Page 10 of 10 1 2 8 9 10
Re: Day two pictures can be seen here ! [Re: Wouter] #135506
03/14/08 11:46 AM
03/14/08 11:46 AM
Without being an expert in english.. Now you sound condescending <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
To be very serious and speaking generally, we all need to think about how we express our opinions and views. As our class grows more and more people comes to the forum. The forum might be the only contact many have with the class. If we want to make our class (and the forum) attractive, we must try not to offend or make our class look like it is filled with buffoons. Condescending, talking down other classes/boats/sailors etc. reflects poorly on ourself.
This is not directed at any post in this thread, but generally speaking.
Re: Day two pictures can be seen here ! [Re: tshan] #135507
03/14/08 12:37 PM
03/14/08 12:37 PM
waynemarlow Offline
waynemarlow  Offline
Guys have a look at the following video www.Stealth_F16_promo_video_01.wmv on it you can see just about every permutation of spinnaker runs with 2 on the wire, driver on the wire, single handed out on the wire etc. Both skippers have been trapezing under spinnaker for years and are both way faster under nearly all conditons by being out on the wire. Good video guys showing how it can be done and is now the standard for all in the UK <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Day two pictures can be seen here ! [Re: waynemarlow] #135508
03/14/08 12:54 PM
03/14/08 12:54 PM
Re: Day two pictures can be seen here ! [Re: Wouter] #135509
03/14/08 01:09 PM
03/14/08 01:09 PM
By the way an alternative is to have the skipper trap out and have the crew with spi sheet sit against the rearbeam. I believe this setup was pioneered by John Casey and John Williams and it worked very well for them.
Totally depends on the conditions - the picture you're basing that upon was a single snapshot of us overstood on the downwind finish. There were times I was on the wire and there were times JC was on the wire - depended upon how much and where we needed the weight to keep the boat under the sails. Mostly, however, as noted several other places, trapping on the F16 on the run did not seem to pay. We enjoyed very deep angles with the boat quite flat for 75% of the runs - this seemed fast.
Re: Day two pictures can be seen here ! [Re: John Williams] #135510
03/14/08 03:33 PM
03/14/08 03:33 PM
I find that when on the wire (up to certain wind strength when things are just happening too quickly) the wire is the place to be.
Two pictures
First pic. Not on the wire. Note how the bow is deeper, but I was crossing a wave; I was further forward. Boat was twitchier.
Second pic; same day, same wind but on the wire. Much faster thru the water and much less drama.
Re: Day two pictures can be seen here ! [Re: bobcat] #135511
03/14/08 05:15 PM
03/14/08 05:15 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
What happened to that rule about keeping your main sheeted in tight when under spin? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
It's easy to talk about someone else but, It looks as if both of them are just running downwind, like with old type spinnakers, not driving as fast as they could. Although if the wind is very strong I'd sometimes do that.
Understood Dermot, but after a previous discussion I had resolved that I needed to overcome the desire to ease the mainsheet while running scared and chicken (deep). Your apparent wind is rotating aft and you are presenting that twisted off roach squarely to the wind (especially after a wave stuff). I was hoping to find out that keeping the main stalled was more effective at reducing the pitching moment.
So travel out yes, ease no.
Just another Northern Sailor.
The remark about the mainsheet was not mine. I just felt that you could have been driving a bit harder - actually the yellow spinnaker is the worst offender. But then I was not there and it was probably blowing harder than it looks. There have been plenty of times when I have been bearing way off and praying to get to the bottom mark without pitchpoling.
Dermot
Catapult 265
Re: Day two pictures can be seen here ! [Re: Dermot] #135512
03/14/08 05:38 PM
03/14/08 05:38 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
.... But then I was not there and it was probably blowing harder than it looks. ....
Is it just me, or do photo's not really give a good indication of how large the swells are?
USA 777
Re: Day two pictures can be seen here ! [Re: scooby_simon] #135513
03/14/08 05:39 PM
03/14/08 05:39 PM
Virginia Beach, VA
Thomm225 Offline
Thomm225  Offline
Virginia Beach, VA
Nice pictures Simon, but it still goes back to steering. You could have just turned a little lower in that picture where you were onboard and it woulda seemed like a walk in the park. It's not even white capping ..............
Re: Day two pictures can be seen here ! [Re: scooby_simon] #135514
03/14/08 05:57 PM
03/14/08 05:57 PM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
But probably pointing higher ?
Dermot
Catapult 265
Re: Day two pictures can be seen here ! [Re: Thomm225] #135515
03/14/08 05:58 PM
03/14/08 05:58 PM
But it would be slow.
GPS plots suggest I'm doing about 3-5kts faster on the wire and sailing the same course as the apparent goes forward.
I agree, when it's to windy for wiring it's time to go deeper, but I'm hoping to get to the point when I can wire down wind in most racing conditions.
When I was sailing my Inter 17 (EU Spec) wiring was faster over about 10kts compared to the other 17 I was racing against most weekends until I could not control the boat from the wire.
I think the GC will be interesting as some believe woring is fast, some do not - hopefully we'll get an answer!
Edit to add, wind was light, about 12kts.
Re: Day two pictures can be seen here ! [Re: scooby_simon] #135516
03/14/08 06:08 PM
03/14/08 06:08 PM
Virginia Beach, VA
Thomm225 Offline
Thomm225  Offline
Virginia Beach, VA
Well, it would be a little slower and a little lower .........
It kinda all comes back to the same thing. Balancing it out. Long downwind leg with few jibes, go for it. Shorter course, I'm thinking stay on board. And like the guy said earlier, depends on the conditions. I don't think Midwinters woulda been a good place to try trapping out downwind singlehanded. Actually, that is what I have been basing my whole argument on. You shoulda seen how many times the spinnakers were collapsing on the singlehanded boats.
Re: Day two pictures can be seen here ! [Re: Thomm225] #135517
03/14/08 07:07 PM
03/14/08 07:07 PM
PTP Offline OP
PTP  Offline OP
I agree, not the best time to try it for the first, second, thrid, fourth.. etc time. But if you could control it, big gains could be made. "go high or go home!"
Re: Day two pictures can be seen here ! [Re: Dermot] #135518
03/14/08 09:52 PM
03/14/08 09:52 PM
Ohio
TeamTeets Offline
TeamTeets  Offline
Ohio
Thanks all for taking the worst sailing form I could muster and post it repeatedly in the forum... That picture is from the last race, and I was beat. Haven't sailed in 7 months... sailed Friday and every race in the series. All I needed for the regatta was a finish.
Let's critique this one instead :-)
Mike, Ohio
Re: Day two pictures can be seen here ! [Re: TeamTeets] #135519
03/14/08 09:55 PM
03/14/08 09:55 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Mike,
Nice racing against you (when I actually made the START <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />) and enjoyed talking with you at the BBQ dinner. Hopefully, we get more chances to race against each other.
Terry
USA 777
Re: Day two pictures can be seen here ! [Re: tback] #135520
03/14/08 10:25 PM
03/14/08 10:25 PM
Ohio
TeamTeets Offline
TeamTeets  Offline
Ohio
Terry, nice racing you too... that wind sure blew the winter cobwebs off for the season. The rest of the year should be easy.
Mike, Ohio
Re: Day two pictures can be seen here ! [Re: TeamTeets] #135521
03/15/08 04:47 AM
03/15/08 04:47 AM
Dublin, Ireland
Dermot Offline
Dermot  Offline
Dublin, Ireland
Sorry about that Mike <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> If the conditions were as bad as everyone is saying, and I was singlehanded, I would have been playing safe and concentrating on getting to the bottom mark upright <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
That's better <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Dermot
Catapult 265
0 registered members (), 2,543 guests, and 519 spiders.
Yesterday at 10:10 AM
