| Re: Beach wheel flat tires
[Re: Todd Berget]
#92099 12/13/06 10:58 AM 12/13/06 10:58 AM |
Posts: 3,906 Clermont, FL, USA | Anybody know of a cheap fix for beachwheels. I have a set of Cat trax with a flat. I was thinking of trying fix-a-flat but wondered if anyone else had any ideas?? I'd rather spend $125 on some new blocks or something rather than a new wheel. It's probably leaking through the valve stem. I've used 5200 to reseal the stem with marginal success.
[Re: Todd Berget]
#92100 12/13/06 11:28 AM 12/13/06 11:28 AM |
Posts: 833 St. Louis, MO, | I've been through this many times. Fix-a-flat doesn't work because the wheels never travel at any speed. You are supposed to put he fix-a-flat in and then drive to spread it around. Put tubes in the tire that's leaking. Go to a tire place that can handle it. Not all have the proper machine for doing this. I've been charged anything from $15 to $60 dollars so shop around. The most expensive places were ATV dealers. The cheapest was Tire America here in town. If you use your wheels in salt water the valve stem will corrode and need to be replaced every few years. Mike Hill www.stlouiscats.com | | | Re: Beach wheel flat tires
[Re: Todd Berget]
#92106 12/20/06 03:47 PM 12/20/06 03:47 PM |
Posts: 1,253 Columbia South Carolina, USA | what about tubeless tire replacements? I have a tire and a wheel with a flat, no valve stem opening, no tube(says tubeless on the side.) Will the local tire shop know how to fix this, and what if it has a leak? How do you fill it back up? I see nothing on the tire to fill it back up with.
[Re: dave mosley]
#92108 12/20/06 05:20 PM 12/20/06 05:20 PM |
Posts: 12,310 South Carolina | and if a tree falls in the woods but nobody is around to hear it, does it make a "sound"?
Jake Kohl | | | Re: Beach wheel flat tires
#92109 12/20/06 06:02 PM 12/20/06 06:02 PM |
Posts: 1,253 Columbia South Carolina, USA | maybe... If 4 out of 5 people in America suffer from Diarrhea, does the 5th person enjoy it?
[Re: dave mosley]
#92111 12/20/06 09:49 PM 12/20/06 09:49 PM |
Posts: 12,310 South Carolina | what about tubeless tire replacements? I have a tire and a wheel with a flat, no valve stem opening, no tube(says tubeless on the side.) Will the local tire shop know how to fix this, and what if it has a leak? How do you fill it back up? I see nothing on the tire to fill it back up with. Seriously? This thing doesn't have an air valve? Tubeless just means that the bead of the tire is meant to seal air-tight to the rim and doesn't require an inner-tube.
#92112 12/21/06 07:45 AM 12/21/06 07:45 AM |
Posts: 99 Commerce, MI | Jeremy Leonard of Surf City Catamarans in Santa Cruz, CA has a slick method of taking flat tubeless beach wheels and inserting a inner tube. Works great and I've haven't had a problem since. I've tried cans of fix-a-flat but only got a temporary repair. Another area to check is the valve stems. Sometimes the rubber cracks over time allowing the air to bleed off.
#92115 12/22/06 07:25 AM 12/22/06 07:25 AM |
Posts: 1,253 Columbia South Carolina, USA | Jake, youre a newly wed, surely you are "still right" on occasion....
[Re: arbo06]
#92116 12/22/06 08:28 AM 12/22/06 08:28 AM |
Posts: 887 Crofton, MD | and my wife is 100 miles away, sounds just about right
462
guests, and 89
