29 PM
I agree, we should use only one measuring system.
So far
Non canting
600kg total volume.
Hull width of .35m
Hull length of 5.0m
Hull height What would be a good starting point? Maybe .46m??
Re: Good start would be ... [Re: Robi] #87871
11/08/06 02:54 PM
11/08/06 02:54 PM
I'm not going to get overly involved in your project as its not my class (and there is an F18 kit boat on my "drawing board" at present). But can I recommend starting out with a discussion of LCG, LCF and prismatic coefficient. The rest of your hull design will follow.
Re: Good start would be ... [Re: Wouter] #87872
11/08/06 02:56 PM
11/08/06 02:56 PM
Mark P Offline
Mark P  Offline
Not taking anything away from Matt & Gina but aren't we forgetting that IF they were sailing a Cat with canted hulls etc they might have won and Qualified? A's have been a development class for years longer than F16's and nearly all the top designs are canted hulls. Lets not fall into the Tiger Trap. Tigers have won the F18 Worlds on nearly every occassion but IMO this is can be attributed mainly to Hobie buying the right crews and not necessarily designing the optimum F18.
MP*MULTIHULLS
Re: Good start would be ... [Re: Mark P] #87873
11/08/06 03:39 PM
11/08/06 03:39 PM
Good points Mark,
I will further support my proposal. And it is just that, a proposal.
I propose uncanted hulls and uncanted daggerboards because ;
-1- No clear quantizied advantage of canted can be shown as of yet. I would elaborate but it will be much easier to ask to other side to provide actual data that canting is faster. I, for one, have over the last 5 years not been able to quantize its effect, either positive OR negative. I propose to not include complexity adding components to a design UNLESS their is a clear and quantizied advantage to doing so.
-2- Canted hulls are best implemented by making assymetrical hulls. Not something a homebuilder appreciates. You can't make both hulls from one mould or deck jib anymore. Therefor canting adds cost in building the boat. Same can be said, but too a lesser extend, with respect to canted boards.
-3- Canted hulls and boards appear to be a drawback in conditions where you can't luff your windward hull. Often this is the region where most people do poorly. I must rather trade in some "overpowered weather" performance for good "underpowered weather" performand then the other way around. Such compromises will have to be performed more often during the design. You can design the perfect craft for 10-15 knots and end up with a total dud in 0-10 and 15-25 knots. Lets not design the cats equivalent of a "single gear race car".
-4- Which way do you cant it ? In or out. For a time outward cant was popular in A-class now inward canting is. If you decide on inward canting the will stick out to the side and could become a very nice shin basher when you are trapezing in rought conditions. An uncanted board has the advantge that it is well out of the way there in the middle of the hull.
Now allow me to reply to the other statements.
True, however on this forum a few years ago, Jim Boyer himself wrote that the only difference they found with canting was that the boat steered a little better in the mid range winds, something that was found advantagious when wildthinging the boat. No noticeable speed advantage was reported beyond improved control that in turn allows to maintain top speed better. AHPC had just put out the mark 4 Boyer A-cat which was effectively a Mark 3 but with canted hulls. In F16's we don't do much of wildthing at all. Under spinnaker the way the boat behaves is different from a boat without that does the wildthing.
I'm argueing that this could be a case of where a thing that works in A-cats might well not work in F16's. And there are alot more of these things. I won't elaborate but A-cats and F16's are remarkably different craft. The A-cat designs operate under a very different set of balances and specification, often to such extend that data acquired there is not easily transferable to F16's.
I can also state here that I spoke to 3 different A-cat builders/designers about this and all said that they didn't think that canted hulls would help much at all on boats that carried a crew of two. I won't elaborate so you can dismiss this point I you want.
The Capricorn F18 is uncanted in both boards and hulls : 2006 world champions
The Cirrus F18 is uncanted in both boards and hulls : 2002 world champions
All other world championships ever held were won by the Hobie Tiger (uncanted/uncanted)
So no worlds was ever won by a canted/canted design.
Note how no new F18 has canted boards anymore, only a few have canted hulls. I think only the Nacra Infusion has canted hulls as one of the newer F18 designs. I think we can regard the F18 as a development class of long standing as well.
I refer back to my original point; unless it provides a clear and quantizeable advantage then I wouldn't propose making the design more complex then necessary.
However having said all this, I propose that is people are committed to canted hulls and daggerboards then lets open up a parallel design path where the alternative design has them. Then when both are done we can look at which is the most attractive when balancing performance potential to things like production considerations and cost.
Re: Good start would be ... [Re: Wouter] #87874
11/08/06 04:41 PM
11/08/06 04:41 PM
Canted boards are not legal under the F18 rule. The boards must be located on the centre plane of the hulls.
Re: Good start would be ... [Re: Robi] #87875
11/08/06 04:59 PM
11/08/06 04:59 PM
Israel
Erez Offline OP
Erez  Offline OP
Israel
I already said that I'm not an engineer
So what ever I write is not based on calculations.
I'm very curious as for hull shapes
I have been looking at the hull shapes of every beach catamaran I could find trying to figure out it's concept
and what the designer was trying to achieve,
The more I looked I was able to see things I could not see in the beginning.
I'm very excited about this Open Source Project and I can't wait to find out all the things I don't know that I don't know.
As for the hull width I suggest 0.4m where the water line is,
and then play with the deck width to achieve total hull volume of at least 600 kg.
more volume = more weight
carbon = less weight
carbon = $$$
<img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
We can design a part that will be placed between the hull and the beam and make the hull canted,
or not canted with a different part,
I am not talking about one part with two positions.
Re: Good start would be ... [Re: Erez] #87876
11/08/06 05:11 PM
11/08/06 05:11 PM
Erez I am trying to get a box measurements and then concentrate on where it should be wider, narrow, taller, shorter etc etc.
Volume - 600kg
Length - 5.0m
Width - .35m
Height - ????.45m .46m .44m????
After we get this box dimensions, we can play with placement of the values. For instance how far back will the tallest, widest thickest point be? Rocker placement, crossbeam positions and everything else.
Re: Good start would be ... [Re: Wouter] #87877
11/08/06 05:47 PM
11/08/06 05:47 PM
ncik Offline
ncik  Offline
wouter, displacement is volume multiplied by 1025 if in salt water...1000 if in fresh water.
Re: Good start would be ... [Re: ncik] #87878
11/08/06 05:56 PM
11/08/06 05:56 PM
well we want the boat to also float in fresh water so lets err on the right side and stick to 1000. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
0 registered members (), 15,068 guests, and 930 spiders.
Most Online16,046
6 minutes ago
